any head unit will work, it is just a matter of what kind of features you are looking for, personally, i like ones that can play mp3/wma format because you can fit over 100 songs on a cd, however, some things to consider are how much wattage each head unit puts out, how many RCA outputs each has, equalizer settings, ease of use, programable features and aesthetics
as far as subs and amps, i like mtx amps and rockford subs, but with whatever you choose, be sure the wattage ratings match, don't buy an amp that is 400x2 peak of your subs are rated at 300 peak, also, the RMS wattage rating is more important than the peak power, in my opinion
another thing is that it is much cheaper to build a sub box yourself, if able, just remember that need so many cubic feet of air inside the box per sub, it's around 1.3 cu ft or so, it can be easily looked up, just search in any search engine
