View Full Version : HVAC
Pages : 1 2 3 [4] 5 6 7
  1. 98 F150 airbag removal
  2. 1997 ford f150 heater blows cold air
  3. heat, a/c not blowing
  4. Blend Door Temporary Fix
  5. Fan speed - 2 lowest settings won't work
  6. How Do I heck the Blend Door for A/C Not Cold Enough?
  7. did the 2000-2003 f150 ever have???
  8. did the 2000-2003 f150 ever have???
  9. did the 2000-2003 f150 ever have???
  10. Heater Blend Door
  11. Help
  12. Where are the vent vaccuum lines ??
  13. A/C Not Blowing Cold
  14. Can this be done? Aftermarket AC
  15. Air Flow changes between levels on its' own
  16. What brnd Heater core to buy? Please help
  17. About to Heater Core on 97...what brand to buy?
  18. Tac goes up when AC or heat is turned on
  19. Heater core of A/C problem
  20. Noobie Question about AC
  21. Blower motor popping fuses...
  22. possable vaccum leak
  23. Temp Control Problems
  24. would like to know belt size
  25. A/C blows cold then switchs to heat
  26. Blower motor won't run.
  27. no luck with pulley
  28. possible to remove a/c compressor pulley?
  29. '03 F150 Cabin Air filter?
  30. Need a picture of defrost vacuum hose
  31. Defrost/Floor buttons don't work
  32. Erratic AC temp changes....
  33. Max A/C not working
  34. When to turn on heat
  35. Ford CAN'Tfix the problem, any ideas?
  36. No heat and no temp indication
  37. level 2 on fan nob doesnt work
  38. Heater Core- 1998 F-150 V6 4.2L
  39. What type of heater hose tool for 97 F150
  40. heater core hoses on a 97 f150
  41. Need a new A/C compressor
  42. 1998 F150 - Getting rid of my A/C
  43. 06 SuperCrew XLT A/C not cold enough
  44. Overheating with A/C
  45. More powerful blower fan
  46. 2005 5.4 Triton massive A/C coolant loss
  47. Climate Control - AC Is On By Default?
  48. 04 F150 AC Evaporator Issue
  49. Heater core replacement for 1999 Expedition
  50. Blower motor
  51. Automatic climate control just shuts off
  52. Heater core replacement
  53. How many plug ins on an AC compressor?
  54. Location of Blend Door Actuator 02 F150?
  55. A C insulation
  56. A/C cuts truck off in Park or Neutral
  57. heater prob...
  58. 2004 manual ac to climate ac?
  59. AC compressor never cuts out not cooling real good
  60. AC wont get cold unless the Truck is moving ??
  61. Do I need a compressor or just the clutch?
  62. Ac blows cold...but when I take off it turns to heat????
  63. A/C blower not working on Low or Med, just High
  64. AC no longer blows out panel; up top instead
  65. 2005 5.4L A/C Problems
  66. Anyone try 134a enviro safe refrigerants
  67. A/C on even though switch is not on A/C?
  68. Weak '97 F150 AC
  69. Very weak A/C - 2001 f150
  70. Blower Resistor Pictures and Instructions
  71. Manual climate control to electronic control
  72. A/C Floor Vents in 2006 F150 FX4
  73. A/C makes my truck run really bad
  74. Temperature Control Knob
  75. Are Any Filters In The Cab
  76. moving vents also gurgle and slurp
  77. Where are hvac air "return(s)" in cab?
  78. Compressor not cycling???
  79. Need help - Heater Hoses - Supply? Return?
  80. Replacing A/C Manifold Assy.
  81. Help My Moving Vents
  82. Compressor Problem
  83. AC Blower problem
  84. 1998 F150 A/C not blowing cool air out
  85. 95 f150 compressor clutch screeches randomly
  86. HVAC retarded; all help appreciated
  87. A/C problem, when gas pedal is pressed
  88. Cahnging AC clutch
  89. Where is low side hook up for a/c???
  90. 2004 Blower motor speed problem
  91. No compresser engaging?
  92. Air Conditioning Drain clogged
  93. 1999 F-150 A/C Compressor Constantly Cycles
  94. I'm an idiot
  95. AC compressor wiring color code?
  96. A/C Blows Cold....Then Hot?????
  97. a/c stopps blowing through vents
  98. Foul odor coming from AC
  99. AC goes warm when moving
  100. AC goes warm when moving
  101. 95 XLT power window motor
  102. A/C blows only hot air, 134a is recharged
  103. Blower motor or something else?
  104. Insufficient Cooling
  105. How do you know when to recharge the system?
  106. Replacing compressor...what else needs to go
  107. Rear A/C rattle?
  108. 99 expedition psi
  109. 94 f-150 A/C question
  110. A/C question
  111. Vaccuum leak
  112. A/C not functioning properly
  113. HVAC problems
  114. What are the signs the compressor is going ??
  115. Replaced condensor coil, what next b4 charge?
  116. change to digital ac?
