View Full Version : Pre-1997 Models
Pages : 1 2 3 4 [5] 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25
  1. C6 to AOD swap
  2. sas from 78 bronco
  3. DTC Terminal for Check Engine Light Codes
  4. Wheel lug threads
  5. oil capacity
  6. 4.9L knock on start up?
  7. Rear brake shudder
  8. 96 F150 Flowmaster or Magnaflow??
  9. Headliner removal
  10. Leaking Warn Manual Hubs - Suggestions?
  11. Looking for piece of aluminum that goes on the tailgate of a 95' F-150?
  12. 6spd w/ a 351w
  13. 1991 f150 no start. Dual Fuel tank sender switch? What is it called?
  14. It runs,then dies...
  15. Transmission Fluid Change Questions
  16. just out of curiosity
  17. Fuel Pump
  18. Fitting 35's
  19. My new 85 F150, when it finally gets here
  20. 94 f150 4x4 ball joints
  21. Truck will not start 92 f150 5.0
  22. F-150 Gear Ratio
  23. '87 Stepside
  24. 88 f-150 4.9 belt and fan problems
  25. Suspension Differences
  26. 1992 F-150 powersteering/tranny whining.
  27. Dashboard Diagram?
  28. Error Code ( Audible ) Very Strange
  29. Max Weight Of Travel Trailer
  30. I need help!
  31. Just bought a new truck!
  32. Non-stock Head off something,
  33. Exhaust problem on 1996 F-150 (PLEASE HELP!)
  34. Rusting oil pan on 95 XLT
  35. AC/heater blower ???
  36. need some advice
  37. '93 XLT-couple ?'s
  38. Valve cover gaskets...how difficult are they?
  39. Lift Kit for 92 2WD
  40. 300 and 302 motor questions
  41. help with starter sylanoid please
  42. lifting
  43. 87-96 Front Cross member
  44. ABS light and driver door problems
  45. 1995 f150 2wd 4.9 I-6 gas tank
  46. Fuel Pump
  47. axel spline count. 8.8 rear end
  48. Spare Tire Winch
  49. air pump delete
  50. New MAF, New Temp Sensor, and Grease
  51. Rotor/Hub Assembly Question?
  52. Got a 95 f150 5.0, whats up with the 235 tires?
  53. 300 Engine / part Question
  54. setting timing on a 4.9 300 cid 6 cyl.
  55. relaced ox and maf
  56. Hoods
  57. Sirius Radio Install
  58. oil leak !!!!!
  59. Change Flywheel
  60. stalling during traffic Jams
  61. 95 F150 XL 5.8L - Fuel pump noises and possible coolant issue.
  62. Mazda 5 speed to ZF swap
  63. Problem with windshield wipers on my 94
  64. Thump on acceleration from a dead stop
  65. Opinion on installing a locker
  66. Help! boiling enigine
  67. Coil- No Spark- 1992 302
  68. Gas Tank leak question
  69. 1993 lightning. major issues with gas tanks
  70. S/D to MAF - smog check issues?
  71. 1988 F150 Sending Unit Floats
  72. Drive Shaft and "F-50 Sport" Question
  73. O2 sensor questions on a 300 I6
  74. No Caliper Clips on pre 5/95 1995 F150
  75. Going X-country
  76. 92 F150 power window problems
  77. Poping/Clicking when turning
  78. hot/ignition wire
  79. Brake Caliper - Phenolic Vs. Metal Piston
  80. CB install
  81. egr code errors
  82. Replacing fluids in 1994 F-150
  83. K&N FIPK Kits...
  84. Steve!!! :)
  85. Rear ABS light
  86. 4 wheelin fun, Broken motormount
  87. f150 single piston caliper vs. f250 dual piston
  88. replacing ac compressor on a '87 F-150
  89. Lifted Pics
  90. Toolbox
  91. help evg errors
  92. uh oh!!! New sound came up!
  93. Where does this hose go?
  94. need help with gear ratio sizes?
  95. What do you guys recommend?
  96. Questions and help about swapping stuff around
  97. Servicing the cooling system
  98. Spark Plug Wires & Stuff
  99. master cylinder rod
  100. 1994 Bronco vs. 1996 Jeep Cherokee bolt pattern
  101. Center Cap compatibility
  102. 1995 F150 XL - Used Buy Checklist
  103. oil perssure gauge
  104. Seat covers?
  105. FYI: Hurst Shifter Install
  106. Brake line went, need some advice.
  107. Putting a/c in a non a/c truck?
  108. 1995 5.0L EFI backfiring after tune-up
  109. Replacing Door Weatherstrip by automatic windows.
  110. 1996 F150 manual locking wheel hub disassembly advice...
