It probably has a choke on it, check the position on that. And yea, if the gas is old you might want to do a new mixture of gas and 2 cycle oil. Might also check the air filter, too.
push that blue button, thats the compresson release, choke the engine, pull until it hits. Then take off choke, push the compression release again and pull until it hits again, rev the engine and she'll run, always make sure to get the blade up to speed gradually then start cutting
Are you sure it's a 2 stroke? I rented one last year and it took regular gas, but it was a walk behind saw.
It would still run with a mix
__________________ 2006 F150 XLT 5.4 4x4 Performance: Cheap ebay CAI w/ K&N filter, Delta Force tuning Exhaust: Stock manifolds, NO cats, 2.5" true duals, Magnaflow X pipe, Original 40 Series Flowmasters, 3.5" stainless tips Other mods: Nathan Airchime K3LA locomotive horns Exhaust videos: Idle, rev and hammer it! Cruising by Pulling up to an idle Inside accelerating and cruising
Danggg, and I just used a sledge to plumb a bathroom in the basement. Only 4 inches of concrete. Nope, wasn't pretty, but Redi-mix and carpet covered that up
I thought about using the Muzzle loader, - ahhh, the neighbors were nosey enough
Reason: forgot the "g" in dang
