- New here,got a ?:How rare are 1978 short bed SuperCab F150s?
- Fails to Start
- 1996 fuel tanks capacity debate
- 1960 F100 Panel Truck
- Steering Wander on a 1994
- 5.0 (non H.O.) mods
- Oil Pans
- Performance mods for 300c.i.d. I-6???
- no good 4sp
- Engine light
- Truck weights......?
- Largest tire for 95 F150 4x4 (stock)?
- ABS Light
- hey dvldog458...
- Fuel pumps failing in hot weather
- Bassani Exhaust
- H.p.
- 0-60 and 1/4 times on 300l-6??
- Starter or cellenoid going bad?
- Speed-o-meter Calibration
- K&N and 302
- Tracking Problem
- Extremely Pre 1997 Ford Truck!!!!!
- rear end chatter
- how much for a gear swap?
- engine swap: efi -> carb
- Need a 7 Blade Fan
- Appraisal
- 300 exhaust
- Air pump on 96 F-150
- How many quarts?
- Bloomsburg PA
- parts
- 302 Performance
- gas tank overflowing
- 302 Towing Question
- Trouble with my F150-93: I-6 ...tranny problems...
- how to or does my truck have tilt steering wheel
- Fuel Mileage isTerrible
- no spark
- Bad volt gauge?
- Casper Electronics and hypertech
- Ford Recall Question
- Tach install
- Removing a Radius Arm Nut
- Does anyone know how to remove and replace a fuel float
- Locating the PCV valve
- Replacing Settring Box
- Codes for trans and rear axle
- Another dual question
- Grinding in 3rd gear only!
- Question for DOUGH
- Clutch Problem:(
- 1987 F150 runs rough
- lost phone in defrost vents!
- Center Console cup door
- Synthetic Oil in 302
- Won't start
- 300 I-6 Questions???
- 300 upgrades
- Mirrors?
- Anyone have a Ford frame spec book?
- Future F-150 S-cab Shortbed 4x4 Rebuild
- Thanks
- Need advice with 1992 Truck
- Hey.....Pastmaster
- Cat question for Fadex
- Accell Super Coil
- Which years are easy swap with 1985 302 EFI?
- Need to upgrade seat belts
- 302 modification questions
- What plug wires?
- post for Jimbello
- MOTORSP[ORT GT40 IN A F150?
- whing noise from rear end
- 302 bolt on power
- Do I need new shocks?
- Cleaning under the hood?
- Spark test - Electronic Ignition
- "PRO-FLOW" MAF CONVERSION?
- need to wake engine up
- 302 SWAP FOR CARBURETOR 460
- 100,000 Mile Club - 1995 F150 XLT
- 1990 F150 with loud knocking???
- Shop manual for 1987 F150
- 2001 hd f150 roms on 92 f150, can it be done????
- Supercharger
- Who has 4.9,5spd,31" tires,3:73gears?
- Lost 1st & 2nd Gear 5spd man.
- Gear Question
- Gear Question
- Roll Cage
- Factory Trailer Tow package connector
- 94 F150 w/ 302 pinging bad?
- Loose power steering fixed!
- Vibration in Steering Wheel on braking
- Anybody with 4.9 and 3:55 Gears?
- Hesitation when hitting the gas
- Trouble Codes
- THE LOWEST GEARS IN A DANA 44 IFS
- Stang 302 into 92 f150????
- Blinkers?
- 1/4 TIMES
- Three point seatbelt ?
- My new "Pre-97" "F-150"
- '70 F-250 with lockers?
- AC FAN PROBLEMS
- CONVERTING TO MAF
- Poweraid
- '89 F-150......making a squeaky sound
- Does Anyone make lowering parts for a '80 F150?
- bouncing/dancing speedometer?
- Edelbrock Performer Intake
- K&N FIPK
- Installing A/C
- Anyone ever build a NASCAR race truck for the street?
- Converting from column to floor shift?
- Towing with 5.0
- Life in Ft. Knox
- 1994 F-150 Won't Start when Raining
- My truck keeps dying
- 1995 F-150 XL
- I just put 2 flomaster 2 chamber....
- MODS TO COMPUTER
- K&N FIPK Whistle at low throttle
- Found the Noise in Cab - 1990 4x4 Ext.cab
- 1986 F-150 Info
- SUPERCHARGING A 5.OL
- How do I straight pipe my F-150?
