View Full Version : Pre-1997 Models
Pages : 1 2 3 4 5 [6] 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25
  1. Transmission fluid change
  2. 1992 F150 4x4 Project Truck
  3. Airbag light blinking code 51
  4. 93 F-150 Gas Mileage
  5. 76' 390 specs?
  6. simple brake question
  7. 5.0 Vs 5.7
  8. Help! trouble after PCV change
  9. Click Click then nothing....
  10. 90 bronco ignition switch
  11. buying a truck..just need a few opinions
  12. buying a truck..just need a few opinions
  13. 92 302 V8 - Stumble off Idle
  14. Seeking Older Parts
  15. Engine Swap
  16. Crazy winter weekend weather (but makes for nice pics)
  17. Opinions please!
  18. Your Old Truck Pictures and upgrades/mods
  19. Using way to much gas
  20. I'm looking for a rack.
  21. Door Lock problems - 91 Ford F150 4x4
  22. Vanity Mirror Removal
  23. Converting an F-150 into a 3/4 ton
  24. 93-95 Ecm
  25. Help Identifying this Model...
  26. engine removal help
  27. Questions on replacing gas tank...
  28. Bulletproofing 95 F150 4x4 351W
  29. '93 F-150
  30. Hay guys!!! Look at E-Bay!!!
  31. Where to get seats
  32. 1992 F150 5.0L V8 302 Engine knock or ping
  33. Stupid drivers
  34. ranch hand/off road bumpers
  35. fluid leaking from top of man. trans
  36. Clutch dragging - '95 300/6
  37. Is this my core support that's rusted out?
  38. 1993 F150 sputtering problems / engine light @45k
  39. replacement headlight knob
  40. Weird engine
  41. engine/transmission removal
  42. new crate motor, old ignition won't start
  43. exhaust system or muffler
  44. Steering Wheel Replacement
  45. Side Mirror Rattles...
  46. Sludge In The Intake And Throttle Body
  47. Shes mad, it wont start
  48. Radius Arm replacement, lights
  49. manafold replacement
  50. 88 Running again: Funny story.
  51. Parts for sale
  52. stearing noise
  53. Underdrive pully belt?
  54. fan removal
  55. 351W redline
  56. M5OD plugs
  57. Door Lock
  58. ford with chevy axles?
  59. need help!!!oxygen sensor question 5.0 347 302
  60. Please Help, Stumped Everybody
  61. speedometer jumpy....
  62. 92 Accessories resources?
  63. 87-91 Cluster
  64. headers for 1996 f150 5.0L
  65. Sway bar worth it?
  66. No Spark-----EFI
  67. Restoration Parts
  68. Front main seal replacement?
  69. Clunk in 4 wheel Drive when turning
  70. Code P1151 and a few questions
  71. Tach
  72. Oil for 95 F150 with 300 I-6
  73. "Princess"
  74. rim width
  75. Tranny Cooler Lines
  76. Plastic front air dam...
  77. ignition switch problem??
  78. converting EFI to Carb
  79. Catalytic Converter Heat Shield
  80. Squeaking clutch.
  81. coolant/egr system idk
  82. speed sensor
  83. Knocking noise '96f150
  84. Clicking in tranny?
  85. Battery Light
  86. Truck Types
  87. Hell is the filter?
  88. Need help finding computer code
  89. High Clutch Pedal
  90. 1994 F150 fails emissions test
  91. 93 5.0 either tranny or engine problems
  92. '88 f150 no heat
  93. 94 F150 wiper switch having problems
  94. 1996 ecm code
  95. Ebay Performance Chips
  96. Thinking of an extended cab F150...any suggestions?
  97. 33" Mud Tires In A Stock 94 F150
  98. Which Lift Kit?
  99. sound like only 5 cylinder works
  100. Turning on headlights kills Engine
  101. Dashboard Light 94 xlt
  102. headers to twice pipes
  103. fog lights?
  104. Remote 6 CD Changer
  105. Exitor ring
  106. Air-Oil seperator
  107. K&n Fipk
  108. Steering Box Lubrication
  109. Rear tank pumping gas into front tank?
  110. Very Rough idling
  111. Oil Pressure sending unit / switch
  112. distributer location
  113. Transmission/Clutch Slipping When Accelerating?
  114. egr problem, 89 F-150 302
  115. gaslines
  116. Easy And Cheap Mod For Non Tach Trucks
  117. what is the correct fuel pump pressure
  118. Headlight removal on '94
  119. Power Sliding Rear Window
  120. how can you tell
  121. Truck Build Date Per Service Manual
  122. Front tank won't take fuel.
  123. new fuel pump won't stop running
  124. Best source for pre '97 F150 parts and aftermarket parts?
  125. thanks for the help but
  126. help, it wont turn over(5.0)
  127. 1994 f150, front turn signal replacement &...
