- '98 Ford F150 - Heater Core Problem???
- blend door problems
- Problems...
- 1999 No heat No air
- uprade hvac to dual control?
- Defroster problems 2004 FX4 new style
- HVAC 2008 F150 Super Crew
- diagnosing electronic climate control problems...
- 80 degree heat
- Heater questions
- HELP! My blower motor will not come on. 2006 F150
- intermittent compressor
- Water pouring sound when accelerating
- Compressor location NBS
- FX4 digital climate control in single cab???
- No Heat No AC
- Blend door
- This the right blower motor?
- A/C blows cold then warm, Dealer says system charged!
- can u help me with my heat?
- HVAC and Battery Fix?????
- Story about trying to fix my 98 f150 a/c
- climate control working without the key in
- Blower motor replacement?
- e fans in 2007 f150 screw 5.4L
- Heater core replacement (howto guide with pictures)
- lower windshield fogging up on the outside
- Air flow won't change off vent
- Antifreeze smell inside of cab when AC is on
- AC cycles from vent to defrost pos
- Why is A/C is always on?
- possible low or high charge?
- Baffle Motor Makes Noise
- Blower only works in position #4.
- AC low Pressure port
- 99 expd
- How do you tell if the cycling switch is bad?
- A/C problems
- A/C Fluid leaking (green)??
- Can you upgrade to automatic climate control
- Intermittent AC problem
- HVAC problem
- Fan Motor Dead...need opinions
- A/C Smells...
- A/C issues
- 1998 F150 XLT A/C Compressor clicking on and off
- 98 F150 Cabin Air Filter
- a/c leak in cab
- Are all 134a refrigerants similar quality?
- Perhaps bad heater core...
- 2007 AC problems
- AC suddenly stopped working
- A/C and Heater not working
- Got a question about my HVAC
- Are '05's crap?
- 2000 F150, clutch or compressor
- No defrost or floor air
- Air is cutting out.
- 2002 F-150 vacuum reading
- Vibrating noise under right dash
- 98 Blows Hot!!!
- Some AC/Heatercore questions
- Normal pressures for cycling switch?
- temperature of air in "vent" setting ???
- 2004 supercab troubleshooting
- New Here! Desperate for HELP - Weak AC!!
- 1991 f150 supercab A/C blower replacement
- Hvac
- smells like mold or something please help
- 97 F150 AC Problem
- A/C system is shot?!
- Guys, I really need help. AC/heater/panel wont turn on at all
- need advice on a/c
- A/C cycling after HC replacement
- Low-Side Port Location
- Compressor clutch troubleshooting
- 2000 Expy Rear Air Leak, W/Picture
- 99 F150 SCAB Blend Door Actuator/Motor
- Water on passenger side floor board
- 99 expd a/c and heat issue?????
- Question for Steve
- Does it need to be recharged?
- 05 f150 air not very cold
- a/c cycling long
- a/c causing engine to overheat
- Buzzing sound on shut down
- a/c
- Picture of A/C Pulley?
- Anyone have a pic of the vacuum lines for F150 or Expy? (a/c blowing through defrost)
- blower resistor location ??
- Heating and cooling issues
- A/C Recirculate indicator
- Diagnostics
- CHT (Bad) + PCM= No A/C?
- Heater Core Issues on 04+
- ac overcharged?
- Temperature knob sticking
- 2004 F150: A/C Controls blinking every second
- Help! How do I pull the AC Compressor
- Evap core
- 99 4.6 water dripping
- Compressor clicking?
- Short in the AC
- A/c not blowing cold air. clutch coil?
- ac not blowing cold
- Weird noise when I adjust temperature on auto HVAC.
- Automatic Climate control question
- 2004 to 2008 cabin filter? Aftermarket? Options? any?...
- AC compressor bearing
- need help locating resistor pack on 1992 F150
- What does Ford charge to charge the A/C system
- AC won't come on Right away???
- AC condensation leaking inside the truck
- '04 Excursion not blowing cool air - EATC codes?
- '98 Expedition: replaced Heater Core, now runs rough?
- A/C does not blow thru panel vents
- A/C Mildew Smell
- Whistling AC
- A/C Compresser Clutch
- ticking comp
- Problem
- poor comments on A/C...add on Efan?
