Quote:
Originally Posted by dumptruck
I asked this in the amp section but got no response so I figured I'd try here.
Is it possible to install an amp for your door speakers and a sub amp to a factory headunit. My truck has the audiophile system if it matters. Is there a seperate "output" from the factory radio for the sub? If it is possible what is needed to do it. I looked at the JL Cleensweep but it looks like it only has front and rear output and nothing for a sub.
You can always use an amp with a high level input and crossover and run it off your rear speakers...
ie. you'll add a wire from your rear speakers to the input on your amp. The amp will amplify the low end and play it through your sub. Won't sound as clean as using a regular low level input like a dedicated sub out but it will work.
I'm pretty sure the audiophile system does not have an amp built into the head unit. It might be possible to buy an adaptor an get a pre-amp output from the headunit. Check pac-audio.com to see if they have such an adaptor.
