View Full Version : Pre-1997 Models
Pages : 1 2 3 4 5 6 7 8 [9] 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25
  1. Is it normal over time???
  2. Oil Leak ?
  3. New to the board and had a few ?'s about my new 92 F150...
  4. Tranny bad because it didn't have the kickdown hooked up?
  5. Coffee can thingy..
  6. Automatic Tranny Hard Shift
  7. 5.0 to 5.8 engine conversion...computer question
  8. 86 F150 Fuel Pump info needed
  9. Manifold pressure.
  10. Surge??????
  11. what wires go to what speakers
  12. What's with the brake lines?
  13. A Couple Small Electrical Questions
  14. Lightning Fog Lights
  15. replaced steering gear, steering is way off
  16. Need Help, Swapping cabs
  17. Data Connector on 96 F-150
  18. New springs need help with bolt size
  19. pipe diameter for dual exhaust on 302
  20. Bundy fitting for 80's fuel line?
  21. egr pipe
  22. Bench to Buckets?
  23. My 1993 F-150
  24. Charging/starting issues
  25. 96 302 FI for Carb swap
  26. 94 F150 DIFFERENTIAL gasket replacement
  27. 302 to 351 swap....Info on 1990 351W
  28. Where is 1990 F-150 Fuel Pump Fuse
  29. patience is running really low....
  30. 94 4.9 Injector Question
  31. Did the '90 f150 have....
  32. Charging Issues
  33. Adjusting Throttle Posistion Sensor
  34. Replacement muffler
  35. 95 F-250....
  36. Popping thru carb after rebuilding 351W
  37. How far can I mod a speed-density system?
  38. '95 5.8 Questions
  39. Best way to level
  40. Roller cam or not?
  41. the mighty 300
  42. 4.9 vers 5.0
  43. ok, new clutch in, and tranny back up
  44. Clutch kit/ Autobody shop.
  45. 1995 Ticking & Missing on Accell
  46. Anybody ever repaired fiberglass top on Bronco?
  47. 4X4 won't engage
  48. 96 f150 4x4 trany question?
  49. Yet Another Gas Mileage Question
  50. ok guys, one more question (torque spec's)
  51. Better grounding? Rewiring?
  52. Steering Wheel
  53. how to disconnect slave cylinder hose?
  54. Pictures of seats in your trucks (request)
  55. IAC Votage ?
  56. Just bought my first used truck
  57. Audio set up on 95 reg cab
  58. master cilyner now slave cilyner??
  59. 5.0 Throttle Body Cleaning
  60. pointers wanted...
  61. A few questions
  62. rough idle
  63. Ouch!
  64. New Negative Battery Cable......Location
  65. 96 f250 351
  66. new to site
  67. My Truck Knocks
  68. another ? about a/c compressor clutch...
  69. 95 Won't Start. Need Help.
  70. mustang headers on a f150
  71. 95 f150
  72. Fast Idle
  73. A/c compressor???..
  74. locker or limited slip
  75. airbag diagnostic module
  76. clutch help... opinions wanted
  77. snorkel for 95 f150
  78. 96 F150 just clicks
  79. ABS Problems
  80. 88, wait 30 min before starting
  81. Some 302 problems
  82. '95 F150 Ball Joints For Dummies (By An Idiot)
  83. Looking for oil pan
  84. Horsepower Q's
  85. Emergency Brake light switch, Need Part# or link
  86. Has anyone converted there F-150 to 5.0 HO?
  87. Help truck shutting off
  88. Looking for an after market fuel tank replacement
  89. F150 bumper?
  90. 94 F150 headlight bezel removal
  91. Now What?
  92. 95 F150 (300I6 Manual) slipping out of 5th
  93. confusion at the dealership
  94. Engine temp
  95. Starter
  96. Throttle Cable Removal
  97. Fuel pump woes
  98. grille
  99. Wire connections to starter relay
  100. Regarding the Brake Pedal on a 1994 F-150.
  101. starter problem
  102. 85 f 150 trannie help
  103. Exhaust cost
  104. Need Help: Removing the fuel rail lines
  105. Feul Filter is confusing
  106. leaf spring shackle
  107. Improve gas milage?
  108. Ball Joints
  109. Cold air intake setup?
  110. beefy suspension
  111. please help
  112. 95 plastic radiator
  113. bed sitting crooked
  114. Oil pressure problem? won't start,
  115. Do I have ABS or not?
  116. Upper Ball Joints
  117. resurecting the F150 Help & advice needed
  118. Can help Identify?
  119. 95 F150 oil pressure problems
  120. 96 5.0L F150 running like CRAP
  121. Idle crazy on 94 f150 with a mustang HO swap
  122. Clutch catches 1/2 inch from floor
  123. Setting the timing...correctly 90 5.0
  124. oil pressure problems
  125. 1995 looses oil pressure
  126. It finally breathes!!!
  127. knock when exiting
  128. Fuel pressure 0 psi after shut down
  129. Weird Fuel Gauge problem
  130. '94 5.0L Temp guage shorting??