  117. 2006 Lariat Crew 5.4 A/C problems
  118. AC blows but air isn't cold after a charge.
  119. Swapping in electronic A/C controls??
  120. Blend Door Problem
  121. Bad Heater Core
  122. Replacing compressor
  123. Think you have all the f-150 answers? Take a stab at this one.
  124. A/C Kicking On and Off
  125. Same old vacuum problem
  126. '90 F-150 A/C Resurrection
  127. Death Kit
  128. A/C blows cold but weak air preasure
  129. Yet another A/C question......
  130. HVAC vacuum line through firewall
  131. Won't take charge after vacuuming
  132. A/C compressor cycling question
  133. Leave the AC on or turn it off every time?
  134. How much oil?
  135. A/C always on?
  136. Dodge Dakota compressor damage
  137. AC blows through defrost vents
  138. 97 ford Expedition what pressure?
  139. Noise when AC turns on
  140. A/C Won't charge?
  141. needing to charge my ac
  142. Where can I find HVAC maintenance service??
  143. AC Chatter
  144. Position of can when charging
  145. A/C warm in city, cold on highway?
  146. A/C issues
  147. A/C issues
  148. 100psi on low side - Compressor won't kick in
  149. Ford HVAC controls STILL suck
  150. Ran into an A/C problem that everyone might want to check for in their vehicles.
  151. AC through defrost (different problem) not vacuum
  152. A/C slow to cool, compressor noisy
  153. Need new Compressor
  154. Ac Goes From Cold To Hot "female In Florida Needs Help"
  155. Vacuum
  156. Just added 17 Oz. R-134a still 36PSI
  157. A/C fan.......
  158. 2001 F150 AC cycles cold to hot over and over
  159. AC Service Port Low side Expedition 1999
  160. A/C problems self diagnosed (I think)
  161. 03 Expi Rear A/C not working
  162. Another odd AC issue
  163. A/C stoped working????//
  164. HVAC switches from panel to defrost and floor
  165. HVAC Console Lighting
  166. Cabin air filters, what's that about?
  167. HVAC has weird smell
  168. HELP, my A/C just stoped working
  169. ac also thru heater, need motor id & action..
  170. A/C Issue... WIERD...
  171. Possible A/C clutch problem please help!!
  172. A/C blowing hot and cold air - F150 SC
  173. A/C Blowing Hot Air, Even On Cold
  174. Loud Noise when A/C turned on
  175. HVAC and mpg
  176. Zero pressure
  177. A/C blows through top defrost.
  178. What is up with my AIR!!
  179. HVAC Help!
  180. Vent just under climate contols
  181. AC in Split vent selection et al?
  182. Werid One
  183. Climate control unit replaced
  184. A/C has good preassure reading
  185. Air stays on after ignition is off!!
  186. Floor vent y pipe. DELETE?
  187. wierd A/C problem
  188. F150 2001, Blend door problems
  189. A/C only works on Low, High switch blows same as low
  190. blend door or switch or what?
  191. I think I only need an a/c clutch...
  192. Running water?
  193. Anyone have the Infamous Heater Core Instructions?
  194. Air squeal from vents.
  195. cap for service port
  196. Now I am not sure
  197. A/c not working even with a new compressor
  198. Standard Climate to Auto Climate control conversion
  199. need help with blend door
  200. AC fan?
  201. A/C blowing like heater
  202. Blend door Instructions (Expy)
  203. Defrost/Floor Noise
  204. A/C staying on...?
  205. AC/defrost also blows thru heater vent...
  206. A/c Recirculate Button
  207. Heater Core???
  208. Air velocity out of vents seems slow
  209. Ac Condenser J-b Weld
  210. Fan stopped blowing?
  211. 134a question Having some problems
  212. Blend Door Replacement Pictures
  213. A/C on
  214. 2002 lariat cliamate control issue
  215. Heater Control
  216. replaced heater core, have problem, need help
  217. Electric heater
  218. Vacuum loss fix?
  219. 03' screw heater problems
  220. Tricks to getting at the orifice?
  221. Heat is stuck on!
  222. Air Con flow-return lines
  223. Heater Inlet Hose Replacement - Help!!!
  224. installing AC in a 2006 f150
  225. 2000 expy blower runs with key off
  226. 134a
  227. OE lower radiator hose remove how?
  228. Manual HVAC to Auto HVAC
  229. Heat issues in 2 trucks
  230. Temperature Control not working on HVAC System
  231. Any Thoughts? Noise from Vent
  232. Air Flowing at 60MPH, why?
  233. Heater core/Water pump/radiator
  234. very little heat....brrrrrrrr
  235. How does this work?
  236. Please Please Help!!!!!!!!!!!!!!!!!!!!!!!!
  237. Coolant leak pass. side bottom of rad.
  238. I have an idea but will it work?
  239. Is my A/C Comp running?
  240. engine running hot, or Temp. Gauge spike
  241. No Control over Temperature
  242. heater core
  243. Low heat/engine running cool
  244. Charging Heat?
  245. DESPERATE for detailed instructions on heater core replacement PLEASE HELP!
  246. 1992/302 belt question
  247. random heat
  248. What is the part # for the blend door motor
  249. Where do the HVAC vacuum lines go to?
  250. 1999 f150 xlt no heat
