- I Got A Rattle That Is Drivin Me Insane!
- Replaced front speakers with Kenwood 3-Ways
- Replaced rear speakers and installed Dynamat
- another wiring question
- What 5x7's, 6x8's do you use? and how do they sound?
- Polk EX357
- Sub's in a 2002 SuperCrew
- Whos Better 8" JL 8w3 or Kicker Comp Vr
- Position of Subwoofer
- Jl audio vantage box on Ebay (if anyone is interested)
- Cheap sub??
- Stuffin
- SUBBOX.net has changed manufacturers...
- Looking for a good sub box to fit under my 200 F150 extended cab
- What kind of subs do you have
- MTX Thunderform Boxes
- Premium sound Speakers
- Alpine 1629?
- Rear seat lift kit????
- putting new speaker wire into drivers door
- 1 10" or 2 8"s
- will 2 12" subs fit under seat in 97
- Will 6x9 's work
- Few Q's about subs
- 6.5" Adapter Plate
- Best component system for under $200?
- OHM Ratings
- Sub & Amp Installed
- F-Series Box
- Dynamat installed
- 1997-99 Super Cab JL StealthBox on Ebay
- Subs on EBAY
- How/what should I use for a sub in a regular cab?
- Removing door panels on 2002 F-150 Ext. Cab XLT
- Box Dimensions
- Help please......
- is this possible....
- Rousefan-1
- Show your Subbox.net boxes
- Anyone have a Probox Sub box?
- Need some help-i'm new
- What did I fry? Speakers or amp?
- New Subs (pics)
- Subs under my cover?
- reference 5x7 for sell
- How To Remove The The Split Seating Area???
- hows this deal?
- Replacing factory speakers ?
- which way?
- Three 10'' MTX blue thunder subs for sale
- Speakers
- What amp? What sub? BEST BUY
- What to buy...what to buy...
- sub distortion?
- Subs under the back seat in a pre 97
- new speaker install
- Question on your F150s speaker holes?
- SuperCrew subwoofer options to complement Polk speakers?
- can i do this.....
- Will this work???
- Regular cab sub box plans
- Box angles
- Is there a single 12 or 15 inch sub to handle 1kw rms?
- where can i find qforms???
- Any Good?
- Back Bulkhead Dynamat? Back Seat Removal
- Static distortion on highs ??
- 1 Ohm wiring....
- Need Tech. advice, please.
- 10" sub in center console
- Carpeting
- Subbox.net question
- mtx thunderform help needed
- where to put my box...
- How do you get the dorr panels off?
- What are the best 6x8's for use with Factory HU?
- Wtf???
- Polk EX3560 component sys. Will it fit? And Component Tweeter location?
- 2002 F-150 Speakers
- Angled Tweeters
- Will Infinity Basslink fit...?
- Going for 2 more...
- Component tweeters
- Need Help on Box
- new guy needs help!
- How do you remove rear interior panels
- Going from 2 speakers to 4 - Do I have to wire?
- A little extra BASS
- More sound/vibe damping
- Audio system upgrade
- Mounting subs to enclosure
- Competition Sound System
- Polk DX7 Speakers
- speaker distortion solution...???
- got new door speakers
- Subs behind the SCrew backseat...
- Wiring DVC subs
- whats the best system for my truck?
- Alpine Type R's
- Dimensions in standard cab?
- JL Audio W7 vs. Eclipse 88000 DVC Titanium Series
- is this a good deal?
- Remove lower seat brackets for subs
- Should I replace stock speaker cables?
- Q logic Dual 8 inch prefab'd box
- Infinity Kappa 572.5cf fit and function for front door location?
- Do subwoofers have to be broken in?
- Anyone have this Kenwood Woofer??
- Raising the backseat for a bigger sub
- MTX amplified thunderforms
- Anybody using Polk EX368's?
- Bass blocking capacitors
- Infinity Kappas/Basslink/Console
- Component x-overs?
- subbox.net extended cab box for 12's?
- better jl w6 or w3?
- i want to know what you think of Alpine type R
- suggestions anyone?
- Anyone Install 6x9's in the rear doors of an SCREW or SuperCab?
- pictures of tweeters in door
- MTX Thunderform??
- Bazooka tube in king cab
- 98 ext cab rear driverside speaker install
- QLogic Kick Panels, EBrake?