  128. Replacement shocks, which to choose?
  129. Mini Spool
  130. Squeaking drive belt
  131. Low miles
  132. Help! No Heat
  133. Cost to replce engine in 1990 F150 4x4
  134. Question for you guys
  135. Captain Chair Cloth Replacement
  136. Towing Power???
  137. Engine swap
  138. looking to restore my 85
  139. looking to restore my 85
  140. compression
  141. 91 F150 stalling
  142. Where is my IAT
  143. Mass Air Flow Conversion
  144. Ways to convert SD to MAF?
  145. Seat belt blocking
  146. 1989 f150 4x4 clutch
  147. Ways To know if its your Throttle Position sensor causing Problems
  148. changeing heat vents
  149. Need new window seals?
  150. spout
  151. oil pressure problem?
  152. How to clean tps/erg/iac valves
  153. heater problems
  154. 2wd 6in. lift
  155. Fender Removal / Replacement
  156. Help reading codes please
  157. Tranny Takes Long Time To Shift Into Next Gear
  158. Help Please - Smog Question
  159. i cant figure this 1 out
  160. Bleeding Brakes: Rusty Rusty Bleeders
  161. SENSORS: Maintenance and/or replacement
  162. Power windows
  163. exhaust system 88 4.9L
  164. 4.9 idle probles
  165. hood latch
  166. 95 E150 Steering Box Leak. Help!
  167. 92 F150 e4od auto
  168. Overheating when heat is on
  169. Help identify pipe from the back of the engine!!
  170. 90 bronco cluch problem
  171. ordered true duals today
  172. broken steering column....?
  173. What's it worth...
  174. door sticker
  175. gearing
  176. 82 F150 runs really rough when cold
  177. Charging system woes
  178. 77 4x4 drive train question
  179. Any 94 shortbox out there
  180. Header ?
  181. Removing f-150 healight
  182. Trans problem
  183. oil guage
  184. New to the boards...problem help
  185. Thermostat or Water Pump. Need Advice.
  186. Swap: Auto hub to Warn locking hub. Worth it?
  187. Cat-back duals on a 4.9, need advice
  188. Code question???
  189. Aftermarket Headunit
  190. 92 f150 dual gas tank problems
  191. 94 towing power
  192. UGH...check engine light...
  193. New member here with a '96 F-150 XLT 4x4
  194. 92 F-150 Won't Start
  195. OD light steady on in handle, wont go off
  196. 460 vs diesel
  197. From good times to hard times...
  198. 1993 f150 body lift problem
  199. 12v outlets not working
  200. wondering
  201. problems starting 95 F150
  202. [large pic]'95 F-150, I've really done it now...
  203. Need help with value with a 1975
  204. '94 CD Player
  205. 82 F150 Front Axle removal??? HELP!
  206. 1993 F-150...turn signals arent working
  207. Front Manual hubs question. TTB front end.
  208. Anyone ever do any driving on sand dunes?
  209. Harsh Shift
  210. First engine mod
  211. 1990 F150
  212. code p0401
  213. Dual Tank Question
  214. Ok... now what?
  215. Still starting problem
  216. Door lock solenoid. How to remove?
  217. Dragging Wheel
  218. manual trans. leak
  219. Speedometer/Cruise Problem
  220. 100,000 Miles on '94
  221. gas tank
  222. 1988 F150 engine problem.
  223. '95 with E4OD MESSED UP!
  224. Vent/AC/Heater not working???
  225. Power Outlet 92 F150
  226. quick silly question
  227. Battery light question
  228. '89 F-150 5.0L Oil Pressure Gauge Malfunction
  229. wiper switch
  230. 1994 F-150, to buy, or not to buy?
  231. scan tool
  232. Ticking noise on left turns
  233. Some upgrades in the works:
  234. exhaust questions
  235. Sweet Grille?
  236. 1991 Won't Start. Please Help!
  237. Production date...
  238. Mild Lift
  239. Rear End
  240. PCV valve location on 89 F150
  241. Only have high on the heater...
  242. 92 no start
  243. Stumbling motor almost gets me killed???
  244. Cleaning Injectors
  245. noises driving me crazy
  246. Sticky 2nd Gear
  247. '87-'88 Inline Hi Pressure Fuel pump?
  248. 302 Head Compatibility
  249. help with gas milage
  250. another dual tank question
