F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Audio & Video System > Head Units
Thread Tools Display Modes
Old 07-19-2006, 06:00 PM
Vehicle: 2004 Ford F150
JL Audio Cleansweep. A Must??
I have a 2004 regular cab f-150. I plan on installing a JL 300/4 amp and JL Component speakers in the front only. I was wondering first of all if the F-150 is even compadable with the cleansweep because i've heard fords cross over the speaker signals and the signals aren't full-range. If this is true the cleansweep wont work. Second of all do i even need one. I've heard factory head units are no good. Thats why i figured i needed one because i wanna keep the factory look.
Old 07-19-2006, 06:25 PM
Vehicle: 2006 Ford Focus
Send a message via ICQ to Lumadar
I have a JL Cleansweep and a JL 450/4 and it worked great. Really does sound like a quality aftermarket deck.
Old 07-19-2006, 07:55 PM
Where did you install the cleansweep and the amp? and was it a hard install
Old 07-19-2006, 08:39 PM
The cleansweep went in the dash behind the stock deck. you could fit a small child in there, lol.
And I put that amp, and my 500/1 behind the rear bench on the back wall. In the supercab and screw models there is a TON of room back there.
In a regular cab it's different, but I am sure you could mount it on the back wall somewhere. MAYBE under a seat?
Old 07-20-2006, 08:36 PM
Yea i want to put the 300/4 under the seat. Dont really know if it will fit and if will overheat or not.
Old 07-20-2006, 09:52 PM
Quote:
I do not know because I didn't do that installation type. If it physically fits, I doubt it will overheat unless a lot of the surface area is physically being pushed on buy something thick.
Go test fit it and see
Old 07-20-2006, 11:21 PM
Vehicle: 2000 Ford F150
Send a message via AIM to Socal858
id recommend against both the cleansweep and 4 channel in a regular cab
a headunit will offer greater fingertip control, the cleansweep is an excellent product but is very expensive. have you considered doubledin video for a factory appearance?
rear fill is not really necessary in a regular cab, i have nothing in the rears and my staging is great. just run some big power to good components in front, with an SQL woofer in rear
7" CST
Fox 2.0
Bilstein 5150
Traction Bars
4.10s
and much more
Old 07-21-2006, 12:31 AM
Vehicle: 2006 Ford F150
Send a message via AIM to Bartak1
If I ever used a factory HU again (doubtfull lol) then I would definatley get the CleanSweep to try to get some better SQ out of the stocker.
Troyer Tuned-3.5" AF1-Magnaflow SI/DO
Eclipse CD 8053
Rainbow Profi Vandis, active
Arc Audio 4050XXK
15" SI Mag, 2.5 sealed
Arc Audio 1500XXK
Old 07-21-2006, 12:21 PM
i wanna keep the stock head unit. And the 300/4 fits perfectly between the rails of the seat. It doesn't look like there will be an over heating problem. Also the 4 channels are for JL XR650-CSi components up front and a 12" JL Sub behind my seat.
Old 07-31-2006, 02:10 PM
Vehicle: 2006 Ford F-150
Another alternative if your not dead set on going JL is the Rockford 3sixty...
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
