All you need is a pair of pliers or something to unscrew it.
Most people that want a shorter antenna VERY CAREFULLY pull the little ball off the top of the antenna with some pliers or the like (use a rag between the pliers and the ball so you dont scratch it up), cut off a chunk of the antenna with some snips, then superglue the ball back on.
Troyer Tuned-3.5" AF1-Magnaflow SI/DO
Eclipse CD 8053
Rainbow Profi Vandis, active
Arc Audio 4050XXK
15" SI Mag, 2.5 sealed
Arc Audio 1500XXK
