- 4.2 y pipe replacement
- Success!!!!!!!!!
- What are underdrive pulleys and e-fans?
- Intake gasket question
- Ok, how do you?
- Cruise control question
- How much should I ask for this V6 truck?
- Piecing together aftermarket CAI
- Check Engine Light
- Leaking head gasket I believe
- Turbo?
- Pull engine or engine+trans
- V-6 a piece of crap?
- Starting Problems=2000 4.2L
- 4.2 w/ 225,000 finally drinks the antifreeze
- 4.2 6 cyl maintainance
- 99 F-150 Hauling Capacity
- Can you believe?
- problem with rpm
- 4.2L with AF1 intake and superchip combo?
- oil pressure
- Need diagnosis opinions 4.2L 130.000 miles
- how i disconnect the wiring harness from the MAF
- Tried to search for it honestly...
- Fuel pumping from one tank to another
- Repower from V6 to V8?
- agitated
- pcv location 4.2
- 1998 f150 4.2L squeek/squeal
- odometer gremlin
- V6 questions
- P0172/P0175 Codes
- Is there such a monster as a V6 supercharger?
- What makes 4x4?
- Breakin Period
- Miles driven before first tune-up
- Eaton M90 "kit" for sale in classifieds
- computer diagnostics
- engine code po443
- My 98 4.2L IS BROKE PLEASE HELP
- V6 with 5 speed - trans fluid
- injector upgrade
- PVC filter mod...pics
- 98' 4.2 noise
- Will the 4.2L V6 have enough power?
- Power window problem
- E-fan
- How do I clean the EGR
- truck shuttering when driving
- Ground Strap - Firewall to Engine, Help!
- A V6 Airaid? Bad decision?
- Ethanol with you gas
- confused
- Block Heater Install
- valve question
- sometimes “rumbles” or vibrates
- Intake Questions
- Drove '05 F150, Not Impressed
- 4.2 to 5.4L Swap Writeup Needed!
- 98 4.2 towing capabilities?
- 97, 4.2l problem
- 98 V6 engines.
- Bosch spark plug wires
- OEM or aftermarket? What is better?
- Ford repair DVD
- '97 F150 4.2L V6 Hydro-Lock Kills Motor
- Troyer plugs and wire.
- Best performance upgrade for a 92 V6?
- Annoying Rattle
- Alternator?
- 98 F150 4.2 V6 Idle problem
- Question on afermarket exhaust.
- after market tach
- PCV hose question
- Missfire in V6 please help :(
- Check engine light
- I need some help, please.
- LPG is it a good option ?
- sunpro tachometer
- burnout
- GearShift
- electric a/c compressor
- Stop leak added, problems
- a/c vibration
- New Parts = lower mileage?
- possible tps problems
- dash \ instrument panel problem
- How to Change tensioner pulley?
- Cruise Control Quit
- 2003 4.2L AC - Can we unhook?
- 2002 Stumbles after tuneup
- Engine Swap?
- any one fuse diagram
- terrible gas mileage....
- DPFE valvue bad. does that equal bad gas milage?
- driveshaft '99 vs. '98
- Exhaust ?
- Oil Pressure Issues
- Truck stalled and still trying to figure out what is wrong
- Burning oil!!!!
- Should i change over to synthetic oil?
- 81 f100 engine specs and questions
- Where is the AC recharge valve on a 4.2L?
- Engine Stall with no warning will not start
- Engine and Tires
- Poor throttle response.
- Whine in the engine
- Replaced Batt Now Guages Gone Haywire
- Check Engine light/misdirected air from vents
- P0171/P0174 & Engine won't start.
- Strange noise
- flows
- 97 Idle/misfire Problem
- Driving Thru The Flood
- synthetic oil?
- missfire help
- Bad knocking noise, can anyone help?
- Mercon for 5 speed.
- Add cruise control for 2002 F-150?
- Where does this wire go?
- What seal is this?
- driveshaft repair/replace
- erratic engine vibration
- need help with exhaust
- Got my 1st check engine light today.
