I agree, it sounds to me like you most likely damaged the clips when removing the wire to the PAD light on the bezel. Either that, or it came loose from the harness when you tugged on it inside your dash.
I'd pull off the bezel again completely, and go over the light and clip assembly with a good flashlight, and if nothing there looks damaged, look at the wire itself, starting with the clip and then tracing the wire back into the dash all the way until it connects to the harness. It's a pain in the ass, but it's not as deeply burried as some of these things are. (ask my about mounting an autostart in an 05 150 with passive security system sometime... had gut the driver side door just to find a live lead that wasn't tied into the security system)
Good luck