- AC doesn't turn on at highway speed
- Chipmunk in heater vent system
- Low pressure port '02
- Digital HVAC
- E350 rear air blower wont switch to ceiling vents
- A/C cooling delay after acceleration
- Automatic Climate Control - Vacuum Line Diagram
- ac compressor squeak?
- Supplier of A/C compressor?
- AUTO setting on AC and Heater malfunction???
- The official Blend Door thread
- Noisey Compressor
- 2004 AC Oil Viscosity???
- AC Delay??
- AC not getting cold enough
- No heat or A/C
- A/C pulley problem (97 Expedition)
- Max A/c amd normal A/C
- Water sound in '97 4.6L
- 2005 - AC not working after Battery jumped
- AC clutch noise
- A/c fan on the blink
- bad day
- Defroster
- A/C will not take charge
- multiple problems with my heater 1997
- Make your AC colder
- Temperature Control Assembly
- No heat
- Blend door? no A/C, no heat, and no panel air!
- 2007 SCrew Heater Noise
- Max A/C problem
- Air Flow Problem
- Heat problems, Please help
- AC Delays Blowing???
- Need Help
- Large Core Radiator options???
- intermitten whistle in hvac
- need help w/AC-heater problem
- loose clutch plate, can i just remove it?
- Heating and defrost questions
- electronic control conversion
- removial of ac equipment
- Hissing sound behind dash
- 99 Lincoln Nav how to replace heater core HELP PLZ.
- temp gauge needle low c fan loud
- how do i fix my damn a/c drain
- heat=warm not hot
- Heater Core... again, what to do?
- Does anyone else have this
- a/c clutch bearing???
- So can I buy an 8 rib pulley for my 4.6 A/C compressor?
- bypass pulley for a/c
- Blend door replacement????????
- water shorting out heater motor
- need help
- Temp control switch
- no heat need help
- No Power to AC Clutch
- Everything is hot why isnt my car?
- Air Flow???
- fixed heater core, now radio and rear heat wont work
- Leaking AC part ID
- Radiator Flush
- Heat temp. control valve
- 99 EXP - Limited Heat
- AC Trouble Please Help!!!
- A/C not cooling fast enough
- schematics for heater blower
- Need help getting pulley back on!!
- How to recharge & repair refrigerant leak
- A.C. Compressor troubles!
- Motor Swap - I need an 8 rib pulley for Compressor
- Cab fan squeakage
- Can Poping Sound when A/C turn off
- bad heater core??
- 98 150 heating/cooling problems
- 98 F150 - Weak Heat
- Thanks to everyone
- A/C problems
- leave blending door in one position
- Blend door motor...actuator?
- 84 F150 Heater Core Instructions to remove
- no defroster please help
- 2000 Blend door
- Electronic Temp Control
- A/C Heater issue...
- Floor = vent apparently?
- 98 heater BDA and BDP Problems
- #5 Fuse- Reverse and Heating-A/C
- 03 screw no heat
- A/C Clutch fell off!!!
- No Heat And Very Cold In The Morning Whats Up?
- A/c Fan Noise
- 98 expy same as f150 heater core? help.
- Does the heater use gas?
- Interior fog on windows
- 98 F150, one my third heater core, Ford is now saying I need a pressure regulator.
- Temperature control problems
- white mist out of vents
- No heat coming from vents
- Selection switch not working
- Air Flow Problem
- water leak and rattleing noise
- Water in cab
- A/C Fuse blowing & no heat
- Starter Bolt Removal Problem
- Compressor Oil Capacity
- engine loses coolant when I turn it off
- 2005 Climate Control Problems
- Replacing A/C clutch please help
- '92 F-250 heater won't switch from vent to defrost/floor
- Convert my 07 screw to climate control?
- Diagnose my A/C problem... p l e a s e.
- 2004-2007 heater core removal
- 2000 Focus
- 2 BLowing levels will not work.
- 97 F150 AC Compressor will not kick on.
- *****AC compressor Clutch******
- 2003 F150 SuperCrew A/C Problem
- Temp control / blend door motor bad?
- Intermittent blower motor
- the new troyer mounting brackets for efans
- Fix for the 04-07 A/C problems!!!
- How do I remove the dash vent swivel?
- error codes
- 03 F150 4.6 A/C on regardless of switch setting.
- Electronic Climate Control System Problem
