Quote:
Originally Posted by JBM
I just popped in some polk db570's into my stock 03 extended cab. Due to the factory h/u it kinda is bland.
I have the same issue alot of people do, i wanna keep my 6x changer and factory look, so whats the best option?
I would replace the h/u if it was really needed,
But would an amp accomplish the same thing?
And i have no idea what this cleansweep unit is, but it looks good
Anyways, DB's & SQ for the $$ what is the best option?
I would get the CleanSweep (I did, heh) and then a 4-channel amp. Those speakers will work with a modest 50-75 watts RMS with GREAT results. I even ran those on a POS Sony Xplod amp back in the day on my first system before I got a quality amp and they still did fantastically.
But, in the end you will ultimately need a 4 channel amp for more solid sound and higher volumes...and of course a clean sweep will help to clean the sound up as well.
*If* you have to choose between the two...the 4 channel will give the most drastic results in that situation.
