View Full Version : Electrical Systems
- fog/dash board lights prob!!!
- No interior dome lights- fuse help?
- Replace the light in the switches
- Which spark plugs?
- 3rd brake light problem
- cluster swap
- 03 s-crew code 32
- 2001 F150 seat belt sensor alarm
- need some help.....object name & place to purchase?
- Optima Enough?
- Gonna Attempt to Wire My Fogs..Again
- 98 Signals and Fashers
- 12-volt accessory plug fuse? PLEASE HELP!!!
- May be a dumb question...
- Switch Gauge Clusters in 08'
- Anyway to add OEM Fog lights?
- Turn signal/brake light fuse blows
- How do you check a relay?
- really dumb, but quick horn installation question..
- Relay or breaker clicking when I use the "seek" button on CD player?
- Headlights won't turn off, and instrument panel doesn't light up
- 2005 Explorer won't start
- RPM guage jumping around at start up
- drawing lights and fan down.....
- Tailgate power lock wiring
- Drivers side front signal not working?
- Headlights
- 2006 F150 Computer Location
- Remote starter install
- two dimming mirrors or one
- dead truck
- Need help finding a timer !!!!
- which color wire is the "switched" power
- aftermarket power windows
- Tach/Cluster Help?
- Remote Start Install Preperation
- 06 F150,Adding Fogs - wiring harness question
- alternator question
- Rookie need help on rear window dilema
- Broken retension clip on coil pack connector
- "Ambient Interior Lighting"
- Odometer screen going blank
- Keyfob question
- Airbag Code 1-9 ???
- Keyless Entry problem
- 1999 F150 XLT No low beams/High beams ok. Why?
- All 4 power windows dead
- Wiring an Amplifier to a cb radio then to a p.a speaker?
- Bad power window switch???
- Push button starter
- Fuel system Failure
- 2003 F-150 turn signal problems
- 2nd PATS key will not enter programming...HELP
- Mirror upgrade install help !!!!
- Parking Light Problems
- 1998 f-150 power windows
- Replacing 9140 Fog Lamp Bulbs w/9145ST??
- Reverse light issue?
- bought some hids
- What bulbs do I get?
- What is the best Alarm system as far as anti-theft and overall security?
- loud click but won't start. battery?
- 2002 gauge cluster help!!
- guages,
- dinging????
- Driver Side Fog Light Keeps Going Out
- in line fuse for toolbox lights
- compass and thermometer not working
- ignition Problems
- Hi beams help
- New Retro-FIt W/ 6-k HID
- Locking Horn Too Loud
- Dim Headlights
- Heater fan switch
- Sidemarker Lamps NOT working
- Windows stuck (DOWN)
- 12v aux outlets question
- couldn't see my odometer in dark this am
- headligth help
- EATC on with no Key in ignition???
- Help locating connector / pigtail.
- OEM Power window regulator
- Check Fuelcap Warning
- needing proper power strip for heat patches
- I want a key without a chip
- Another sparkplug thread
- Airbag Light
- 01 screw cruise problem temp fix and questions
- Battery light on??
- Battery Problem
- Buzz by the computer hook up
- 12V Winch Wiring Question
- Cigarette lighters aren't working
- Problems... where to start...
- Anyone know how to turn off Dayrunners??
- High beam + foglight mod = me needing more help
- Cylinder lock broke? need help asap
- window switch dead...can I remove the cluster surround?
- Another HID Question
- Cruise Control Repir Thoughts
- Taillight styleside make 1998
- HID high/low headlights and fog lights problem...
- Have an alarm installed, do I only need power lock atuators?
- INstrument Cluster question?????
- possible electric problem?
- Shorted Accesory Wire
- Fog lights trying to start engine???
- Someone has to know what this is.......HELP!!
- putting 06 mirrors on 08 truck
- Help Me Diagnose My Illumination Fus Problem
- Headlights not working hellllp!!!
- Subwoofer wiring harness
- No power to pump
- Parking assist button stuck off????
- Wire from engine into cab????
- problems with my reverse lights
- Lights Dimming on Cold Starts
- replacing airbags
- Unreliable Tachometer
- "No start" mode???
- gauge problem
- Battery change question
- knob illumination question...
