Quote:
Originally Posted by bgsu_rhine
Spoke to KCAutosound today (that guy knows his stuff) about the harness to reverse harness pigtail to the OEM Head Unit. I'm trying to add a system to my factory HU without cutting the factory harness so I picked up a Scosche FD23B and FD23RB to try to splice together to make a pigtail. Apparently there are a couple of pins that don't match? Can anyone help someone with limited electrical splicing knowledge on how to make the connection between these two work? What pins need to be moved/switched/replaced/etc? Can someone give a step by step on how to do it?
KCAutosound, you mentioned that a parrot blue tooth harness will do the same thing as the Scosche harnesses. Is this the harness you are referring to: BWFCSS-2P
Do any of the pins in the parrot harness need to be rearranged or is this a true plug and play application?
As far as I remember, all the pins match up. But then again it is a Scosche product....
SPL is one note... SQ is a flat 20-20.
If ported, always tune to CRF 33Hz... aka the Golden Number
Quote:
Originally Posted by Odin's Wrath
Eye-humping: One advantage of dating a girl with a glass eye.
PLEASE DO NOT PM ME. EMAIL ME INSTEAD (the email form for me is found by clicking on my name at the top of the post.)
Anyone hiring?!?!? Fired(og) Installer
