View Full Version : Pre-1997 Models
- Got my superchip today....
- suspension question
- 4x4 question
- 4.9 1994 F150 that stalls...
- Early Morning, No Start
- ATTN: Chris and/or Ray
- Chip ? again
- more lift!!!!!
- Wanted... Grill Guard
- Supercharger 96 5.8 F150 which one?
- 94 351 started sucking gas
- Axle Codes Simplified (?)
- Do I need new hubs??
- Question for dvldog458....
- Donate54 elec fan?
- Carfax help?
- trailer towing
- F-150 w/ tow package?
- engine temp
- Calling inski21!
- exhaust question for pre-97
- Got My Underdrive Pulleys In Today!!!
- Wobbling Gas pedal
- I just ordered........
- 94 F150 5.8l power???
- Tach installing
- Warn hubs..
- 1/4 mile, 0-60 times.....
- Tire Advice?
- drm7 - can you check a VIN for me?
- Which oil viscosity
- non HO 302 to HO 302 swap (mustang engine)
- Check your power return steering hoses!
- Hood Scoops
- Going to Power Doors/locks
- '86 cab pull off, what does it weigh?
- Not Happy.
- My poor little baby!!!
- signal lenses
- Parts list numbers & stepside tailgate
- Electric fans
- New tires for a 95
- Need Help... Quick!
- Correct me if i am wrong
- Bilstein Shocks
- what can I tell from this info: VIN & Door codes inside.
- radiators
- Another new EGR
- 92-96 f150 sub's
- RAY, need more info on air box mod
- New Warn hubs
- spark plugs
- hyperspeed module???
- Any body converted to the "4-bolt" cover steering box?
- Redline????
- are all ford 9" rearends the same?
- MAF conversion with junkyard parts!
- Hello: New to the Board
- What kinda Oil ya guys use?
- Re Code Scanner
- Gone And Done It-- Chip, Pulleys...
- Wierd Idle
- best way to raise front - 92' f150 4x2
- Code Scanner
- ATTN: dvldog458
- 5.0 --> 5.8, whats involved?
- General Maintenance
- 5-spd shifter
- 351 to 514
- Interesting items in classifieds
- tb spacers
- 87-91 to 92-96 front end conversion
- Attn. anyone with a lift....
- Where can I get a "slotted" front bumper?
- ANYONE converted to a Mustang style EFI intake?
- Body lift anyone...??
- This page has really taken off.
- Dual Exausts=Better Gas Mileage???
- Looking for Pre-1997 F-150
- Need help deciphering F250 manufacturer codes
- Can ya'll show your pre-1997 lifts?
- Paint question
- ignition systems
- 5.0 performance y-pipes?
- Problems with ignition or something other
- F150 gas tanks
- Looking for a 95 F150 website
- C6
- 302-351 regulators & pulleys
- Tornado Engine Performance Maximizer?
- CraneCams HI-6S Ignition
- Codes Gone MPG has improved
- its baaaaack...
- 95 exhaust ??
- My F150 idles up and down, plus getting 7 mpg
- Attn: Pkrwud
- injectors
- Front end rattle
- 351 throttle body...
- My trucks getting there...one more prob.
- TFI Module Settlement?
- Addition to air box mod. Attn. Donate
- 1986 F-150 4.9L Fuel Mileage Question
- Power steering chattering sound on '92
- hey macgyver, i did the airbox mod...
- Harsh Shift
- 1996 F150 XL truck ?????
- Will a C6 from a 460 work with a 5.0?
- My hood is stuck...
- will 97+ rims fit my "older" truck?
- Sucky Pooh
- air filter
- Call me crazy!
- pulleys
- old trucks are good, new trucks are better.
- Mass Air or speed density?
- New Respect for '91
- Intake
- 0-60 time
- pics of my truck
- 1995 F-150 4x4
- selling my truck
- Updating a 91 F/E 350???
- Everyone Read!!!!
- Transmissions in the '96's???
- I Need Anti-sway Bars!.......88 F150
- I need you guys help..