- SRS light on
- 2004 F-150 Driver Power Seat and Power Pedals
- Window Kit or Regulator? Which one do i need?
- "08" 5.4 fan question.
- Parking Brake Light Intermittent
- Radio Noise install help
- Help!! Headlight signal/parking wires
- 2005 F150 Turn Signal Issue
- PLEASE HELP 97 f150 ground wire location
- Headlights Won't turn off! 2000 F-150
- power window wont roll up
- Turn Signal Indicators in Cluster
- Help! 04' Heritage no Hi beams?
- Starter on F250
- Windshield wipers not working right?
- passenger side airbag on/off light
- air horns
- After Market tach
- Second Battery
- PCM Question
- whacky gauges
- Driver side heated seat won't heat!!
- backup lights
- Rapid Turn Signal
- Cruise control does not work 00 f150
- Right Side Low Beams not working...
- HID Head Lights and DRL
- remote start w/ xk04 bypass. Need help
- 1998 F150 XLT - instrument panel bulbs
- 1998 F150 XLT - which headlight switch?
- 1988 F150 ignition Problems
- help! remote start bypass
- removing driver seat.... where is 4th bolt?
- power point fuse # for 2004 F150
- odometer trick
- help me pick an alarm
- 4x4, wipers, windows, daytime lights do not work?
- Keys in Ignition Dinger always on when door open
- Keyless entry module?
- Adding power windows and locks?
- Tail lights and instrument panel lights out
- blue leds...
- Factory Electrical System - Up to Upgrades?
- Ecu
- 98 F150 power window
- Power window switches
- door lock problem?
- map lights out
- Code SRT5500 Remote Start
- ???Interior Accent lighting wiring help???
- Radio/AC/seat warmers going on and off randomly?
- Constant 12v power at trailer plug?
- 4H, testing
- Backup camera problem
- 97 F150 4WD Lariat starting Problem
- day time running lights wont turn off any help please
- How to reprogram my unlock remote?
- Old model ford remote start help
- DVD player problems. no picture
- OEM Alarm System Information
- OBD port does not work
- train horn wiring
- Ignition Switch Issues
- Hella lights w/ out highbeam tap?
- 98 4.6 Engine ground location help???
- Power seat problem...
- no signals and no back up lights HELP!
- No Sidelights or rear lights. 2003 F150
- Just bought a 2005 FX4 and have a question about a "buzzer" sound
- Passenger Airbag Light
- window switch
- What alarm/remote starter??
- My Key Switch ...
- 1998 F-150 ignition switch possibly draining battery?
- Fog light install
- Dead Battery Again
- brake lights help
- help with temp and compass
- MPH Gauge problem
- 1998 F150 Drivers Side Headlight Removal
- V1 Hardwire Problem
- Remote Start
- Fan????
- Daytime running light intermittent
- Driver Side Window
- 2006 F150 Wiring Harness Failure
- Help! No Right Rear Turn Signal
- No trailer running lights 2006 F150 4x4
- 2005 F150 is dead and a ticking occurs rear of cab.
- need help parking lights slash dash lights
- Gauge Cluster concern
- Headlamps water
- how do i disconnect...
- altenator
- horn is very weak
- Horn works with ignition off, not with it on???
- Python 580P remote start
- Electrical Problems
- 94 F150 won't start. Only hear a click noise
- Help total electric failure
- 04' cruse control
- Strange electrical problem
- Turn signal and four wheel drive won't engage
- Weird problem
- electric fans
- This problems got me puzzled. Extra 2 amps going somewhere...
- maybe gem box ??
- remote start t-harness
- Optima Battery?
- Blown Fusible Link
- fuse 15 shorted
- Illumination not working!! HELP ASAP!
- windshield washer problem
- No radio sound
- Gauge cluster swap
- Brake lights
- Electrical Issues, Gauge lights and running lights stay on
- Right blinker
- How to turn off ABS and Parking brake??
- Intermittent odometer - not a repair
- HIDS yes or no?
- Fog Lamp Mounting Bolt/spacers?
- Reverse light out not the bulb or fuse..
- speedometer not working
- HID COnversion
- Power seat won't move back
- install of projector lamps???? LEDS
