View Full Version : Pre-1997 Models
Pages : [1] 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27
  1. Ignition switch on a 91
  2. Is weak vacuum a problem? 87 F150 5.8 Carb
  3. Combustion, Fuel and you!
  4. 1996 4.9l Knock Driving Me Nuts - Help this Newbie Please
  5. what to do with front and rear anti sway bars when lifting truck???
  6. Steering column shift tube
  7. Traction
  8. 4.9 strait 6
  9. Truck turns over when battery is connected? help!
  10. Wipers Cut Out
  11. 95 F150 4x4, front hubs, brakes, etc
  12. Problem?
  13. E4OD is dead, need some input. 1990 4.9L
  14. 1992 dual tanks problem
  15. Dual Exhausts and Dual Tanks
  16. LOUD screech from engine after thermostat chg
  17. Battery warning light.
  18. engine swap
  19. Headlight problem
  20. 460 oil cooler
  21. Auto hubs
  22. Need Transfer Case Shifter Linkage
  23. what does a hotter coil do?
  24. COWL HOOD for 92-96 F150s DFW Cheap !!
  25. 1986 Engine problems
  26. What is this???
  27. 1995 f-150 4x4 differential questions
  28. Headers anyone?
  29. Spray Bombed
  30. '93 Power Steering Pump
  31. Timing Chain
  32. new clutch problem
  33. new clutch problem
  34. Difficulty starting the truck
  35. muffler recomendation?
  36. Relocated PCV hose 1993 F150 *a must do project?*
  37. adjusting steering box?
  38. 1995 4.9l will crank but wont start
  39. New guy from Argentina
  40. shut off switch
  41. No brake pedal
  42. Reading 12V between postive post and cable
  43. weather stripping Part name # ?
  44. Starter Troubles
  45. 2 mufflers to y pipe or y pipe to one muffler?
  46. 1993 F250 Fuel Tank Size
  47. Cutting out!
  48. Want to buy a 92-96 F150
  49. Can't get into 4 Wheel Drive
  50. does anybody have an extra rim?
  51. GT40 Heads
  52. 7' bed? Looking for a Truck cap?
  53. 93 f150 new tires
  54. New MLPS 1994 Lightning not working
  55. 5.0 to 5.8 swap staring saturday!
  56. Vacuum Lines
  57. truck downshifts on the highway
  58. Changing Wiring
  59. need help asap
  60. Ford Racing 9mm wires
  61. a/c problem
  62. heater not working
  63. Looking for bedbolts.
  64. AC vents not working
  65. Defroster/AC question
  66. 92 wiper problem
  67. Bought a '93 F150
  68. Looking at a 94 f150 supercab, couple questions...
  69. 2 wheel drive
  70. ditching my a/c and heater!!!!!!!
  71. 2.5 inch lift
  72. selling my truck!!!! anyone interested?
  73. is this truck worth it?
  74. 89. F-150 4.9 no start
  75. bad gas economy
  76. Getting New Tires
  77. raising a 1993 F150?
  78. Slave Cylinder Mystery
  79. Is this illegal?
  80. clicking when A/C is on
  81. Trade / buy seats for 92 F150 ex cab
  82. Body Lifts
  83. New "Old" truck
  84. bench seat
  85. F-150 Predecessor
  86. ABS light on and crazy speedometer
  87. Might buy an 89 F150 this weekend, Need advice
  88. steering loose? ahhhhh another problem
  89. Tranny Noise
  90. Help I have codes but not sure where to go with them
  91. 93 f-150 XL Suspension issues?
  92. Smog Pump Pulley
  93. 302 Build Help.
  94. my truck is jacked up, can I use regular shocks?
  95. where do I hook scanner up 88 f150
  96. L/R Brake Hose DIY?
  97. Transmission Lines.
  98. window motor
  99. MSD Ignition box?
  100. 1991 f150 5.8L EFI rough idle surging
  101. 94 F250,7.5 Brake Problem
  102. Just bought '88 F150
  103. 89 4x4 f-150 4 inch lift and 35's?
  104. Recommended towing
  105. Can't shift to 4wl
  106. 1989 true duals?
  107. 84 300 i6
  108. Code 87?
  109. 1989 F-150 High idle problem
  110. Oil Pan Gasket replacement
  111. Hey everyone, check in and roll call!
  112. Engine swap- 6 cyl. to 302
  113. 1993 Ford F150 V8 Skipping Bucking Misfire???
  114. 94 F-150 4.9L Tensioner Pulley
  115. 1995 F-150 bedbolts
  116. Suggestions on fixing up a '92 302 F150 4x2
  117. Normal Temp's 91 f150
  118. Tow capacity on a 1990 F150 302?
  119. 85 f150 2" lift with 33's?
  120. stearing coloum problems on 89 F-150
  121. valve covers
  122. Battery corrosion
  123. shaking at 35 mph
  124. serpentine belt help!
  125. Cruise Control Module/Amplfier
  126. 95 F-150 6 cyl. Pwr Steering Hose replacement
  127. lockout hub o-ring?