  131. 351M Reasons for failure?
  132. 96 F150 Serpentine problem
  133. 93 F-150 surging and running bad
  134. 85 f150 with 391...lookinf for manual
  135. broken coil spring
  136. EEC OEM / Autozone #
  137. speedometer location
  138. Anybody looking for March pulleys or alternator?
  139. tosted clutch?
  140. 5.0 & 5.8 flexplates, any difference ?
  141. Need info from Pre '97 owners
  142. manual vs auto hubs.
  143. 1990 4.9L Will not start
  144. 351M to inline 6 swap
  145. 1992 ford f-150 transmission type?
  146. Brake Upgrade
  147. Code Reader Where Does It Go???
  148. Pre-1997 F150 specifications
  149. Stock fuel pump rating?????
  150. Auto to manual hub change
  151. 1993 302 Soundin Bad
  152. Cost for Brake job in Dallas Area
  153. 1990 F150 w. 302...what is needed for 351 and has anyone done it
  154. Changing plugs
  155. my '87 5.0 still pings
  156. marker and surround removal
  157. 04 heritage radio size...
  158. 93 explorer
  159. 1991 F150 with 420K miles Need Help
  160. 90 5.0 no spark
  161. One fuel pump or two?
  162. surging cruz control
  163. Finding codes
  164. MIL light on throwing code 989
  165. Is it the fuel pump?
  166. 351W is almost ready, need guidance....
  167. 33 x 10.5's on '93 4x2??
  168. 1991 6cyl 137,000 miles
  169. 1986 Ford F-150 302 -- Is she going to pull through??
  170. Dead Truck
  171. Rough Idle (92 f-150)
  172. Which mustang parts fit? supercharging it!
  173. removing the top from a Bronco...
  174. 91 5.0 f150 exhuast size?
  175. Clutch problem
  176. 1991 Ford 150 custom question
  177. 94 F150... ram air?
  178. Some Power loss
  179. Transfer Case in 85 F150
  180. alternators for my 86 HO
  181. 96 fuel problem, slow or no start?
  182. 89 f150 no spark problem Please Help
  183. Help with an 88
  184. Rear Window Replacement
  185. M50D 5-speed parts source?
  186. maintenance questions
  187. welding on truck
  188. Dual shock 4x4 front axle question
  189. 1989 F150-no spark
  190. 86 F150 W/T6 Trans... I think?
  191. Snorkel
  192. 1977 F150 4x4
  193. Bronco top off
  194. Cab Lights for F-150?
  195. Best Exhaust for an I6?
  196. Fuse box under hood?
  197. Brake Line Leaking
  198. changing gears
  199. Wanted:: extended radius arms
  200. 91 F150 Ignition Timing Frozen --won't advance.
  201. Removing steering wheel
  202. Is my 1995 F-150 Standard Cab SB 4x2 worth repairing?
  203. Online Parts Suppliers?
  204. Changing Rims?
  205. extended cab window swap?
  206. Air in Fuel Line
  207. Hard start issue
  208. OD light blinking
  209. o2 sensor question
  210. 86 f150
  211. Dang plastic radiator parts...
  212. replacing instrument cluster
  213. Running Rich/Runnung Cold...
  214. Rusted Brake Line.. Helllllllp!
  215. 4.9l chip/tuner
  216. seats,seats,seats
  217. adrianspeeder type ?
  218. 95 turn signal/wiper arm loose
  219. '89 headlight knob removal
  220. help adrianspeeder
  221. switch from 75 amp. to 100 amp
  222. 94 F150 E4OD Downshifts from OD too often
  223. 96 F150 engine specs
  224. bird chirping dash
  225. 92 F150 mods
  226. steering wheel not centering properly. alignment? what would this issue be...
  227. Wheel hop and tire spin
  228. 95 F150 clutch
  229. Speaker boxes
  230. Location of ECM in 94 F150?
  231. 1989 f150 302 question
  232. limited slip or non...
  233. f100 to f250
  234. 1975 390/C6 ?'s, "mostly" vacuum related...
  235. What Should All This Run Me...
  236. 73-79 F-series info...
  237. need more amps
  238. New Member New truck...kinda
  239. 93 F150 4x4 only gets 14MPG! HELP!
  240. rumbles at 35 - 50 mph
  241. 4x4 non-limited slip converted to LS? Possible?
  242. 1990 F150 5.0 Lt. ??? Remove Oil Pan???
  243. Rattle and bubbling when on the throtle???
  244. value of a truck with a blown engine?
  245. cruise lights
  246. New Guy, TPS Question
  247. ever heard of a XLS
  248. Topper 4 Sale
  249. 1995 F-150 FlareSide... Slow from stop, I mean really slow to get moving!
  250. 4.9 I6 Gas mileage
