F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Audio & Video System > Head Units
Thread Tools Display Modes
Old 09-23-2008, 11:34 PM
JVC NX7000 Install Help
Does anyone have the JVC NX7000 installed in a 06 F150? I purchased this radio and am having problems installing it...
1. Because the radio has a detatchable face, it need clearance at the bottom of the radio to swing open. This means I need to install the radio sticking out about 1/2-3/4 inch...it just doesn't look right.
2. Is there an install kit for a double din radio that has a groove cut out at the bottom to allow enough clearance for the face to open but still mount the radio flush??
3. the trim plate that comes with the JVC radio doesn;t fill the opening in the F150 trim panel....has gaps top bottom left and right...
Any advice, pictures of your install, recomendations on a double din install kit would be greatly appreciated!
Thanks!
Old 09-24-2008, 06:23 AM
Vehicle: 2005 Ford F150 XL
[quote=wstadmin;3385800]Does anyone have the JVC NX7000 installed in a 06 F150? I purchased this radio and am having problems installing it...
Any advice, pictures of your install, recomendations on a double din install kit would be greatly appreciated! Hey wstad, you'll have to order another trim kit for it, you can't use the one it comes with. It's a Metra kit, can't remember the number right now. As for how far it sticks out of the dash, I was able to trim the kit at the bottom by a little more than an 1/8th of an inch and installed the unit flush with the dash. Faceplate comes out with ease, no issues with clearance. It realy needs the clearance at the top of the unit. Will try to post some pics of the HU in the truck and get you the kit number.
2005 F150 XL scab longbed 4x4 w/ h.d. payload pkg. http://f150online.com/galleries/myga...cfm?gnum=10239
Old 09-24-2008, 06:28 AM
Angry What the hell!!!!
What hapenned to the quote. I know damn well I quoted his post! Man this site is quickly going to ****
Old 09-24-2008, 09:00 AM
Hi Mitch...Thanks for your response....I think the metra kit is the one I have...How did you trim the bottom of the plastic piece? utility knife? I want to make sure this thing looks professional...
Thanks!
Old 09-24-2008, 01:01 PM
Quote:
Thanks!
Hey man. Unless the install kit came seperate from the box the HU was in, you probably don't have the Metra kit. Mine has no gappage at all between the install kit, radio and the dash trim. I used a Dremal Tool and some patience to trim the bottom of the install kit after I scored a straight line with my razor knife. Again, will try to post some pics of it if I can figure out the new gallery procedures. And don't get me started on that one!
Old 09-24-2008, 07:22 PM
Mitch - a picture would be great!!
Old 09-24-2008, 08:48 PM
As soon as I get a chance I'll take a few shots of it and post them. Only had it in for about a month now and I have to say it is pretty impressive!
Old 09-24-2008, 09:11 PM
I went a got the correct metro kit....my concern is cutting the bottom of the plate...I have a dremel tool and I bought a cutting blade, but getting a straight line won;t be that easy....
Old 09-25-2008, 04:27 AM
Vehicle: 2007 Ford F150
use a router with a rabbitting bit
MET 99-5812 or 99-5807
SPL is one note... SQ is a flat 20-20.
If ported, always tune to CRF 33Hz... aka the Golden Number
Quote:
Originally Posted by Odin's Wrath View Post
Eye-humping: One advantage of dating a girl with a glass eye.
PLEASE DO NOT PM ME. EMAIL ME INSTEAD (the email form for me is found by clicking on my name at the top of the post.)
Anyone hiring?!?!? Fired(og) Installer
Old 09-25-2008, 07:30 PM
no luck with a photo yet? Is that how you cut the face plate? with a router? I would imagine that you need a table router to do this perfectly straight - which I don't have.
Old 09-27-2008, 02:55 PM
Metra Dash Kit part number 99-5812. Should not have to do any trimming to it.
The 99-5807 will work but will need some trimming.
Old 09-27-2008, 09:36 PM
Here's a pic of it flush wstad
Old 09-27-2008, 09:50 PM
You do have to trim the kit by an 1/8th of in inch or so to get it to sit flush in the dash and still be able to remove the face plate. Otherwise the unit will stick out a 1/2 an inch from the dash.
Old 09-29-2008, 09:06 AM
Mitch - that install looks great! Right now, I have the radio installed and it is sticking out 1/2 inch....I bought two of those install kits so I'm going to try and trim one of them...I'll have to do it freehand with my dremel tool....hope the line comes out straight...thanks for posting that pic! now I know it can be done.
Old 09-29-2008, 11:57 AM
Hey wstad, I scored a straight line with a straight edge and a razor knife at the bottom of the install kit and just took my time with the dremmel. After cutting, I filed off the rough edges w/ a small file. I should also tell you you'll have to drill out the pre-drilled holes on the side brackets that attach to the radio. You'll have to hold the Metra kit onto the radio w/ the faceplate on, faceplate flush with the face of the kit, to line the bracket holes up w/ the mounting holes on the side of the radio. Hope this helps.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