- attn: inski21
- Anyone replaced a bench seat in an older F-250/350?
- Induction Hoods
- porting and polishing tb
- 302 engine idle up, down,up,down
- 5.0L & 5.0L HO Parts?
- Clutch master or slave, who has lost one?
- Knock sensor on 95 5.0???
- Need help for slightly embarassing problem...
- Who sells an off road Y pipe for a 95 5.0?
- EGR Problems 95 f-150
- porting and polishing intake
- Calling all Ford mechanics, I need Help
- 1996 F150 XL 4wd
- Looking at buying a 1992 F150-questions...
- phenolic spacers for manifolds
- 1994 none working turn signals; air bag light flashes
- Bouncing speedometer on 95 f150
- Broke something on my truck again
- Flex fan or Electric?
- Interval Wiper Test & Diagrams
- Attn: Donate54
- Running Boards
- Pre 97 design vs Todays
- Gone 'n Done It--Jacobs
- help me!!
- stupid me
- hey curt73@aol.com...
- Vacuum Lines
- Air Filter help
- fordmotorsports
- roller vs flat-tappet
- Winshield wiper problems
- For all of those looking for a little x-tra
- Shift Knob
- 4.9 VS 5.0 question
- C6 trans problems
- PKRWUD, Your toolbox ;)
- Battery Size
- Looking for a "swap"
- Mustang/Aftermarket Intakes
- CHIP...Is is worth the money?
- Supercharger
- 5.8 Am I the Lone Ranger
- Towing Upgrades
- AC Delco Rapidfire Plugs
- smog/air pump elimination on 5.0L
- Here is the stuff i've got
- Headers & 302
- Need a little help..
- Removing a Body Mount
- How do I identify a transmission
- c4/c6 question
- USBody.com?
- 302 vs. 302 Interceptor
- Steel Cowl Induction hood
- 1990 F150 Questions
- 1996 f150 xtdcab
- Air Bag
- brake job on 91 explorer
- What kind of transmission do I have ?!@?!?!?!
- Fuel System
- Back up lights???
- New grill
- Driver side wiper @#$%^
- Camshaft help
- stroker
- Exhaust manifold noise?
- Cleaning corrosion off intake manifold
- Air bag module removal
- Just got new wheels and tires!
- Need help w/ ping
- Vacuum switch on thermo housing
- Re-Location of PCM
- Will these fit my truck??...
- Heater
- Rattling on startup problem
- Exhaust options
- Chip for a 93/5.8
- Air Bags
- What wheel tire combination should i get..
- Hello
- Bad Fuel Pump?
- Recommend good site for '63 F-100?
- Limiting turning raduis on an '85?
- Won't Start Part Dux
- No Ignition
- Whacky Oil Guage
- '78-'86 F series sites on the web.
- 82 F250 7.4L (!!!) Any Ideas?
- HELP!! need seat
- Anyone with 20's on there 92-96 F-150?
- Where is PCV on '96 5.0 302?
- electric fan
- 302 vs. 351
- GT-40 heads from Lightning on my 93 5.0
- Newbie? '85 150 4x4 operation.
- Shifter Knob
- Heater Fan...Switch? or Motor?
- hey pkrwud
- Torque specs
- Vibrating
- How do I adjust the timing?
- smog pump?
- cutting holes in bumper
- Dang cheap gas!!!!
- loss of power
- Anyone with a 4.9 Superchip?
- Anyone have the 63-1014 K&N Filtercharger?
- Trading Truck/Selling K&N FIPK
- check engine light
- 1984 F150 axles
- Long Tube Headers on a 302
- '83 f-150 w/ 460 engine
- Carb stud torque?
- hard to turn ingnition switch!!!
- Steering Question
- '84 Ford F150/no fire
- Problems starting my '88 4.9L
- Computer ? for Izzy Eddy!
- 1992 4.9L Oil Pan
- 1996 F150 4.9L 2wd Gear Ratio
- Bad Catalytic Converter?
