- the tornados????
- No good deed goes unpunished!
- Windshield Wiper Stuck
- 4.2L vs. 5.4L
- Possible 'Leaky Gasket' ?
- 5 speed tranny
- Engine overheating after some time
- Broke my Maf Sensor!! Yay!!
- Grinding noise
- another engine swap question
- New but older
- ECU Swap! Dare to answer?
- Gatorback belt size?
- How many pulleys??
- Squeeling noise at low speed after replacing...
- V6 coolant question
- 98 F150 with 44,000 miles, time for tune up?
- Final head torque specs?
- OEM v aftermarket gaskets
- mine truck is slower then my fathers?
- hydrolock questions
- Fuel, MPG
- F-150 tachometer
- standalone engine management options?
- exhaust?
- Hydrolocked 4.2, repair or replace?
- The Infamous Coolant Leak
- Difference between two Motorcraft spark plugs?
- Engine Misses Under load
- 98 F150 build date, is it good or bad?
- NO start
- Noisy Door
- 4.2 general mods ???
- 02 F-150
- the chips????
- 4.2 to 4.6/5.4 swap
- power
- p0171 174
- Denso Plugs
- fuel pressure test
- need help
- 4.2 intermit problems
- split fires
- 4.2L exhaust... best bang for the buck!
- Pcm/eec????
- coolant from green to orange
- missing
- Getting some sound out of my 4.2L
- Remove intake manifold to clean EGR ports?
- Possible new head gaskets available soon
- engine code help!!!
- Avoid Sweet Deal on '98 4.2 Due to Gasket Problem?
- how much mpg's do you really gain with a better exhaust?
- Underdrive Pulley for 98
- Error Codes
- Dtc 0456?
- Po401 Egr
- what problems have you had?
- EGR ports?
- Fuel Line recall on 1997-98 f150
- air intakes?????
- V-6 Shift light
- Squeaky Cold Starts
- Power steering Vibration?
- Cylinder #2 misfire 4.2 1998
- MAF sensor location?
- manual tranny vibrations
- Replcing water pump
- Aftermarket Tach
- squeaking noise after warm up
- Truck... update
- Steering squeal
- 300 running weird
- V-6 Chips
- Im considering buying a 99 4.2 liter v6 f-150
- !984 Ford F-150 Inline Six 3 speed Manual Tarnny
- Engine Tune Up
- Radiator Coolant Drain and Refill
- Fouled Plugs...
- Hurst shifter Part #'s???
- Cleaning intake ports in heads
- Southern V6 Ford Challenge fast approaching
- What Should I do?
- More Power!!!
- 96 F-150 4.9l
- 2000 F150 question
- Spark plug wires
- wheelbase
- Check Engine Light...newbie
- 2001 F150 4.2 trouble code
- solenoid
- 2003 F-150 with the darn 4.2
- P1447 "ELC Flow Error" -- help please?
- Hydro lock 97 4.2
- Vibration at idle
- excessive shaking with acceleration - HELP
- New 2002 f-150, what to do
- CAM Swaps
- What is this little finned cooler...?
- Dash Mileage Reset Button
- 4.2 blowup prevention -- same as "engine" post
- blinker/brake light issue
- Motor gone....
- Fuel Filter Change
- Cheapest oomph!
- the flowmaster??
- Stumble while idling...?
- Problems with the truck
- oil pressure
- the term "uses oil"
- serpentine belt replacement
- Pinging (detonation)
- 2001 4.2l V6
- Motor oil weight change?
- camper pulling
- Engine stumble and trouble codes
- Ive seen lots of coolant leaking problems this week.
- Headers?
- Newbie needs advice!!
- Anybody think I'm crazy...
- Help Needed
- New Titan
- What's involved in changing rearend pinion seal?
- 97-02 F150 Ld
- Kill list
- Need Help Please read
- f150 mass air sensor
- New Spark Plugs ?
- Heater Core Instructions, Tips, Do's and Donts
- Parking Brake Cable Relocation
- super 40????!!!
- Need help with AIRAID
- Engine misfire
- Signs of EGR sticking...?
- 1998 Grill Guard / Headache rack
- 5.4 engine coolant drain plugs
- Chip and gears or cam?
- 2000 4.2L V6 Coolant leak
- leaking/noisy Exh. manifold?
- 1998 4.2L Cold Clunk
- Drain plug bolt size
- Extra Engine noise when serpentine belt is on.
- screeching noise when engine is cold
- 99 4.2 suggestions
- V-6 Gas Mileage
- suspected fuel pump problem
- Supercharging and removing IMRCs
- V-6 Diesel
- Intake manifold runner control
- Ram air hood
- Gatorback belt Part #?
- Ticking noise when just started up and put in reverse
- Hopefully the last time I will ever ask for help! Hah!
- Question about cleaning MAF
- MAC headers
- 5 sp V6 towing
- 1998 V6 with 1/98 build date going to have leak problem???
- rough start
- 2002 V6 in a 1997..Possible?
- flashing check engine light/running poorly.
- Studded tires
- Body moldings
- egr valve location
- rough idle minor shudder
- lower intake manifold gasket
- V6 Ford Challenge Race Series OFFICAL CHAT
- Throttle Position Sensor
- rough running new engine help
- Oil Question
- Front cover crank seal
- egr question
- Need help ASAP please
- Odd sound
- 3 months VS 3K miles
- 4.2 V6 Horespower
- No Clattering
- how to get better gas milage???
- Harmonic Balancer
- V6 stock tire/wheel sizes ?
- Automatic transmittion problems
- Supercharged 4.2 Video
- High rev with Defrost?
- Loss of Power In 4th/OD
- V6 horsepower numbers with Upgrades
- Help with engine
- most miles
- Correct Spark Plugs???
- build date
- V6 turbo
- Ported Heads on ebay
- 99 sport 4.2 FOR SALE
- What's the best air filter ?
- cam?
- New F150 Owner
- Can't find wiper blade refill replacements
- Who's had the most miles ?
- RPM Dip at idle
- OK, I did it....replaced worn out 4.2 with late model 3.8
- Need Help !!!!!!!!please
- runs rough
- Hesitation
- broken truck, pls help
- V6 shudders at speed...sensor issue?
- Oil Leak?
- 1997 F-150 4.2L on last leg
- 90,000 mile problem
- PCV Valve?
- 4.2 engine replacement price???
- who has the best exhaust!!!1
- 04 4.2 heritage
- Changed plugs and wires now runs like crap
- tranny out.. any preventive maint. sugg
- Underdrive Pulleys???
- 4.2 v6 chewing up plugs
- how much horsepower is possible?
- couple of questions
- girl with quesiton
- some vids of my truck
- occasional rough start
- Maintinence?
- Got a prob with my F150 and ABS...
- 4.2 L V6
- 4.2 oil guage bounces around
- Stock Horsepower?
- 4X4 Won't lock in
- Well, my 4.2 finally got bit!!!
- traded in
- P0402 Code
- Engine code?
- super chip vs. diablo?
- T-Bird Eaton M-90 S/C on 4.2L?
- any advise would be appreciated
- intake
- what do yall think will it have a nuf power
- loud pipes save lives
- clattering sound
- Gasket leak finally got me 2
- 4.2 hauls pretty good =)
- GAS MILEAGE ?? v-6 ??
- Vibration
- How to change serpentine belt.
- Picture of 4.2L?
- Tune up on 4.2L
- I killed my V-6!
- lightning exhaust on 4.2l
- Wierd Clicking Noise
- Reset CEL?
- misfiring at all RPM's
