Strong Focus = Lightning Killer!!!
somewhat local car from a Mustang Forum. Not sure what times it runs, or how much HP it puts out. But it sounds good.
http://ok-focus.com/videos/preview.wmv
http://www.kugelkomponents.com/focus/focus.html
Check it out!
You can buy a kit for your focus !!
Johnathan
Check it out!
Johnathan
I love it!! Kind of makes me not want to get rid of my P.O.S. Focus!! $5500 for the complete kit without any drivetrain parts is kind of steep though. In the video's, I like how they're laughing like little girls at how fast that thing is.
Jason
Jason
here is a few specs on his car.
351w Bored .040 over to 357 c.i.
10.5:1 Compression
TRW Lightweight Forged Pistons
Eagle H-Beam Forged Rods
Milodon Stainless Valves
Comp Cams Hardened Chromoly Pushrods
Comp Cams Magnum Valve Springs w/Titanium Retainers
Comp Cams Magnum Roller Cam: .533 Lift, 284 Duration, 110 LSA, 106 Centerline
Comp Cams Magnum Roller Lifters
Comp Cams Pro Magnum 1.7 Roller Rockers
Comp Cams Double Roller Timing Chain
Clevite Bearings
Pro Comp Balancer
Milogon Windage Tray
ARP Head Bolts
ARP Main Studs
Edelbrock Performer Aluminum Heads, Ported & Polished
Edelbrock Torker II Intake Manifold
Holley 750cfm Carb
Proform Carburetor Main Body
Ford Racing 9mm Plug Wires
MSD Digital 6 Plus Ignition
MSD Pro-Billett Distributor
MSD Blaster2 Coil
Edelbrock Elite Valve Covers & Air Cleaner
Edelbrock Foam Element Filter
Flex-A-Lite Cooling Fan
Lokar Billet Transmission Dipstick
Custom Exhaust w/ Flowmaster Delta 40 Mufflers
Custom Short Tube Headers
Super Huge Aluminum Radiator
Moroso Radiator Cap
Complete Stainless Steel Fuel System
Billett Fuel Pressure Regulator
Summit Racing 16-Gallon Fuel Cell
Summit Racing 140gph Fuel Pump
Suspension & Drivetrain
Custom Coilover 4-Link Rear Suspension
Custom Front & Rear Anti-Roll Bars
G2 Sport Lowering Springs-Front
Custom Steel Braided Lines
Energy Suspension Bushings
Focus Sport Strut Tower Brace
Focus Sport Rear Chassis Brace
Built C4 w/ TCI Clutches
TCI Reverse Manual Valvebody
Edge 9.5" Torque Converter w/ anti balloon plate for N2O
B&M Pro-Ratchet Shifter
TCI Transmission Cooler
Ford 8.8 Rear End w/ 3.73 Gears
Traction-Loc Differential
Custom Driveshaft
OZ SuperLeggera Wheels 17X7 +42 Offset
Weld Draglites 15X8 w/ 26X10 Hoosier Slicks
10.5:1 Compression
Clevite Bearings
Pro Comp Balancer
ARP Head Bolts
ARP Main Studs
Holley 750cfm Carb
MSD Blaster2 Coil
Moroso Radiator Cap
Custom Driveshaft
wow that would be fun!!!!!!! it would be a great sleeper if it didnt rumble like a drag car though.....id drive it happily!....imagine how embarassed a vette driver would be if was beat by a focus....well imagine how anyone would be (including Ls) if they were beat by a focus, well done whoever built it!