- SPEED DENSITY???????
- 1991 5.0L MISFIRE
- 5.8 camshaft
- Where do I get interior ceiling ?
- new to the board need advice
- Check Engine Light
- Opinions on '85 F150 mods
- MSD ignition
- battered bed replacement?
- noise from belt
- Engine options?
- Need opinions.....3:55 or 3:73 gears ?
- Motors To Sell
- Noise in Cab - 1990 4x4 Ext.cab
- Vin Numbers
- Headers on & Fail Smog test
- smoke headlight covers for sale
- 9 inch rear in 92 F-150
- '85 F-150 302 fuel filter
- Air Injection Troubles
- Damn fuel filter!!!!!!!!
- which engine
- Horse Trailer Towing
- '73 to 79 Cab specs question 2
- Help me find a fiberglass tailgate
- what is the bolt patern on a 1970 f100?
- LEVELING CAB AND BED
- "Run-Rite" Fuel system cleaner>>>>
- 94 Dash
- '96 F150 Performance
- 300-351
- What size alternator on an '96 F-350 4x4 Diesel?
- Jacobs Ultra-Team Pack or MSD
- 94 F150 4x4 front suspension hop?
- Who has done rear main seal on 5spd F150?
- Idle adjustment
- '73 to '79 Cab spec's
- Should I buy? high mileage 92 xlt lariat?
- xlt?
- haedlights
- 1985 F150 5.0l EFI (Hello Mike Troyer)
- 1980 to 1986 lowering kits?
- Need A '81 Or Older Truck
- where to buy accessories?
- 86 F150 EFI problems
- 5.0L 302 power
- Help! Wandering F150
- PTC computer
- Power Upgrades
- Air Bag Code 41
- '79 F-100 lowering
- Install A/C in 1987 F-150
- no cruise;speedo;odometer
- 351 Windsor Motor
- Looking For second-hand Engine
- NEED MORE POWER
- Possible 300 I6 power upgrades
- lift the front
- 4.6 302 power
- 1996 Year Model
- Hard Shifting 2-3 When Warm
- Setting timing on a '92 5.0 EFI
- Where to buy a rollpan & which one
- 92 F-150 302 to 351 swap
- '93 F150 Brake Lines
- 91 valve covers
- 302 idle problems
- Hi guys I'm new here so let me introduce mi self!
- My Dad's lookin to buy an F250 (94-97)
- Spiral thing behind steering wheel
- Smog Plumbing on an 83 4.9L 6 cyl.
- broken bolt..HELP!!
- Clutch R&R, now idle is off
- '91 302 Rebuild vs Lifter Replacement
- Spedometer
- Pinion nut overtightened at factory?
- performance parts for 300 4.9L I6
- 95 Mass Air...
- 1995 F150 8.8 axle - 28 or 31 splines?
- 95 Exhaust
- Where to put that subwoofer??
- '96 Towing Capacity
- EGR VALVE
- Two More Questions
- B&M shiftplus
- Anyone have a oil leak in '92-'96 5.8's?
- taller springs or boby lift?
- Mass Air Conversion for 94' 5.0
- 4.9L Missing
- Taking off the door panels with roll up windows?
- 250+brighter reverse lights
- Top Speed
- 100k Tuneup
- Rear sending unit problems
- FYI, finished replacing Auto hubs
- Brakes - Larger or Different ???
- I6 Dual Exhaust
- Check this out
- 1990 accuator help?
- Any more 1980 to '86 Stepside 4x4's out there?
- TYPO it's a 1980 to '86!!!!
- 1908 to "86 Tailgate
- Axle Gear Ratio Question?
- stalling
- IFS Axle Swap
- '86 F150 stock height
- hey jetter
- Converting electric 4x4 shift to manual
- Backfire!! Engine Troubles.
- Diagnose this one please.
- What's the deal with tire sizes?
- How do I tell if truck has tow package?
- 302 to 460
- Help! Coolant coming out tail pipe!
- Lots of questions...
- cruise control troubles
- Another Clutch Problem
- Replacement Engines
- '93' 4.9 6cyl smell gas & won't start when cold outside after sitting overnight
- Clutch/Starter Safety Switch
