View Full Version : Electrical Systems
- Headlight Problem/Possible Short?
- Well, I'm the proud owner of a New Remy alternator
- A/C Clutch
- Power window help
- Constant horn blast, power locks keep locking while driving
- How to Adjust headlight aim on a 2003 f150
- Wipers finally out
- Constant Battery Light
- Door ajar light..
- 7 pin trailer hook up to charge battery
- Battery losing charge after replacing alternator & battery
- 1998 Ford F150 Headlight issue
- 87 battery jumping
- headlight switch wiring diagram 2002 f150
- Not once, not twice, but three times!!
- LED 3rd Brake Light/Reverse Light Bulbs Ordered, GREAT DEAL
- 98 Lariat remote lock issue
- Power window not going up
- Headlight Problem
- starter issue 2000 f150
- RECON xenon bulbs
- HID's flicker with turn signal - Anyone ever seen this?
- How many taps on switched circuit?
- Temprature-Compass Display
- Fuel gauge stuck???
- 1998 F-150 with dead battery and theft alarm wont shut off
- after market fog lites
- 2004 150 xlt wireing schematic extieror.
- Lighting - HVAC / Heated Seats - How to Fix?
- 2003 relay question
- Airbag light on
- RECON 60" White Lightning LED Light bar Ordered!
- No brake lights
- HID headlights
- Aftermarket Back up lights
- Rear Passenger Door Problem
- Remote Start/Alarm Help
- Brake Issue
- Wiring diagram please
- Fast Blinker
- 05 Cargo light ..timer?
- help help help!!!!!!
- Good place for power.
- Could use some help im confused
- Radio install gone wrong, now huge electrical issues.
- Does it exist??????
- Extended abs wires...amongst others
- Temperature control backlight
- New Alternator Time?
- how many amps can I start to charge with?
- maybe a bad key?
- Battery Question
- 04 cruise control problem
- Wipers "creak".... annoying!
- Backup sensors continuous beep in reverse!!!
- Headlights not working right damnnit!!!
- fog lights with hibeam??
- Adding Power Mirrors to an STX
- Chime removal , '09
- 01 SCREW Thieft light
- Driver Side Power Lock
- 1999 Battery Voltage Reading?
- 2004 FX4 No electrical all of a sudden
- Need help locating a wire
- Time to replace? (Battery is 6 years old)
- factory alarm phantom fault
- NEED HELP:1985 F150 with brake light issues
- Good Aftermarket Battery
- looking to get a hid kit!
- All green panel lights switch to a different color
- wanting to convert to PW, what buttons am i lookin for?
- 1997 Lariat needs cyl. lock replacement and clock spring
- door locks & speed/tach acting funny on start-up
- HO alternator & Big 3 Q's??
- HID question
- Under Hood Light...
- airbag,overdrive,service engine soon lights
- blowing fuses....?????????
- The best None hid light bulb to but in
- K3LA installed!!!
- blinker and brake light not working
- Lightning GAUGE CLUSTER Into 97 Ford
- I need an 09 power mirror wiring diagram / help
- light bulb
- Auxillary Power Point Problem
- Outside Temperature Sensor
- windsheild wiper problem
- hazzards dont work
- Calibrate thermometer??
- key off voltage?
- Remote Door Locks
- Turn signals and hazard lights not working
- Power Mirrors Question
- PP & cig lighter
- Pwr Door locks lock by themselves even when door already locked
- Possible electrical problem----maybe?
- how do you change the map light bulbs
- ceter consol gear shift light not working
- If I upgrade to a fog bumper????
- Factory alarm vs Karr Alarm
- Remote start problem
- Red Door Lights 03 Supercrew
- Odometer light went out...please help
- breaks, cruise, heater
- cruise control
- Fog light control
- No brake lights but fuses are fine
- Brights
- remote start using iphone
- abs light / cruise control
- A different auto lock issue
- 12v Power Fuse Location and Window Issue
- 92 F150 Passenger Rear stop lamp/turn signal malfunction
- Truck has difficulty starting
- intermittent battery light
- Gauges Flatline and ODO Dead
- headlights wont turn off
- Brakes cause Turn signal fuse to blow
- Can you please help me? Power Windows and inter lights don't work .
- Auto door lock Gremlin - something more?
- lost my key 2002 f150 with anti theft please help if you can
- Do cargo light and license plate bulds run on the same circuit?
