I have this setup in my 05, except I mounted the radio on top and the pocket on the bottom. I also skipped using Alpine's module and just bought a straight Ipod to AI-Net cable that also has a power lead on it so I can charge it while listening. You get the same high quality sound, but unless you have an 06 or newer Alpine deck with the highspeed Ipod adapter, it's easier to control the thing directly instead of through the headunit.
To keep the cable from slipping back into the dash when unplugged, I first drilled a hole about the same size as the width of the connector, then used my dremel to cut a rectangle opening just large enough to fit it through. Once I had it in place and tested it to make sure it worked, I glued the piece I cut out back, and used some black sealant to cover the gaps. It's not as nice as stock, but it doesn't look ghetto either and to my eyes looks a lot better then routing it between the dash and the radio bezel like some people do. Good luck with yours.
