F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Audio & Video System > Head Units
Thread Tools Display Modes
Old 07-13-2006, 04:54 AM
Vehicle: 2005 Ford F-150
Backup camera with alpine w200
I just installed a backup camera on my w200 and it works great except that occasionally while I am driving the monitor cuts to the backup camera for a spit second. I am guessing that it is doing this because it is very srnsitive and there is slight voltage going through the reverse wite I tapped for the signal. Anyway... I was wondering if anyone else was having this problem. Also you electrical gurus... what could I use to filter out the random voltage that is causing the HU to switch to the camera? A diode or something? Please let me know.... It is quite distracting to see the reverse cam for no reason every coulde of minutes!
thanks
Stephen
Old 07-13-2006, 12:46 PM
Vehicle: 2002 Ford F150
I'm having no problems with my install.
2002 4X2 Supercrew Lariat
5.4L V8
Bright Red over Silver
20" Lightning Replica Wheels
Goodyear 275/45/20 GT II's
Lightning Front/Rear End
3.55 LS
Cab Steps
Factory Mudflaps
Power Moonroof
Med Graph Lthr Captains Chairs
ARES LSII
Homelink
Penda Bedliner
Wet Okole Covers
DJM 2/4 Lowering Kit
Color Matched Handles/Emblems
Superchip
Magnaflow Catback Exhaust
AirForce One FIPK
Lightning Heads & Tails
Alpine IVA-W200
http://www.f150online.com/galleries/...y.cfm?gnum=457
Old 07-13-2006, 02:10 PM
Vehicle: 2007 Ford F150
Send a message via AIM to BREWDUDE
I had a problem with mine and had to install a relay for the power to the head unit when the camera was activated.
Here's my thread. Post #38 is where I explain what I did to fix it with a relay. If you need anymore info just ask and I'll be glad to help you.
Reverse Camera problem..HELP!!!!!
BREW
Quote:
I wish my lawn was EMO....it would cut itself
Old 07-14-2006, 05:19 AM
Brew...
Wasnt yours flickering when it was in reverse?
My problem is the opposite I think. My HU will flip to the camera screen momentarily when I am just driving around. I suppose a relay might fix this but i am not totally sure. I am guessing that for some reason it is sensing power when the reverse lights arent on. who knows why... I guess I could try the relay and see if it stops it.
thanks for thte input
Stephen
2005 F-150 SuperCrew FX4
Appearance - Nifty Coverall Floormats * Line-X Bedliner * C.M.I. Low Pro Black Toolbox * Back Carriage Works upper and lower grills * Front window tint * Depo Black Headlighs * Black tinted tail lights and 3rd brake light * Black 20" Factory wheels * 33x13.50R20 Super Swamper Iroks * 2 1/2 inch Autospring * Skyjacker Add-a-leaf
Audio/Security - Python 881XP Alarm/Remote Start * Infinity Kappa 680.1cs Components
Performance - Edge Evolution
Gallery
Old 07-14-2006, 05:26 AM
Ok I reread your posts and I think I may be having the same problem. I think I just didnt understand what your problem was before.
Is there any way you could give me more specific instructions on the relay? Basicly just what relay to use and where to get it. It should be pretty simple to wire up... But I have never installed a relay before.
Gallery
Old 07-14-2006, 11:46 AM
Since I'm sure I would confuse you by trting to explain it, check out the link Im posting. It is real easy to understand. Just read the relay stuff. A little further down the page it talks about adding a switch and stuff, just ignore that.
I bought my relay at Radio Shack for $6. I'ts pretty similar to the one in the picture. It will have the diagram on the side of it that shows what post is power, ground, source and switched. Look at the relay you buy, follow the link I gave you and you will be fine. Just so you know, I used a fuse tap to tap into a fuse at the fuse box in the passanger kick panel. Theres also a ground stud right on the side in the kick panel that I used. So to go by the picture in that link, #1 went to the revers light wire in the passanger door sil, #2 ground, #3 went to the fuse panel and #5 went to the "camera turn on" wire in the head unit.
I hope this helps. If you need any more info let me know. Heres the link.
http://www.r1200gs.info/howto/relay.html
And heres a link to the relay I used. Any Bosch or Hella relay of the like will be fine.
http://www.radioshack.com/product/in...entPage=search
BREW
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
