- cold start engine knock?
- turbo v6 is alive!
- not an F150 but need help
- Fuel Mileage
- 2002 ford f150 electrical problem
- Thermosat surround sensor ??
- Rough/ Choppy start
- Lean Condition 2001 4.2
- 97 4.2l to 4.2l engine swap...
- 3.0L taurus Q
- Question about sel code. HELP!
- gas mileage
- Truck has been at the dealer all week
- need help truck is running like crap!!
- New alternator
- Coolant Problem
- low rpm miss
- F 150 1997 6 cyl oil pressure prob.
- ideal rpm for best mpg
- engine swap V6 for V8
- a few cranks in cold weather??
- can i pull a jon boat with my v6
- Noise from intake area.
- Water pump going out ???????
- IMRC Acuator ??
- v6 4.2l new body style performance
- Coil pack replacement
- cold air intake
- Vacuum leaks
- Rough Start
- Can anyone help me please?
- autolite copper plugs???
- Need Help Identifying a Noise
- 4.2L codes P0171 and P0175
- what can you do to a v6
- Needing some input
- Odo reading?
- 99 water pump problems
- New gaskets and problems. Need help
- Dealer Line Of Bull, Or Not?
- Still at it i'm afraid.
- 4.2 towing manuall tranny
- TRACK DAY!!! post your best track times
- Idle problem!
- 98 F150 2wd lifted
- intermittent rough idle
- Camshaft Position Sensor
- 04 heritage tach install?????
- Autolite Finewire Platinum
- What to look for
- Towing / Manual transmission
- squealing
- Something For 4.2 Owners to have "Just In Case"....
- help with 84 f150-300i6 hesitating
- V6 Swap
- is the 4.2 known to be a little noisy?
- Problem Codes
- Possible 5.3L kill?
- 2003 F150 V6 p0171, p0174, p1131, p1151
- gas milage?
- A couple of things going on here.
- V6 heater core hose
- Ranger with Misfire
- The van I just drove makes the V6 seem like the largest engine ever
- Supercrew in a V6?
- Rough Idle and Check Engine Codes
- Valve Lash Adjustment...
- Airaid intake for 08 4.2
- 4.2L Badges
- Ford trouble code 1401
- Where's the flasher? 1998 F150.
- power loss especially in overdrive
- anybody with V6 with 33's or 35's?
- engine rattle at shutoff
- 4.2 mpg?
- Evap codes
- 2000 4.2L V6 - Can it tow an Accord?
- Using coolant, not in oil.
- Overheating, help please
- Looking for massive powere gains for 4.2L!
- 01 Instrument Panel is quiting, what are my options?
- New throttle bdy question
- Water Pump issue, need advise
- motorcraft plugs
- Side exit exhaust
- Inline 6 trouble
- my issues!
- 1999 f150 V6 removing the starter problems
- World Record
- 4.6 Noise
- 2001 4.2 V6 Removal
- Check Engine
- Change the crankshaft pulley 4.2 v6
- I love my Truck Thread!!
- Rattle is killing me!!
- Can someone tell me what this is?
- Piston Slap? Valvetrain issue?
- just thought yall might like to see this
- Fuel/emissions line OK to use as vacuum line?
- Got a BIG problem... please help!!
- So how many of you?
- Water Pump Replacement Help.... w/pics
- V6 towing
- rough idle
- After market throttle body??
- progress
- Hp
- 06 v6
- Trouble with my engine. Any ideas
- Gauges Going All The Way Over!
- Flushing the coolant?
- DTC error code PO136
- Truck is at the dealer...
- How many mpg
- Truck quites when eng gets hot ?..
- Runs hot while towing up hill
- Ranger 4.0 troubles
- headers?
- another question- underdrive pulley
- electric fan?
- Engine overheated and Freeze plugs popped
- Wierd power loss under acceleration.
- Something is shady about my engine......
- Whining Engine
- Aftermarket Cam for a 4.2?
- Failsafe & overheating question (Blue Oval Fitter, are you online today?)
- Cold Air Intake worth it??
- F150 2000 V6 Intake Manifold
- Air Filter
- ljh
- bank 2 lean, bank 2 rich, and misfire... HELP!!
- what year is my engine considered?
