smokin deal is WM an authorized kenwood dealer?
I am in the process of installing my 5120 now. just did the backup cam wiring hook up for an 08.
I have read the wire is in the drivers kick panel.
Some run the wire all the way to the reverse lamp.
Based on advise I got i tapped in near the fuse block find the black wire with the pink stripe for 08 (I would test to make sure you have the correct wire).
I tapped it into a pig tail that I made with two female plugs to hook up cam and hu reverse wire feed.
I still need to tap a switched 12v source for the cam - not sure where to tap that just yet...
The sun is the same, in a relative way, but you're older, shorter of breath, and one day closer to death.-Pink Floyd Dark Side of the Moon
