F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Audio & Video System > Head Units
Thread Tools Display Modes
Old 11-08-2005, 09:56 AM
Bridging factory HU
I asssume that all the OEM HUs are the same and provide 4 speaker high level outputs. Anyone know if these can be bridged??
I've got a reg cab so am only using two spekaers and would like to upgrade the power and the spekaers but keep the factory HU.
Old 11-10-2005, 02:30 PM
Vehicle: 2006 Ford F150
Send a message via AIM to Bartak1
No.
If you want to up the power, but keep the factory HU, you can use an amplifier and LOC to convert the signal.
Troyer Tuned-3.5" AF1-Magnaflow SI/DO
Eclipse CD 8053
Rainbow Profi Vandis, active
Arc Audio 4050XXK
15" SI Mag, 2.5 sealed
Arc Audio 1500XXK
Old 11-11-2005, 05:17 PM
Vehicle: 2007 Ford F-150
Check and see if your HU has FADE control. If so, it'll have two (front & rear) channels.
You can bridge the output. The only obstacle is that the factory wiring harness probably does not have wires/pins going to the rear channel on the HU.
Back in the 70's & 80's, we'd just solder a "run" between the channels on the HU connector to bridge them. No need to run an amp... you'll get the extra power you were looking for.
Old 11-11-2005, 06:16 PM
Vehicle: 1998 Ford F150
I'd be a little hesitant to bridge it as well, I can't speak from experience here, nor would I have the funds to attempt it but... Aftermarket decks are not made to be bridged - except pioneer(rear outputs) for a small sub, why would a factory deck be any different?
I get the impression worland is "combining" outputs, + to + and - to -, I don't know, I don't really follow his description. Then again, 70's and some 80's cars were frequently Common ground - and thats a whole different story.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