- major electrical problem..headlights, wipers, interiors
- temperature gauge went out
- Electrical Problem?
- Turning off Autolocks
- Air bag help!
- Big Time Problems on the 2003 FX4
- Head light help?
- desperate for advice
- Headlights
- 2000 Lariat Door Lock Mystery
- Door Locks
- Blower motor stays on with key out
- sunpro tach II
- No OBDll in 97 F250HD
- 02 F150 4x4 Lariat overdrive light
- electrical problem
- Auto climate control does not shut off with key off
- Ignition Coil Pack problems
- b codes?
- Auto Headlamps 04 f150
- Battery Dash light on?
- Another Power Window Issue
- Keyless entry keypad not working
- Security Key Pad
- '94 F150, new altenator not charging
- wierd light issue
- power locks not working
- Power Windows dont work, fuse is fine.
- wiper/washer problem
- Brake Lights Stuck On - 1997 F150
- starting problem
- Replaced battery; now won't start
- Power Lock Switch Dead
- Wet horn?
- ignition gremlin?
- Fuse 14 2004 f150 supercrew lariat 4x4 5.4
- courtesy light DOES NOT come on when door is opened
- F150 Powetrain control module questions
- OD Switch (Aftermarket) wiring ??s
- HID Prices
- Halo headlights/Aftermarkets
- looking for a better battery.
- Heated Seats, Compass and Cruise not working...
- Compustar & KCAutosound
- DIY Homelink
- Airbag Light DTC 42 FIX
- 84 F150 no taillights???
- Turn Signal works intermittently 1999 F150
- Viper Alarm OPINION PLEASE!
- Fuel pressure problem. Wiring issue?
- Auto climate control malfunction
- Question about Instrument cluster
- Dash wiring harness???
- Mirrors not working
- 2001 F350 Alternator problems HELP PLEASE
- switched 12v source on 2001 lightning
- ABS light
- Color code 4 3ed brk light?
- Windown wont work
- Cruise control not working
- Window Wipers Problem
- calibration on compass screen
- blown fuse
- Aftermarket fog lights in factory fog holes on 04-08
- Red alarm light on dash staying on.
- Air Bag Code 18
- 2003---SiLvErStArS---who's got 'em??
- amp steps, which black/blue wire?
- What is this connector for?
- Shifter overdrive button shorting out fuse problems
- Left brake/turn signal light will not work
- 2003 F150 Blinker Doesn't Work
- Battery Dying
- power for headrest monitors?
- Failsafe mode
- Fog light Question
- Trouble codes
- What color wire for highbeams?
- 12v acc feed
- DRL Questions
- Keyless entry door keypad
- Compass not coming on & working
- Gas guage not working
- Garage Door Opener
- Keyless entry won't work after changing battery
- Warning lights stay on even when truck is off.
- Drivers window switch, probelm
- Signals and brake lights won't work if headlights on?
- Instead of the Line of Fire....
- Bad power window switch
- Keyless Entry Unknown
- Wont start..........Kinda.
- how to hook up to dash lights!??!?! help please
- 12v on dash..what fuse?
- GREEN HID kit install help
- Brake switch??
- I replaced my bad starter and now my truck still wont start.
- Help, too much voltage at trailer wiring
- Mirrors, drivers seat and pedal not working
- chiming noise will not stop...
- Blowing fuses?!?!?!
- Headlights, taillights won't turn off
- 2005 f150 xlt supercrew power window problem
- Light numbers, HELP!!!!
- Trailer Wiring Unanswered...
- Weird problem with door locks
- cruise control lights
- High beams won't work.
- windshield wiper won't turn off
- Chimes Again !
- 99 F-150 ignition/anti-theft question
- No Tail Lights
- No power from alternator, why?
- Cant link to computer?
- Does anyone know the A/C wiring difference between 07 XLT and Lariat?
- RAP? 1998 what performs the RAP function in 1998 F150
- CB Radio interference with Radio?
- 1998 remote entry system and perimeter alarm system
- a/c clutch,4x4 solenoid fuse blows
- f-150 starter
- relay wiring question
- hid on 09 f-150
- Recommended HID company's?
- HELP!!! cooked electrical system? Blinking OD light, no power & battery died HELP!
- 85'f-150
- Replacing 95 amp with 130 amp alternator
- Electrical Issue New Battery Won't Start
- Replaced Alternator whines and is HOT
