View Full Version : Pre-1997 Models
- Bad Catalytic Converter?
- 88 F150 digital clock
- Just changed my fuel filter
- help me figure this out, please!
- Tar Troubles...
- Chalk one up for the Pre-97's!!
- 92-96 interior door panels & Lightning jump seat
- Clicking brakes
- Pinging 302
- Anyone with a lowered 92-96 F150?
- 302 Project - Need Advice !!
- Signmaster- FIPK, part three
- Signmaster- FIPK, part two
- Signmaster- FIPK pics, part one
- Sudden performance drop?
- oil sending unit
- free mods?
- motor shakes rattles and rolls ....HELP!
- Exhaust Leak
- Any EEC tuners out there?
- wash my engine?
- Rotors and Calipers
- Starter, relay, or cable?
- 92-96 300 inline 6 cyl.
- anti-lock Brakes #%&%@%
- 95 Questions(2)
- posting for a friend
- pre 97???
- Wierd Noise on Modded Ranger
- 53 f150, 302 transplant, HELP
- New Pics
- Maintenance questions
- help
- how many ponies here??
- timing
- Ford F-150 Acceleration?
- rebuild, or new?
- how much $$$ ?
- manual tranny
- Why do you think Ford offers mega rebates?
- WANTED: Edelbrock EFI Truck 5.0 Intake!
- interior
- putting diesel in a 1996-older 150??
- 3 leafspring clunk?
- EEC Codes and High Idle
- upgrade to LS
- 92 Ford Explorer
- Computer Problems?
- PCV on a 96 4.9 I6?
- Tailgate
- Mass Air
- tranny question
- Clear headlight lenses?
- have k&n off 94 f-150 that will fit any small block
- Value of a 94 with a 4.9L I-6
- powerslider rear window problem
- need a new clutch soon
- 96 F250
- 96 F250
- poor response under no load
- hey dvldog458...
- Headers
- help me setup my exhaust!!!
- bucket seats
- code 51 on air bag light
- Temp Gauge Accuracy
- '91 F150 rough idle, clacking
- help with adjustable fuel pressure regulator.
- K&N Filters.......just the FACTS please!
- Which year '91-'96 to BUY???
- Sick of yellowed OEM headlights
- 96F1504x4 NEED ADVICE PLEASE!!!
- Valve cover breather location
- white faced gauges
- aftermarket gauges
- 96Ford buying advice
- f 150 marker lights
- Is it worth it?
- HELP ... Vibration in truck ...
- 300 to 351 swap
- 4 x 4 Question
- 1991 F-150 Repairs
- Stutters shifting from 2nd to 3rd
- 1996 Fuel Filter
- 93 Temp Sending Unit
- Suggestions for an '84 F-150 XLT?
- 1993 4.9 tune up suggestions
- Relocating fuel filter, 1992 Flareside
- Clutch Master Cylinder
- 1994 speedometer calibration
- interchangeablility of campershells
- Oil leak on 95 150?
- hook up sony cd player
- Difference in 302!!!!
- a-pillar gauge pods
- H.p.
- 88 f150 eng swap
- Early '90s manual trans question
- Mass Air in the 460?
- adjustable fuel pressure regulator
- top speed limiter?
- 1978 truck into a 1976
- Easy But Effective Bolt-On Mods
- 302 information
- Mustang engine in an F150?
- 302 horsepower?
- New here,got a ?:How rare are 1978 short bed SuperCab F150s?
- Fails to Start
- 1996 fuel tanks capacity debate
- 1960 F100 Panel Truck
- Steering Wander on a 1994
- 5.0 (non H.O.) mods
- Oil Pans
- Performance mods for 300c.i.d. I-6???
- no good 4sp
- Engine light
- Truck weights......?
- Largest tire for 95 F150 4x4 (stock)?
- ABS Light
- hey dvldog458...
- Fuel pumps failing in hot weather
- Bassani Exhaust
- H.p.
- 0-60 and 1/4 times on 300l-6??
- Starter or cellenoid going bad?
- Speed-o-meter Calibration
- K&N and 302
- Tracking Problem
- Extremely Pre 1997 Ford Truck!!!!!