- intake manifold issues and questions?
- Need help, truck won't start
- Fuel pump 3.0 taurus
- sport trac with 4.0 wont rev past 1600rpm
- Raptor's Port and Polish
- 300 straight six 4.9
- two questions
- EGR question - no vaccuum hose attached
- Heater Hoses
- 1997 f-150 v6 rear end vibration
- 4.2 died yesterday
- Raptor's efans!
- 2001 4.2l misfire ignition problems
- 1997 f150 2wd tick
- f150 v6 and ranger v6 gas mileage
- 2002 Ranger...P0171/P0174 Codes
- Chips, programers, V6
- How does this efan look to you guys?
- power loss
- Video and Picture
- Idle air control valve....
- 4.2 engine flush fixed it
- '97 Ford, trouble with starter?
- 2007 4.2 same as 98 4.2
- (part 2) engine stalling at corner
- HELP! diy injectors 2002 4.2
- Need help with a 4.0 Explorer
- engine stall at the stop corner
- Higher RPM miss
- 1999 4.0L v6 into 1998 F150 to replace 4.2L
- Older engine oil capacity
- 2000 4.2 questions.
- New guy and 4.2 V6 advice 2006 F150 STX
- Got trouble?
- Oil pressure problem?
- This could have been bad!!!
- What causes power loss?
- 4.2 V-6 bogging/power loss?
- Won't start for a brief moment...
- 1998 4.2 Engine Rec.
- 1998 ford 150 o2 sensors
- efan gains?
- 4.2l to larger - motor swap?
- 2003 F150 I6 low idle
- I would like to introduce myself.
- Stupid Wrench
- 4.2L using ALOT of oil...
- stuck coolant drain plug (block plug). How do I remove it?
- New Exhaust Flowmaster 44
- 2005 F150 v6 bumper hitch
- odometer problems! HELP!
- cant figure it out! HELP!
- MAF Location...
- Changed Alternator and the Fusable Link Cable blew!!
- P1504 & P1507 Codes
- reccomendations...
- low oil pressure
- 0-60 and/or 1/4 mile times for V6
- Idle Rough<~~~> After Swap
- 2000 Ford F150 4.2L ***Need Help***
- Engine Swap vs CPU
- Motor miss
- Engine Replacement on 1997 4.2l
- HELP! Engine wont start!!!
- new to me f-150
- AF1 CAI kit MacGvyer Limited Edition Mk II
- HUGE hydro-lock concern
- 4.2L V6 Engine Mods?
- 7 inches of snow and the good ole 4.2L :)
- PCM Help!!
- hell-of-a-day
- v6f150.com
- using coolant?
- No Compression No 1 Cylinder 1997 4.2l
- P1309 code.
- where is MAF sensor
- Rear main
- Po174 and Po171 is sometimes followed by po401 " solutions list"
- blown head gasket?
- Need better MPG... exhaust,intake, or tune? halo plugs?
- Running Lean
- rear differential.
- milky on cap
- 97 v6 ehaust ?
- knock sound when engaging/disengaging clutch
- Oil Pressure/Coolant warning light?
- Bad knock/popping sound in '97 4.2l
- Spark PLugs
- Washed Egine Question
- engine knock!!!
- coolant in oil / misfire on 2 and 3
- Oil pressure question.
- cruise control and gas mileage
- Even 4.2 swap
- Pulled codes-Where to start?
- MAF sensor
- last bolt on intake..back right WTF??
- fuel rail tool?
- 1998 F150 v6 4.2 Valve Lifter Replacement ?
- True or no?
- 97 coolent leak intake or head? best way to tell?
- 13 mpg average?
- V6 engine swap
- will headers give me more horsepower and sound
- 98 V6 Alternator Whine
- 4.2 V6 skipping
- F150 1991 strange problem warming up engine! Sputters!
- Mileage going to low teens...
- 1998 hydrolock question help
- 4.2L V6 strong enough for me?
- Ticking sound from new engine.
- Do 04 4.2s hydrolock also? What are their problems?
- gas smell in oil
- Camshaft synchronization
- Which lower intake manifold gasket to use?
- 4.0 will not start when cold
- Troyer 4.2 plugs & wires are in!
- 4.2 v6 vs. 4.0 v6
