- This the right stuff to clean MAF sensor??
- 96 f150 4.9 bogging
- Starting problems on 1990 F150
- new guy with weird question
- starts and stops 90 F250 6 banger
- Check this out:
- New engine?
- 98 V6 4.2L I'm ready to trow in the towel
- Bad Ping
- Autolite Iridium (xp5144) spark plugs work well in our 4.2 litres
- 2002 4.2 Weird Stuff Questions and overhaul cost
- Anyone Doin Airbox Mods??
- help!!!!
- 2003 4.2l Speed Control aka cruise control
- I Wanna Go Fast!!!
- What The Heck Is That Noise?
- Low Oil Pressure
- Serpentine belt replacement
- Whats this problem?
- Heavy duty Rad
- Well I moved on.....
- 4.2, Engine rev's high coming to stop
- problems with the 4.2?
- Replacement engine oil dipstick (broken tip)
- Finding TDC on 97 4.2 w/o removing frnt cover
- Trouble Code
- 2000 engine stutter at acceleration only
- Add me to the list of 07 6 cyls
- Power stutter & service engine soon
- Auto to Manual
- I got a new 2007 F150!!!
- V8 Swap???
- '05 Dying at stops & while driving
- batt dying.
- Horsepower
- cam sensor sychronizer
- Bad miss/shudder
- spark knocking
- 3 & 6 cyl. misfiring need lots of help
- 97 V6 Rear Axle Ratio Change 3.08 to 4.10 LS
- adding tach cluster to 98 4.2
- v6 5speed 4x4 guys
- My new 2007 F150
- fuel mileage is down
- new to the forum
- 4.2 l V6.....4x4?
- Running lean
- power steering noise
- Is There A 4.2 Supercharger???
- 3.8 & 4.2
- 07 XL 4.2l.
- whats the problem
- cold start high idle
- need help with hesitation?
- EGR Feedback sensor
- v6 exhaust setup
- 99 Xlt 4.2l-v6 Stalls @ Acceleration
- how many miles?
- Troyer Custom Chips ?
- Exhaust Headers or Electric Fans
- obd2 codes
- 4.2L dyno run!
- Help please
- P1151 - Which O2 Sensor is bad
- still missfire
- header advice
- thought i had it fixed
- rear main leak
- EGR Valve
- Does this thing tow?
- 98 4.2L External Knock
- Just bought 07 F150 w/ V6 5spd: need advice!
- Ohms Specs for 4.2 ingition coil
- Yet another 4.2 misfire thread
- yes or no ?
- 4.2 poor mileage
- Trouble codes, Help
- 1997 F150 4.2 to 4.2 swap
- 4.2 Engine Stutter?
- Should I cut my losses with this truck?
- First oil change...
- one more time folks
- Rebuilt front end
- 4.2 needs help
- MPG v6 4.2 and v8 4.6
- does 4.2l have any power?
- break-in requiered?
- air intake for 04-06 F150 V6
- New Muffler and tips installed
- Do I need to pull my engine out to repair?
- EVAP system
- electric fan & pulleys
- 2006 4.2L air intake system.
- Troyer ignition kit?
- Check engine light
- Towing across country
- Has Ford paid for any hydro-locked engines
- Engine Block Heater
- What's good first?
- P1151 Code Trouble
- Info on replacing harmonic balancer 4.2L
- Is this common??
- pic of supercharged 4.2L check it out.
- Lots of 4.2L Perfmonce mods. check out
- better MPG
- shop manual ?
- v6 mods
- Missfire Question
- rebuilt 4.2 won't turn over, mechanic says need at least a 750 cold cranking amp batt
- '97 4.2L start up problem
- 4.2L V6 Missfiring
- Gear Change for Towing
- 4.2 miss popping
- My 4.2 V6 Has a Miss
- ford spark plug torque
- PCV vs. breather?
- V-6 Intake Dillema
- 4.2 knockin like crazy!
- how many horses on v-6....
- 05 4.2L Upgrades/Modifications
- k&n air intake on v6????