- Infinity Kappa 572.5cf vs. Polk DX7?'s
- Bazooka sub tubes
- Applying Dynamat
- 2 important questions... PLEASE HELP
- quick computer code ?
- bazooka
- tweeter placement
- subbox.net box and fosgate sub FS
- Weird!!! Bass response from rear doors MUCH more than front speakers?
- Speaker question
- 3-way component set???
- screw put in 6 1/2 work great
- Blew my 10's...
- 6.5 vs 5.5 Components
- Ideas....Ideas....I need ideas!
- Subs in '02 SD Crew Cab?
- Where to mount cross-overs?
- Subwoofer Sound
- Is this enough power?
- JL 10w6 vs the rest
- 2 12" Solo Barics under the back seat
- Size Of Subs
- Liners
- Rate your Pioneers
- Pioneer 6X8's SUCK!
- Question About Mirrors
- Component Installs
- Speaker depth....
- Drop kits
- custom box?
- Polk audio EX368's, will they fit......
- Do I have enough air space?
- Anyone ever ordered from CarStereoOnline.com?
- Sound deadening material ??????
- Speakers in door not lined up
- 6 or 8 " sub for back door of SCrew?
- 2 JL 10w6's
- '01 Supercab 1-10" Downfire Sub-box
- Which polk audio oval spkrs are best?
- Rear seat lift
- Speaker Size
- Installing Subs?
- Read this if you had chicken for lunch...
- Running Wire to Door Speakers
- Crossovers, better at the amp, or in the door?
- How to wire at 2 OHMS?
- S'Crew Speaker Install
- Down vs Forward Firing
- What about 6.5's in the back?
- Hexagon Subwoofers
- Reasons for my Sub to cut out?
- Speaker install assistance/Advice
- where to get 5x7 to 6.5 conversion plates ?
- rear door speaker size for Expedition
- JL 10W-1 sub where to get?
- MB Quart's
- New 2-12" Sub Enclosures
- Thunderforms
- Speaker Install
- Kenwood 6X8 VS. Pioneer 6X8 Which is better?
- Rear Door Panels
- Fiberglass tweeter mount
- The subs are in....kinda
- Polk Momo 465 in the doors
- Anyone have to move the JACK?
- Q-logic kick panels and PSD 6 1/2 MB Quarts
- Subbox.net how are the boxes for (2) 10's in an extra cab?
- How would this sound ???????
- sub box?
- Both Solo Baric 12L7s are in!!!
- Alumapro 10" Alchemy and Alpine M300
- pioneer 6 x 8's
- Not for the truck, but I just finished this for the car...
- Why change from 6x8 to 6.5
- tweeters and components in different areas?
- Speaker box
- Can this be done?
- need a answer on speakers
- Quality install place in Houston???
- ? for RMcoolX - JL10w6 in a subbox.net enclosure for the SCrew
- 6.5 in-door conversion from 5x7 ?
- FOCAL UTOPIA $1100 a pair !!!
- Arghhhh, need help with speaker install
- how to hook up speakers
- MTX Thunderform....
- Sub rattling problem
- I found a new custom subbox for the Screw. Thought I would share.
- Powered -Sub/to install in Lightning???
- Bass from front doors?
- Installation Pix
- New Guy help me please
- 12" Down-firing pics....
- Box dimensions, what size sub??
- reg cab box plans
- parking brake & kickpods
- Kenwood or MBQuart
- Jl Audio Stealthbox Has Arrived, Finally!
- I have my Kappas FS
- how do they stack up
- What size speakers for my doors
- So who makes the MACH Audio system installed...
- 6.5" in 6x8 hole
- Success and Failure in my sound system
- subbox.net specs
- Box Carpeting
- Polk?? DX7 or EX3574
- Downfiring the only way to go?
- Opinions on MTX Amplified ThunderForm?
- subbox.net box for 02 SCrew
- blown speakers.
- Sub under Drvr side rear seat
- New Subs in....
- 5 x 7 speaker
- Dynomat Supercrew
- 92-96 f150 sub's
- Clarion Camo Sub Wiring?
- need help choosing between these two Pioneers
- final questions
- Seat Lift
- Sound Deadening.....
- 2 12" Help
- How do I wire the my New 10" 500watt Pioneer Sub
- Magnet Space
- Bach's Toccata and Fugue or that d*mned organ!
- MTX Thunder6000 10" Sub
- JL vs. JBL