  111. 92-96 OEM Chrome Rear Bumper (Surestep)
  112. power locks and windows
  113. 93 F150 I6 or 93 F150 302
  114. straight 6
  115. tire style musical chairs
  116. 1993 F150 issues ( coolant temp switch ) ( problems after 20min of driving )
  117. Replacing shocks
  118. Removing radio
  119. Fender mouldings
  120. codes and other stupid topics
  121. Pushbutton an Option?
  122. OD and Cruise Control Issues
  123. gear change
  124. GT40 VS GT40P Which heads are better?
  125. strange Codes
  126. New cabs anyone?
  127. Fuel Economy on a 7.3L TD
  128. Fuse box diagram
  129. Starter wires
  130. wanna learn how to work on trucks w/o a role model
  131. Fast idle speed on '92 302
  132. IT AINT MY TRUCK(is a chev)
  133. Slight tilt to the left
  134. 1994 F-150 replacing twin I-beams for a more modern setup?
  135. Mystery part question...
  136. 95 150 Start up problems
  137. 5.4 3v (TRITON) swap into a 91 f150
  138. 1992 Re-Build
  139. mystery engine problem.... help
  140. Maybe some one will answer me here
  141. noob says hi, and temp sender q
  142. Center Caps?
  143. dam auto hubs
  144. Steering column replacement
  145. problems with charging system
  146. Best place to tap in for switch power???
  147. Need stock leaf springs
  148. Looking at buying a 1993 F150
  149. rear end codes
  150. Exhaust tick, Idle issues
  151. Piece of random metal...???
  152. Manual Hubs Question
  153. Fuel tank selector switch
  154. 93 F150 4x4 shift pattern
  155. 94 F150 oil leak
  156. side mirror rattles..
  157. '94 F150 cruise control in-op
  158. Rear brakes or axle help
  159. 1995 f150 speedometer stopped working
  160. Removing Ugly Ventshades
  161. tie rod ends
  162. aod shifter
  163. Torque in the low range
  164. roaing rearend
  165. Need customizing suggestions for an 86 f150
  166. Shaking at higher speeds
  167. Newb Checking In!
  168. Questions about some mods for my 93' Flareside
  169. Which tranny?
  170. ZF Trans in 4x4 F150?
  171. 1985 f150 problems
  172. Brake repair question..
  173. Pics of 2" body lift....
  174. Looking to buy a 92-97 F250, anything i should look out for?
  175. Engine problems 91 F150 5.0
  176. Engine problems 91 F150 5.0
  177. 1997 F250 questions (1992-1996) body style
  178. 1997 F250 questions (1992-1996) body style
  179. Cannot Fill Rear Fuel Tank
  180. 1992 F-150 - Replacing the Power Steering Gear Box
  181. swap 8.8 to a 9.75 on a 95 F 150
  182. front x suspension on 89 f150
  183. djm drop kit
  184. Stalling/Intermittent Start on 95 302
  185. Installing a tach in a '90
  186. Front Lower Shock Bracket stud broke.
  187. 92-96 owners, anyone using the after market clear projector headlights?
  188. Show off your pre-97 Ford trucks
  189. Can you ID my rear axle with the tag?
  190. belt lenght after smog pump is removed & recomendation on intake
  191. Buying '92 from "Friend" questions
  192. hooking up a tach
  193. warn hubs
  194. need help with 4x4
  195. It's conversion time!!
  196. turbo for 300 CID 4.9L I6
  197. Turbo F150 project.
  198. 95 F150 4x4 XLT Rear Gas Tank
  199. Vacuum lines suck
  200. 4wd Problems
  201. 31" plus tires
  202. Hoop Steps
  203. O2 Sensors
  204. How do I remove the headlight switch?
  205. Changing U joints
  206. 94 Trans upshifts too soon - tire size issue?
  207. 6.9L IDI swap into a 92-96 F150 4x4
  208. vacum line harness, any one made one??
  209. AOD tranny wont downshift
  210. EGR question...
  211. need help finding leak
  212. remote start
  213. Auto to Manual Hub Conversion
  214. Couple questions
  215. Coolant Leak - 92 302
  216. Tires on a 94 4x4
  217. coffee can like filter?
  218. Trans wont seporate
  219. Transmission Removal Help
  220. Steering wheel removal help
  221. i got my mufflers!!
  222. Factory tire size
  223. Engine ?
  224. Really wierd problem. Help please!
  225. 94 F350 project
  226. 90's F250?
  227. 88f150 to 81f100 swap
  228. How do you test the fuel regulator?
  229. 390 known problems?
  230. Rear Leaf Spring Bracket Questions
  231. Best mods?
  232. Carpet question...
  233. 1985 F150 lowering
  234. Programmers and Tuners
  235. Output shaft bushing
  236. Shaking off the line - Need help bad!
  237. Shift lever getting hard to move
  238. Battery cable corrosion
  239. 91 F-150 Rich Exhaust - Got These Codes
  240. plastic oil pressure gauge feed??
  241. Front end "Pop"
  242. 5.0 engine woes
  243. 1988 F150 Fuel Gauge Problems
  244. Fuel filter-1, Me-0
  245. EGR Valve - '93 XLT, S-Cab, 4X4
  246. Transmission/Sensor Woes
  247. 5.0 Mods?
  248. yo
  249. Roll Bar?
  250. replacing CORNER Lamp bulb
