- Where do the HVAC vacuum lines go to?
- 1999 f150 xlt no heat
- weak blower output?
- Heat Question
- Blend door replacement with pictures
- AC/Heat question!A way to test the Blend Control Switch?
- Heat on my work van doesn't work well
- I replaced my blend door and heater core. Happy ending!
- Vacuum diaphram info. Please help
- ac/heater fan resister
- Heater core/blend door replacement questions
- A/C on all the time
- Random Heater Operation
- No Floor Heat Or A/c
- 98 F-150 heater problem
- 98 F-150 little or no heat
- exhaust fumes
- Rear A/c
- A/C cycling on and off - couple questions
- Heater core advice
- Repaired my blend door control motor 2000 f-150
- Blend Door
- 02 Harley A/c problem
- Auto Climate Conversion
- EATC - Only through defrosters??
- 89 with A/C problem
- Replacing HVAC Blower Resistor on 2001 F-150
- Heating coil
- Automatic Climate Control
- New compressor louder than original. Normal?
- Bad Bearings...
- HVAC question
- Thumping noise from HVAC
- 97' f150 HEATER CORE REPL/DASH REMOVAL
- hissing sound comming from control panel
- A/C Hissing sound
- Rats or mice...it's one of them
- bad compressor?
- Bad compressor?
- Gauges
- EATC display problem
- When does the AC compressor cycle?
- Problems with a/c blower motor- ideas????
- AC losing freon
- Where to check/charge A/C? 4.6 liter
- A/C only blows thru the defrost vents. 98 F150
- Flame Grilles - Effect on A/C and Engine Temp
- Weird sound only when using A/C????
- 1997 Expy-5.4-A/C stops blowing with acceleration???
- Hvac
- Rear Air Conditioner
- EATC not working
- Blower doesn't work
- Restriction in system?
- Is a compressor hard to replace?
- Retrofit Blues
- A/C Help: Clutch or Compressor?
- Change Standard AC Contols To Automatic
- Missing service port cap. please advise
- A/C Upgrade
- Do I need a recharge?
- 2001 SCrew needs A/C Recharge - something I can do??
- Orifice Tube Location / Compressor Question
- A/C noise...
- Cabin Filter...Location?
- A/C question
- A/C Compressor Blues
- R12 to R134a -- How to do it??
- brand new Screw, blowing warm :(
- Buying A/C parts online?
- 1993 F-150 5.0, what A/C system?
- 05 F-150 A/C click noise
- AC system diagram
- Automatic climate control - leave on or turn off?
- Need AC help for 2000 F150
- Help with A/C compressor
- Cycling switch question
- HELP!!!!! AC Problems -on vacation
- Supercrew HVAC vacuum line lose in firewall
- Cabin Air Filter
- Bad Evaporator '01 F-150
- AC clutch replacement diagrams
- A/C Shuts off at WOT doesn't come back on
- Need Help. Engine miss/hesitation with A/C on?
- 70psi on Low side?
- high side ?
- F250 KR not cold at idle
- 93 F150 blows thru defroster
- A/C vent temp ?????
- Loose vacuum?
- water in passenger floor
- Compressor Running Constantly
- HVAC Fan Control Failing (Burning Smell)
- Heater Core - Help
- low side ac pressure is high
- A\C Warm under Heavey Acceleration
- AC Gages and Vaccuum Pump
- 99 F150 blows thru defroster under acceleration
- '97 F150 A/C clutch meltdown (4.2L)
- Heater Coil Leak
- Vacum leak
- Where did all this oil on my compressor come from?? this cant be good
- AC compressor trouble: many questions
- '05 FX4, A/C out
- Recharge Didn't Work; Now What?
- Antifreeze smell after shut down; 2005
- how many cans?
- Question.........strange A/C behavior?
- Stinky Air
- Orifice Tube?
- NO air
- 1996
- Max AC Does not Work
- AC Clutch Rebuild
- yet another ?. System empty, then oil or no oil?
- added 134 and still not blowing cold
- 2 Trucks, Same Problem
- No pressure, I think my kit is defective.
