- Poor Gaas Mileage!!
- Installed new Motorcraft plugs
- Plug Wires
- 1997 F150 replace oil pressure sending unit
- Chips for the v6 motor?
- 4.9 specs?
- Yet another hesitation thread
- v-6 is dead...almost (Long)
- F150 no more
- weird surge when cruising
- Flowmaster 40 vs. 50
- oil pressure switch (sending unit)
- Fixed a surge at idle
- still have rattling noise
- Towing Capacity
- V6 Engine miss!!
- Antifreeze leak very hot in oklahoma need help with some questions
- GIBSON vs MAGNAFLOW
- BlueOvalFitter...(Motorcraft "Finewire" info)
- Help! Running rough after plugs/wires change
- Intake Question???
- Sparkplug wires...
- ? on new exhaust
- running hot???????????????
- Engine Misfire on 3 cylinders
- electric windows f150
- ? on fuel filters
- rattle noise
- frontend Vibration and squeak from left front.
- To clean or not to clean inside the throttle body?
- Questions ,questions, and more ?????
- V6 with electronic fans
- new plugs and wires
- needing new cats
- 2006 V6 Top Speed...
- Has my 4.2L started using oil?
- Oil change turns into $800.00 bill
- Tune Up kit Worth It?
- PCV Vavle Replacement 2000 F150
- Help! AC acting wierd!
- Shifter
- 96 v6 dies 5min after running daily
- Where is a good place to get a remanufacture engine for F150 1997
- real coolant temp gauge
- cutting off cats
- 92 f150 v6 swap to v8
- oil capacity
- '97 4.2 Throwing P1151 Code, Need Help Please
- Codes P1537 & P1538
- What happened to Mr. Bentwrench?
- Tuner for a V6
- Fuel delivery maintenance
- Please review my 4.2 litre posting under "engines"
- 2000 F150 Tensonsioner Seized?
- Super Six Motorsports
- 99 f150 4.2 6cyl. overheating under load
- fuel leaking all of a sudden...
- Does anyone have a performance exhaust on their 4.2?
- Jumpy idle
- Running Rough constantly - oil on plugs after removal...
- 4.9 smog removal / catalytic conv. removal, help
- Trying to figure out my rear-end gear ratio
- anyone here forged?
- Header
- Finally fixed hesitation problem!!!
- Question about towing capabilities...
- temperature blend selector
- oil pressure problem
- P1400 code.
- Traded the 1997 4.2 for a 2006 5.4
- 1997, v6-4.2 cyl 2 missing
- Engine making tapping noise?
- 4.2l egr valve location
- Delete this...
- My '99 F-150 has problems
- Ram air
- Rear O2 sensor Q's
- Harmonic Balancer Broke in two!
- milage question
- SC or a TBC
- K&N Filter/Intake kit for the 4.2
- Quirky noise after changing serpentine belt
- Spintech??
- Jumping engine
- Chip or Programmer
- Cylinder 5 burning antifreeze, must be the head gasket?
- Need help 1990 4.9L straight six (missing head gasket)
- Tecnical Help for the mechanically impaired
- timing gears
- 4.2 v6 towing capacity
- Would you buy this truck?
- still have the service engine soon
- Spark plug wiresets, suggestions?
- Startin problems
- Aftermarket coil/ignition for V-6
- replaced intake gaskets
- Will this work
- Where is my IAT (intake air temp) sensor/sending unit?
- Fel-Pro or Ford Gaskets?
- Pictures from DIY intake gaskets?
- Need info on f150 before buying
- Well where too from here?
- Problem w/ friend's '98 V6
- V-6 4.2 Hesitating while accelerating?
- rattling...whyyy?
- Another P0401/0402 Problem...
- 4.2 with the Troyer tunes
- Went fishing and have trouble
- 88tbird 3.8v6 changing head gasket...
- Spark plug change without removing wheel well?
- carfax report
- "New" Used Truck
- oil loss in less than a minute
- HP/MPG Bang for your buck?
- Oil pan gasket/spark plug help
- AirForce One & the 06 4.2ltr.
- p0104 code please help
- Truck runs slow after oil seal and clutch replacement
- mpg...so close
- v-6 tach
- Help with overheating
- Oil getting black in 4.2L?
