As far as I know, all F-series head units are plug-n-play. A head unit from one 2007+ F-150 should work in any other 2007+ F-150. The antenna connector was changed in 2007, so head units are not forwards/backwards compatible without an antenna adpater. I have found the new antenna connector on 2005 & 2006 F-150's, but it's rare.
I've had a lot of guys bring in Mustang or other passenger vehicle head units and want them installed in their F-150's. It can be done, but the head units require a CPU upload. Typically, the new head unit won't be 100% functional. I usually have to move a pin or two around in the connector to get the backlighting or constant 12VDC to match up with the new head unit.
In your case, an aftermarket system is probably your best bet.