- Blower wont turn on umless I Beat the dash
- what guages for DIY r134 recharge?
- Leaking Heater Core???
- AC-system Pictures
- leaking compressor??
- Oil type?
- compressor or clutch?
- Going to attempt to recharge it....
- A/C problem need help......Thanks!
- A/C Question - 99 XLT
- 98 F150, 111K miles, AC recharge question
- Details on Charging R-134a for '99 F150
- Cabin Air Filter?
- 01 screw ac cycling hot and cold
- a/c only blows cold while stationary
- AC cycling off
- Heat Won't Turn Off!!!
- '05 Hissing as A/C Cycles
- 03' F150 Supercrew A/C blower
- R12 or R134a
- Help Please!!!!!!!
- 97 F150 Ac Smells!
- 4.6 vac leak
- Dust in vents
- Heater control
- stuck on heater core replacement
- 1999 F-150 heater/ac control knob
- '04 A/C: Anything New?
- low pressure switch
- Can someone answer a few Q's?
- ac/ defrost shutting off engine?
- Stupid AC won't even come on :(
- A/C Compressor Replacement
- I know this subject has been beat to death, but.......
- vacuum schematic
- Vent Temp when NOT set to Auto
- air conditioning coming thru defrost vents only
- f150 v6 condenser
- In the owners manual...........
- heater core
- Factory or Dealer installed A/C
- AC out
- 99 F150 Heater Problem Fixed
- Heater air output
- A/C switching vents!!
- Electronic HVAC cutout
- Heater Core and Electrolysis
- Oops I forgot to add something!
- Which one could it be?
- Another Heater Core Success W/ ???
- how do u burp a coolant system?
- isolating a vacuum leak
- Adding Rear HVAC...
- Heater Core Insulation Foam
- Amount of air from heater/ac
- trapped air in heater core help
- Rear A/C Question
- water trickling sound
- Internal diamater of heater core hose
- Question for IndyEng or any else who can answer it
- A/C Temperature?
- Another heater core question...why not just take it out?
- Heater core quality issues
- F150(97) V6 heater box
- Big Smoke
- blower speeds flux in MAX a/c
- Help! No air out of Panel
- Swap standard climate control with factory digital controls?
- How does the HVAC system work
- Geeze, my heat sux...
- Why Did My Blower Motor Fill Up Wth Snow?
- Heater broken - not a thermostat prob
- My heater isn't working
- heater not working
- 98 F150 HVAC problem
- heater problem
- A/C comes on with defrost?
- A/C shut off
- Compressor cutoff at ____ RPM mod....
- Heat goes On then Off!
- Cooling System Problem
- water pump
- groaning at shutdown?
- Expedition A/C Cycles with Accelerator
- Cabin Air Filter- 1999 F150
- Help! Receiver/dryer connection at firewall
- AC compressor running with heat on
- temperture not working on heater
- Dash Squeal
- Heater and Idle
- Heater not working correctly
- Replacing Blender Control actuator?
- Temp control not working in Climate Control
- Problem with Defroster
- help finding the fan resistor on Excursion
- Blower Motor Access
- 1997 Heater Core R&R with Pictures
- FPO AC controls...
- Heater Core Clog?
- Is a special tool required to replace compressor clutch??
- hvac problem
- No Defroster...
- HELP...Yes I did the heater core myself...
- Panel air intermittent
- you guys had me scared. (heater core)
- a/c orifice tube location 97 expy
- Radiator Smell
- No heat inside.
- Rear A/C conversion
- Water is leaking from???
- 92 F150 Blend door problem???
- Rise in RPM with heat on
- heater core
- Inconstant heat?
- Wheres my heat and air conditioning?
- thermostat install
- heater core replacement
- Two Questions
- weird coolant system
- Help again...
- Another Heater Core Veteran
- heater control switch
- 99 F-150 Supercab heater problems
- I've nearly got it!!!
- AC Noises
- Rough Idle When Heat Is On
- What are the steps to recharge A/C?
- Another Heater Core Replacement Question..Not dropping hte column?
- Cannot spin new AC compressor manually. What gives?
- heater hoses at firewall
- Drink dispensor
