So I installed a Exceleon HU, amp, sub....and was not getting any power to amp and could not figure it out. Took it to best buy and the guy told me the remote wire was bad. So I run a new remote wire now no HU power. So we test it and he says the there is no power coming through the plug from crutchfield...so he taps a grey/stripe wire from the OEM harness to bypass. Now everything works....until the truck moves with the gas. I rev it it works, I let it roll it works, I drive and it cuts out. I come to a stop at the light and it all comes back on. WTF!! Did he tap a wire that makes it to where everything shuts off like the DVD player.(that I dont have by the way)
He may have tapped some sort of VSS wire. That does not sound very cool at all. I hope the BB guy didn't mar up the factory harness to bad either. I would make them fix it, but another person or location. The HU might have a defect not allowing a remote turn on? No too sure.
PHP Gryphon, 2.5" AS level, Strobes on all 4 corners, Black TS Toolbox, 15% tint all around, Pioneer AVH-P4100 with Low_e_red's relay bypass, MA Audio 1000w RMS 1 ohm amp pushing 2 - 10" ED subs under the rear seat, Viper 5901 with 530T auto up/down windows, Viair 380c at 165/200 PSI in a 3 gal tank pushing 1/2" DOT airline to my Siege Engineering train horns, and Beltronics RX 65 pro to keep me out of trouble
What's crazy is the hu was fine the remote was just pinched. Now everything only works
When I am not moving. Ack.
Grey/Black in the Ford vehicles is a VSS wire. Take that back to them, have them put it back and do things right. He has access to Directechs off his ETK. If he gives you any crap, have him call me. (Email me for my #) Make the little **** fix it.
__________________ SPL is one note... SQ is a flat 20-20.
If ported, always tune to CRF 33Hz... aka the Golden Number
Quote:
Originally Posted by Odin's Wrath
Eye-humping: One advantage of dating a girl with a glass eye.
PLEASE DO NOT PM ME. EMAIL ME INSTEAD (the email form for me is found by clicking on my name at the top of the post.)
Thanx manl that is what I thought when it cut out when I was driving.
God*** Well, I will go back tomorrow after I get done with class.
Anyone have a pin diagram...I will fix it if I can find the right wire to use as the ACC Power to bypass to cheap as plug that crutchfield sent me..