  128. B&M shift improver kit?
  129. 94 Ford F150 issue
  130. Oil in Water
  131. Need help on a 94 F150 XLT
  132. 89 F150 stalls when warm
  133. no power to fuel pump after new tank/fuel pump
  134. tuesdaa rant
  135. 56 F100 stock tire size?
  136. flexplate
  137. Scai
  138. Thinking about building a new engine for the 93
  139. Help with snow plow
  140. NEED HELP! 92 ford f150 XLT.
  141. Check Engine Light
  142. Starts and stalls
  143. 1996 F-150 2wd Lug measurement
  144. code help
  145. new guy build thread!
  146. alternator help
  147. Went to the country house today to start the old truck
  148. 4.9 with no fire
  149. got some pics of my truck! new to forums!
  150. new truck pictures (thanks patman)
  151. Plans for my '94 - help
  152. 1974 F150 4x4
  153. pin ups
  154. 1985 F-150 Fuel pump/tank ????'s 5.0 EFI
  155. my window wont go up!
  156. 86 f150, 302.. Help Or Im Gonna Kill It!
  157. Clutch 1995 F150
  158. 82 f100 loading up
  159. Shifter Arm Question
  160. Who can I.D. this spring?
  161. Now how about them brakes...
  162. Fuel pumprelay 96 F150
  163. what are you 5.0 guys doing for lots of HP?
  164. 1996 F-150 insturment cluster
  165. Signal lights not working
  166. '96 F150 I-6 (300 cid) cooling fan?
  167. Proper way to disengage 4wd (auto hubs)
  168. Question About Heads
  169. is this possible?
  170. help
  171. mirror replacement
  172. Vacuum Diagram 1989 F150 5.8 351
  173. New guy with "new" old truck
  174. Anyone need a Massair conversion kit???
  175. Questions about my '87 XLT
  176. Almost traded my 92 F150 "Cash for Clunkers"
  177. whistling sound?
  178. left side lower quad shock mount
  179. 1983 F150......What's that Carburator??
  180. 1994 f-150 sas
  181. Newb needing Trans Insight
  182. 1996 F-150 Radiator, wrong part?
  183. Towing Capacity, 1996 F150
  184. 81 F150 no dash power.
  185. aftermarket tranny cooler??
  186. 5.0 Upper Intake Manifold Removal
  187. quick hypertech question
  188. Put it in 4x4 now pulls to the left
  189. how do i remove hub to remove rotor?
  190. help with 1978 F-100 6cyl
  191. Lift?
  192. 1993 Ford F-150 XL Reg Cab 8' bed Towing Capacity?
  193. gagues
  194. 1990 4.9L. Fuel Delivery Problem
  195. 1991 302 with not idle
  196. Tailgate trim panel clips
  197. 1977 F150 400 vacuum diagram
  198. replacing wiper assembly
  199. Clutch Question
  200. Need to Regear?
  201. 1950 f100 build
  202. Urgent - Please Help - Been driving with the tranny dry
  203. 87 5.0 won't cold start
  204. Threaded Intake Bolt. Help!
  205. what years have the same bed ?
  206. Carb Flooding out *Edelbrock
  207. swapping from carburetion to fuel injection
  208. 1995 F150 XLT Bogging Down
  209. 1990 f150 headlight problem
  210. Starts, Idles, Put it in gear dies
  211. 89 F-150 firing problem.........
  212. 87 5.8L F150 -- belt/pulley info???
  213. Replaced plugs...now not turning over
  214. Factory leather wrapped steering wheel
  215. Melted inner wheel well liner
  216. 93 f-150 6 cyl cold start problems
  217. New Guy
  218. How much difference will I notice?
  219. Warm starting problems
  220. Alt. Gauge Jumps, truck dies!
  221. 90 f150 5.0 2wd
  222. Aftermarket Power steering pump
  223. 96 e4od to 91 pickup
  224. AC Clutch 1998 F-150 4.2 V6
  225. a sound i never wanted to hear
  226. New guy... Richmond, VA
  227. How much temp drop?
  228. Rear Brakes Lock UP
  229. 94 vs 95 E4OD, compatible?
  230. Air Pump with Aftermarket Converter
  231. 1996 OBD-II Code Reader Problems
  232. Speedometer Issue!
  233. HID kits
  234. 1995 Oil Level Issues
  235. Replacing Fuel Injectors
  236. 1990 F150 Codes
  237. Bumper Identification
  238. 1993 Flareside!
  239. Can a spark plug spark not grounded?
  240. 1987 F150 intermitant running
  241. lots of play in the steering?
  242. 1.7 Rocker Arms
  243. Fixed my cig lighter!!
  244. Mirror Cracked :(
  245. 83 F150 Worth Buying?
  246. MAP Sensor
  247. stereo wiring
  248. tourqe converter shudder 91 e40d
  249. 1996 leaking power steering fluid
  250. 94 stalls intermittently
