F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Audio & Video System > Head Units
Thread Tools Display Modes
Old 08-29-2006, 01:31 PM
Vehicle: 2003 Ford F150
2003 F150 radio reception problem
Hi. I'd like some input on a problem that recently developed with the reception on my stock radio. It's suddenly developed a reception problem. I think. Mostly static on every channel. AM and FM. Sometimes it will clear up for a few seconds then return to static. Nothing has been done recently to the truck. I've pulled the anntena and checked the connection from the wire. Checks good. I've also pulled the radio from the dash and inspected the connections on the back. Unplugged and plugged back. Seems good and tight.
Any ideas for me to check? Anyway for me to tell if the problem is coming from the wires or from the radio itself?
Thanks for any info you can share.
Joey
Old 08-29-2006, 03:43 PM
Hi.
Well Joey, troubleshooting 101 suggests trying the following ( only one at a time), in the order dictated by your available resources:
- swap in another stock unit from a friend, wreckers, etc, to check if it's the unit or the wiring.
- Does the CD/tape (not sure of your model) work? Or, is there plenty of volume on the static? Chances are, it's the tuner section.
- Connect another standalone antenna to check that entire subsystem - cable included.
- Find someone with one of those wireless FM transmitters; connect a music source & place that near the existing antenna - if you can tune it in properly, it's indicative of a weak tuner section (provided you already did the check above), since the proximity & the power of the transmitter output is providing the stongest possible signal...
Repair is not economical if it's the unit IMHO. If it is fried, go with a 'recycled' unit or take the opportunity to upgrade the head unit .
Good luck
Cheers
Grog
Quote:
Originally Posted by UD
1. Bro
Stupid white trash guys in the 909 with lifted trucks, wife beaters, [crappy] music (usually the most popular rap, hardcore, and nowadays emo) ugly girlfriends, ugly hair, mouths constantly open, retarded as all get up, have no common sense, think its cool to park half on the curb half off, put Flowmaster exhausts on Nissan Hardbodies and Toyota longbeds, don't realize that a huge lift job and giant tires [messes] up your gears, which in turn equals less power. Fags.
Old 08-29-2006, 04:12 PM
Thanks, Vic. I've considered much you suggest.
First, the CD player(6 disc version) works fine. Good sound. Must be the tuner.
Have swapped antennas with no better results. Antenna wire looks good on both ends. No fray or exposed cable. Maybe broke somewhere under the insulation? I do need to try another antenna wire to be sure. If it is the wire, looks like beeotch to run through the console to the antenna. Though I'm sure I can accomplish the job if it is.
Would love to try someone's HU if I can find a match.
As far as the transmitter, I may be able to get someone at a local install/upgrade shop to run a test.
I'm not against an upgraded unit, but I've been happy with my stock, so far.
Can't understand what may have caused this issue. Would make sense if I'd done some work on something that may have caused a short or screwed up a ground.
Speaking of, do you know where the head unit is grounded? May have a bad connection there.
Thanks for your suggestions.
Joey
Old 09-11-2006, 06:54 PM
I've run into a similar problem... in my case if I power cycle the radio starts working OK. I thing there is a problem with the tuner, probably an internal solder problem that develops over time due to vibration. For me it is not worth the time to troubleshoot it, I will simply upgrade to an aftermarket unit.
Old 09-11-2006, 11:36 PM
My 03 developed a poor reception problem a couple of years ago and I have just dealt with it. It fades in and out at times. One guy said it could be a rusted conection where the cable plugs into the antenna but I have yet to check. Sounds like you have so maybe its the head unit. I'll know when I get a new one.
Old 09-12-2006, 11:23 AM
Narrowed the problem down to the headunit itself. Replaced with a new one.
Problem solved.
Learned a little more, too.
Tip --- if you decide to solder the replacement harness in, have a few beers before. Sure steadies the hands.
Old 09-12-2006, 11:29 AM
Hi Joey.
Roger that
Thanks for posting your fix.
Cheers
Bubba
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
