Quote:
Originally Posted by TJ05FX4
Just an FYI on the JVC.....it only has one RCA port for the sub. So make sure you buy a Y splitter so that you can Y the two RCA's down to the one out on the JVC double din deck. Also on that sub harness, it has two remote wires. Solder them together and then to one end of the resistor and then the other end of the resistor to the remote wire coming out of the JVC deck.
The Y splitter is not needed on the audiophile sub. Only one channel is used for the amp anyway, also the sub harness plug has two rca's on it but one of them is a dead end and goes nowhere. Take a good look at the sub harness in the truck at the radio end, there are only 3 terminals used. the amp turn on lead, and the rca + and - All you need to do is make sure you plug the right rca into the back of your deck, cause only one of them works