- Mechanic kudos
- 2005 4.2 v6 questions
- Torque values for bolts for lower intake manifold?
- Terribly annoying sounds
- Camshaft Synchronization / Timing?
- Cat Punch-out?
- Any recommendations for repair books?
- Tranny flush
- what is the stock HP and TQ ??
- PCV pulled/popped out of valve cover
- 97 F150 4.2 rough idle / misfire
- 4.2 lower intake, fuel injectors, rail, regulator on ebay
- Throttle Body
- 4.2 Cam Position Sensor and Synchro
- need help fast!!
- Blew out a sparkplug last night....
- Losing coolant,again!
- def maf sensor
- gas prices = love?
- Mirror polished Throttle body
- Stock air filter
- Help with OBD Code
- Qestions about maintenance services by dealer
- tachometer range
- more problem 4.2l
- P0340 Camshaft Sensor Malfunction
- 00 4.2L v6 Ticking Problem!! HELP!!
- Supercharger info on the 4.2: The old one needs to die
- 2001 F120 2WD Questions
- Troyer Underdrive pulley
- Drop pan without pulling engine?
- What size is my rear end?
- rear gears
- More F150 Frustration
- steel bumper
- help
- 4.2L Cam Sensor Synchronization
- 05 4.2 Horrible Gas Mileage
- Took off the muffler
- 4.2 problem
- What is IMRC?
- O2 Sensor Brands - Any Recommendations?
- Brakes
- 4.2 engine stumble?? AGAIN
- cylinder numbering for '98 4.2
- Air Intake Silencer Mod
- What are these things???
- flywheel ring gear help
- i need help
- What's going on??
- maf from an 8cyl work on the 4.2?
- Where is the MAT sensor on a 2002 4.2L V6
- 98 V-6 w/no engine temp control
- 97 4.2L intake gaskets
- Rough Idle, Engine Dying, no start and CEL Fixed!
- engine oil light on and off
- pcv vac. leak?
- Just bought a new 2005 F-150
- Twin Cold Air Intake System
- Spark Plugs
- 98 150 4.2l hesitates BADLY-please help!
- Stalling when clutch hot?
- Cut Outs and Cat's!!!
- exhaust for my 4.2
- Gas Tank
- Tach Installation
- problem with my xlt 97
- 4.2L 5 spd grinding into 3rd
- 4.2 Eaton blower... Coming soon!
- hesitaition off the line?
- Ford Service Manual Info please
- disconnect fuel line
- Service Engine Soon light On!!!
- 4.2 v6 noise from engine then no AC
- po153, p1151
- '02 Intake Problems
- exhaust help 4 new member
- How-to articles that may answer your questions.
- Fixer-Upper
- I Need a good sounding cat-back for my 4.2
- Emergency!!
- Wont start
- RPM Redline on V-6
- Missing FYI
- Lower intake gasket
- Dual Exaust Help?
- P0117 codes
- coolant temperature sensor replacement
- 2001 4.2 with P401 & P402 Codes...Help
- DIY manifold gasket replacement???
- Need some help
- Starter help please??
- p0303, p0304
- Idle Issues 03 F-150
- Fair price on Intake repairs
- 4.2L Throttle body
- Flashing overdrive "off" light, 2000 F150 4.2L auto
- A little project
- More Horsepower!
- I got the shakes
- Loss of Acceleration/power
- 97 4.2L Leaking Gaskets Issue…Revisted
- Ignition ?
- Crankshaft Movement
- clattering noise
- gas milage
- What am I looking at?
- Gas prices!
- PCV Stupidity Causing Low RPM Engine Stumble
- Trouble in the manifold!
- Problems on RE-start
- P0171/p0174
- Headers & Dual Exhaust
- Cold air intake
- Maf cleaning
- headers for 4.2 ltr 97 f-150 2wd.
- 4.10 swap
- how to break the glasspack????
- P1520 code
- 1998 F 150 with 4.2L V6
- magnaflow or flowmaster?
- 95 300 inline 6
- Problems Starting..sometimes
- Service Engine Soon - P0401
- Anybody run a si/so Magnaflow muffler?
