F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Audio & Video System > Head Units
Thread Tools Display Modes
Old 11-02-2006, 07:08 PM
Vehicle: 2001 Ford F-150
Burned out HU display.
My wife's 99 Explorer has an AM/FM CD Cassette Head Unit. It has the controls on the strg wheel, subwoolfer in the back. The unit works and sounds fine, the only problem is that the entire display is blank. There is no clock showing, and you can't see what station you are listening to.
I can't believe that all the individual segments of the individual numerals have burned out at once. Is there a single source (bulb) or something that backlights the display?
2001 F150 Supercab 4x4
Troyer Performance Stage 2 Kit, includes:
  1. Xcal II with 87 perf, 90 perf & tow tunes
  2. Airforce 1 intake
  3. Magnaflow Exhaust, new Y pipe
  4. Plasma boost ignition box
  5. Denso Iriduim spark plugs
  6. Underdrive pulleys
  7. Electric Fans
Recent Craig's list finds:
  1. Centerline Wilderness Falcon 17x8 wheels
  2. Stockland hard tonnaeu cover (matching color!)
  3. Liteforce 240's
http://www.f150online.com/galleries/....cfm?gnum=8068
Old 11-04-2006, 08:53 PM
Vehicle: 2007 Ford F-150
The display is an LCD bar much like the display on a digital clock. If the entire display is blank, then it probably burned out or the ribbon cable going to the control board came out of its socket. Also, the plastic layers on top of the LCD could have delaminated making it so dim it's nearly unreadable. That usually happens only after years of heavy use in which the LCDs become so hot the plastic cover layers begin to seperate.
You can always take the unit apart to see if there's anything loose/damaged. On a 7 year old head unit, you'd probably be better off just buying a new one. Check out Crutchfield...
Old 11-21-2006, 12:48 PM
Vehicle: 1999 Ford F-150
Same Problem
This has recently become a problem with my '99 F-150 as well . . I have not discovered the problem yet, but I am going to be taking the HU apart soon, and take a look at Worland's suggestions.
Thanks man.
Old 11-21-2006, 01:47 PM
Vehicle: 2005 Ford F150
Search the threads the display is a known problem on 97-99's.
It's a crappy soldering job on the display/circuit bd.
2005 King Ranch Supercrew
White/Arizona Beige
5.4 L 3-v
MODS:
Magnaflow SI/DO exhaust system;Leer cap;Bed Rug bed liner;Volant cold air intake system;Sylvania Silver Star Halogens;Carriage Works Billet Grilles(upr & lwr);Putco chrome door & tailgate handles,Edge Evolution,Magellan Integrated Nav System,WOLO air horns.
Old 11-26-2006, 07:12 PM
I must need a search 101 course. I looked under blank display, burned out display, black display and everything I could think of to no avail.
Deewreck, did you have sucess when you took yours apart? I would like to avoid replacing this unit, as the vehicle has 150,000 on it already. But I will keep it for a couple years, and hate not having the display. Also, I think it would be difficult/expensive to find an aftermarked unit that works with all the factory stuff - ie. strg wheel controls, sub, etc.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