- Exhaust sound clips
- Stupid Emissions
- Brakes
- Superchips 1714...WHAT IS THE DEAL?
- Weird noise when I "floor" it
- Is the 6 inferior to the bigger 8?
- Tapping
- Locating O2 sensor
- 4.2 Help
- 1985 6 240.000 mi Engine orig
- Engine Posessed
- 4.2 help please
- Towing with a V-6
- Blown head gasket, motor knock, 4.2L w/ 100k miles
- V6 power
- 5.4 misfire
- 4.2 misfire / miss / spark knock when warm
- Gaskets
- power steerting seal on hose
- 1996 Explorer w/ 4.0
- Engine working too hard?
- How do I change PCV? ('99 4.2l)
- used oil analysis
- 06 4.2 Options
- fuel problems
- Improving gas mileage - and some other general questions
- Howdy
- Starting Problems
- Need some HELP
- Dtc P1131 & P1151
- Motorcraft parts wholesaler
- New Jasper motor in
- Want More Power!
- Oil Gauge
- Ford dealership just hydrolocked my engine
- Sources for new motor
- Should I replace the motor?
- milky oil cap
- Having my differential rebuilt
- Starting Problems
- Temp Sensor for the ECM
- Intermittent overheat when it is cold
- 2003 4.2L V6 / 2005 4.2L V6. Whats the Difference?
- Noise in front end 2001 F-150
- idle issue?
- This may sound dumb: Where the heck is the horn?
- Cat. converter failure after 6,000 Miles?
- O2 sensor location?
- Towing Bass Boat with 2006 F150 XL 4.2 3.55 auto
- for all v6 guys
- Past 15mph/2k rpm, grinding noise
- Borla?
- just got my trouble codes help please
- California 2006 f-150 4.2 needed for AirForceOne Fitting
- "big 6" needs a boost
- Do I need a T-stat
- 1995 f150 I6
- Cold Air Intake
- IAC Valve
- MPG and average costs?
- Plug Wires
- y pipe and cats
- First F150 upgrades
- Torque Specs needed
- Harmonic Balancer sleeve cracked off, how to remove?
- More HP for V-6...HELP...
- wanting to make V-6 faster
- Idle Control Valve
- Engine Date Code
- List of trouble codes for the 4.2L V6
- 97 4.2L- Rough start question
- ? on code
- 97 4.2 power steering out? doesn't seem to be pump
- Fuel starving @ low RPM's???
- Hows Oil getting outside the plugs?
- Fuse Diagram
- '97 f150 V6 Oil Pressure problem
- dpfe location....exactly
- 1998 4.2L Question
- Rattling sound underneath truck.
- 96 Inline 6 Surging
- 0-60 time
- 95 4.9L F-150 4x2 coolant issues
- 4.2 running extremely odd
- Towing a motorcycle trailer
- My New Truck
- No Power!!
- Camshaft position sensor
- 4.2 oil dipstick tube
- Damn...
- Yes, its possible!
- truck running too lean
- 2001 F150 EGR Valve Question
- Throttle Body Question
- Another Ranger Defector Here
- Oil seepage near valve cover on `05
- Engine Swap Possibilitys?
- Basic upgrade
- Heater Core
- P102 MAF OBD Code
- Horrible gas mileage????
- Gas mileage update
- af1 intake for 05-06 (new body) ??
- Stock Cluster W/o tach for Stock Cluster W/ tach
- Check Out My New Truck!! It's A V8 Triton.
- 2002 65K Maintenance List?
- Thinking about new 150 with v6
- upgrade vs. stock brakes
- Who makes a supercharger for V-6
- How To change clutch
- seafoam?
- 2001 XLT Getting better Gas Miliage?
- '99 F150 Engine Will Notstart
- F-150 Engine Miss
- Truck won't even crank over
- Where do you guys take your truck to get plugs and wires changed?
- More Torque
- Oil pressure
- Egine acting up
- Bad coil?
- Cold Air Intake
- Hanging RPM's
- Need to know what you all think?
- Air Intakes
- how much hp?
- 99' Identify Noise
- 2005 v6
- propane??
- Muffler and Filter?