- Ticking Noise only when Accelerating
- Post Ur 1/4 Mile Time...
- L6 Mods
- yet another intake gasket question
- 2 questions
- Deer Encounters
- Recall Ford Cruise Control Fix?
- Engine ?
- V6 owner
- Sorry to go
- 1997 f150 gasket issues
- 1998 Maintenance issues and value
- converter
- Help...Engine Miss..?
- Truck comes out of storage after 2 years
- Help me figure this out
- Mis and fault code
- Hydrolocking??
- 4.2L "Ticking" sound
- P1537, whats involved?
- $5000 for new motor...DAMN FORDS
- Any mods to speak of?
- rear axle shaft
- Please help with 1997 4.2 v6 issue
- Worth it or not??
- Im4uva
- rev limiter?? red line on 4.2???
- f150 xlt value
- Transmission - I need some help from people who know
- No Spark
- Lazy valve spring
- Abs Light
- i need help
- 1997 4.2 v6 oil capacity
- Gears
- Supercharger-04' f150 heritage
- How much gas??
- Shakin
- need help
- MAF sensor question
- Southern V6 Ford Challenge
- programers
- Are new Motorcraft fuel filters supposed to come with red caps?
- XCAL2 on 4.2?
- Governor problems on lifted 4.2
- I need a DPFE, where can I get the best price?
- Losing antifreeze?
- steering gear shot?
- 98 F150 wolnt idle will not go over 25 mph
- What in the world just happened???
- Intake mod filter?
- Stock V-6 not underpowered!
- 4.2 Intake Gasket.....
- Code 0456
- p301 Cylinder 1 and 5 Misfire
- Airaid Install!!!
- EGR Question
- Goodyear Drive Belt
- Drive Segment?
- idler pulley torgue
- 4.2L Idle problem
- vacuum problem
- Anyone have an extra bed rail cap i could buy?
- engine swap (sure yall have heard this before)
- Hesitation during driving?
- Question on Seafoam.
- 2006 4.2 air intake
- Looking for a pictorial step by step method of cleaning EGR valve
- 4 cylinder ranger
- Trouble codes
- Low oil pressure after long idle
- Thoughts on 2002 4.2L V6
- Need Help with Coolant Lines on the PCV
- How does the 4.2 stack up against the other V6's?
- Just fix your 4.2
- P0171 error
- My V6 mods(future and now)....
- potential problems i can look for
- Ticking and warmup
- 1998 V6 F150 Hydrolocked!!!
- V-6
- Jet Vs Hypertech!!!
- Idle?
- Clutch and pinging questions.
- where to find replacement cat conv for 98 4.2???
- Changing out my COIL - 1999 V6 4.2 liter
- my 4.2 needs help....
- Did my v-6 just bite the big one?
- How do I know if PCM is working???
- P0174 code where to start looking?
- Why is it hard to believe that a V6 can be fast??
- Rough going - 1st and reverse
- how fast does a v6 go
- Pic of my "Bully" nerf bars
- Power Steering / using brake fluid
- Ur Chance For Hateorade
- Oil leak
- 2002 4.2L V6 Intake Gasket Replaced
- 4.2 L V-6
- Can u go faster, than stock cutoff speed?
- Tachometer installation on 2006 F 150
- This is how a magnaflow muffler sounds on a 4.2L V6.
- V-6 Is A First Rate P.o.s.
- What size rear?
- MAC Air Intake V6
- Rancho RS5000
- Engine Shutting Off
- Need help, winter taking toll on truck
- Down stream O2
- 2006 V6 4.2
- squeelling noise!
- 4.2 owners unite!
- Whats your mileage w/ 4.10 auto
- PVC valve
- HID lights??
- Mileage help???
- Flashing OD Light
- Replacing oil pressure sending unit
- Constant Airbag Light-no codes, no blinking
- Check Engine Light
- Codes po171, po174, po1131?
- My son, My hero
- Question for peacemaker....
- Coolant change by shop-distilled water?
- 99 V6 Breadown
- Tachometer Gauge
- 4.2 spark plug/tune up
- Where's the fuel filter?