- rear end chatter
- how much for a gear swap?
- engine swap: efi -> carb
- Need a 7 Blade Fan
- Appraisal
- 300 exhaust
- Air pump on 96 F-150
- How many quarts?
- Bloomsburg PA
- parts
- 302 Performance
- 4.9Liter 300cid. Inline Six Info/Modifications?!
- gas tank overflowing
- 302 Towing Question
- Trouble with my F150-93: I-6 ...tranny problems...
- how to or does my truck have tilt steering wheel
- Fuel Mileage isTerrible
- no spark
- Bad volt gauge?
- Casper Electronics and hypertech
- Ford Recall Question
- Tach install
- Removing a Radius Arm Nut
- Does anyone know how to remove and replace a fuel float
- Locating the PCV valve
- Replacing Settring Box
- Codes for trans and rear axle
- Another dual question
- Grinding in 3rd gear only!
- Question for DOUGH
- Clutch Problem:(
- 1987 F150 runs rough
- lost phone in defrost vents!
- Center Console cup door
- Synthetic Oil in 302
- Won't start
- 300 I-6 Questions???
- 300 upgrades
- Mirrors?
- Anyone have a Ford frame spec book?
- Future F-150 S-cab Shortbed 4x4 Rebuild
- Thanks
- Need advice with 1992 Truck
- Hey.....Pastmaster
- Cat question for Fadex
- Accell Super Coil
- Which years are easy swap with 1985 302 EFI?
- Need to upgrade seat belts
- 302 modification questions
- What plug wires?
- post for Jimbello
- MOTORSP[ORT GT40 IN A F150?
- whing noise from rear end
- 302 bolt on power
- Do I need new shocks?
- Cleaning under the hood?
- Spark test - Electronic Ignition
- "PRO-FLOW" MAF CONVERSION?
- need to wake engine up
- 302 SWAP FOR CARBURETOR 460
- 100,000 Mile Club - 1995 F150 XLT
- 1990 F150 with loud knocking???
- Shop manual for 1987 F150
- 2001 hd f150 roms on 92 f150, can it be done????
- Supercharger
- Who has 4.9,5spd,31" tires,3:73gears?
- Lost 1st & 2nd Gear 5spd man.
- Gear Question
- Gear Question
- Roll Cage
- Factory Trailer Tow package connector
- 94 F150 w/ 302 pinging bad?
- Loose power steering fixed!
- Vibration in Steering Wheel on braking
- Anybody with 4.9 and 3:55 Gears?
- Hesitation when hitting the gas
- Trouble Codes
- THE LOWEST GEARS IN A DANA 44 IFS
- Stang 302 into 92 f150????
- Blinkers?
- 1/4 TIMES
- Three point seatbelt ?
- My new "Pre-97" "F-150"
- '70 F-250 with lockers?
- AC FAN PROBLEMS
- CONVERTING TO MAF
- Poweraid
- '89 F-150......making a squeaky sound
- Does Anyone make lowering parts for a '80 F150?
- bouncing/dancing speedometer?
- Edelbrock Performer Intake
- K&N FIPK
- Installing A/C
- Anyone ever build a NASCAR race truck for the street?
- Converting from column to floor shift?
- Towing with 5.0
- Life in Ft. Knox
- 1994 F-150 Won't Start when Raining
- My truck keeps dying
- 1995 F-150 XL
- I just put 2 flomaster 2 chamber....
- MODS TO COMPUTER
- K&N FIPK Whistle at low throttle
- Found the Noise in Cab - 1990 4x4 Ext.cab
- 1986 F-150 Info
- SUPERCHARGING A 5.OL
- How do I straight pipe my F-150?
- SPEED DENSITY???????
- 1991 5.0L MISFIRE
- 5.8 camshaft
- Where do I get interior ceiling ?
- new to the board need advice
- Check Engine Light
- Opinions on '85 F150 mods
- MSD ignition
- battered bed replacement?
- noise from belt
- Engine options?
- Need opinions.....3:55 or 3:73 gears ?
- Motors To Sell
- Noise in Cab - 1990 4x4 Ext.cab
