F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Audio & Video System > Head Units
Thread Tools Display Modes
Old 12-02-2006, 08:02 PM
Vehicle: 2000 Ford F250
Bad Radio Reception
I have a 97 f150. The radio has always had really bad reception. Only very close fm stations would come in. I bought a alpine unit and installed it. I made sure that the antenna was plugged in. The alpine doesn't get any better reception. 3 or 4 miles from town and I lose the radio station. I unscrewed the antenna from the base and it did make it slightly worse. Any ideas what could be wrong. The antenna wire is connected to the base of the antenna.
Budman
Old 12-03-2006, 01:29 PM
Vehicle: 2006 Ford F150
Send a message via AIM to Bartak1
Have you looked over the whole wire?
Maybe the antenna wire got cut/chewed inhalf somewhere?
Troyer Tuned-3.5" AF1-Magnaflow SI/DO
Eclipse CD 8053
Rainbow Profi Vandis, active
Arc Audio 4050XXK
15" SI Mag, 2.5 sealed
Arc Audio 1500XXK
Old 12-03-2006, 02:07 PM
I'll have to check that next. Is the outer wires of the coax cable grounded? If the inner wire is touching the outer wire would it change the reception? Thanks for the help.
Budman
Old 12-03-2006, 05:44 PM
Vehicle: 1997 Ford F150 5.4
Quote:
Budman
The outer jacket (shield) must be grounded at the antenna base.
The inner conductor must NOT show any resistance to the outer conductor. If it does, it's not an antenna anymore.
Steve
Old 12-03-2006, 06:12 PM
Thanks for the info. Any idea how to remove the base from the fender?
Budman
Old 12-03-2006, 07:28 PM
You have to pop off that black cover first. Get a flat blade screwdriver and take your time so you dont mark it all up. Once you get that off, there are three phillips screws under there that need to come out, then you can just pull the base off the fender.
Eclipse CD 8053
Arc Audio 4050XXK
Arc Audio 1500XXK
Old 12-03-2006, 08:14 PM
Thanks for the help. I'll go check it out right now.
Budman
Old 12-13-2006, 01:38 PM
Send a message via AIM to 97_4sixer Send a message via MSN to 97_4sixer Send a message via Yahoo to 97_4sixer
Same problem very poor reception
I have a 97 F150 lariat. Back in April I had a new head unit installed. Back when it was installed i had great reception. My stock radio had really good reception and now the new hu is getting bad reception. what could be the problem?
Old 12-21-2006, 02:43 PM
I have the same exact problem. Installed a new hu and the reception went to crap, reinstalled the original and the reception is still crap. Reception was great up untill the new hu install.
Old 12-24-2006, 01:01 AM
Vehicle: 1996 Ford F150 4x4
I have a 1996 and since I have had my HU installed my reception has static at times. I was blaming the mountains, but my car tunes in fine.
Think FM boosters would help?
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
