View Full Version : Pre-1997 Models
- Ignition timing and spout
- The I6 vs. V8
- Bronco II ?
- Mopar Missile
- Attn FORCEFD
- Runs rough win first start!
- Mods Mods Mods!
- Autometer Gauge Pods
- interior door handle
- Thumbs up!
- Are there any "budget boost" type lifts for 95 f150's?
- Upgrading to a '93 - '95 F150 or F250?
- What does w/o mass air or w/ mass air mean, on the FIPK?
- The lift I'm getting
- gas mileage
- what are the biggest tires i can put on my truck?
- how much ATF
- Which motor oil additive?
- need help!!!!
- Need Help Fast
- 1990 Xlt 4x4
- Supercharged 4.9L
- Holy cow
- IM sory im really sorry
- Y or Z?
- Knock sensor? Broke!
- Good Bye and Thanks!
- $200 4 a starter!!!!!
- frames
- Need Truck Purchase Advise
- Mod ?
- Now I have my aim set real high
- Adding shift kit to high mileage tranny
- Has anyone thought about polishing this?
- vibration/stuttering
- Need all Alabama Lightning owners
- damn!
- Heads on Ebay
- Need help with 5.0 H.O. Conversion
- 1986 F150 specs
- 1986 F150 351W carb
- how to get codes
- advanced timing:
- Pkrwud......
- You guy's will like this
- Steering Wheels
- guages installed!
- 96 f150 with 302
- 4x4 not working
- Christmas Snow...22inches
- can you beleive this
- Fuel Guage woes
- temp guage problem
- Weird Idle Return
- 86 F150 2BBL throttle body rebuild
- Head question
- '86 F150, Anyone?
- My "new" truck
- Here are a few more questions
- Gearing question
- Front seats
- wouldn't start:
- Engine Dies when given throttle
- engine pics
- Heater Controls
- it wont start
- Let The Modding Begin !!!!
- L6 performance parts
- Happy Holidays to all
- help with temp sender unit
- have you guys had trouble with door latch cable?
- Tie Rods?
- Tank size.
- traction/ladder bars
- Project: 308, is finished
- I was upset
- New Suspension
- sway bars
- losing oil
- Who has an aftermarket lower valance?
- Stupid question for a stupid guy
- Dumb question - where is EGR and how to clean
- Screamim Demon Tune Up Kit
- That 5.0L sound
- oil question
- Fuel gauge not working properly
- Heat swings
- '87 F150 Questions & Help
- Fuel Tank Leak
- radiator, leaking, fix or replace???
- my newest mod...
- 351 parts
- 302 problems when shifting into gear
- Oil Pressure Problem
- Summit Headers
- F-350 shocks....Need help..
- 1992 f 150 oem wheels? Where to get?
- heater blows hot then cold
- Is there a way to bypass the EGR valve?
- My eventful weekend
- what tranny do i have???
- 79-86 Diamond Headlights
- Heater core.........help...?
- 5 speed manual problem?
- New F150 Video
- 93' F150 looking for Tranny Options..
- Power Mirror Harness?
- 300000 miles and somethin finally quit
- Attn:// PKRWUD & StrangeRanger
- Helpful Tip!!!
- help
- My newest project
- '89 mod help
- hot brakes
- difference between 88 and 87 bumper..
- steering wheel replacement
- Coolant Leak.. Can't find it
- What do you think?
- 3" body lift installed, how to raise rear bumper?
- shift kit install comes to a hault
- ? about changing oil pump and stuff on oil cap
- will C6 bolt up to 4.9L?
- hot brakes
- lots of noise when hubs locked in
- Aftermarket accessories
- Manual Hubs VS Auto Hubs
- Good Exaust
- super chips
- 351 conversion (for 302) for $2300
- Why no icon for pre-97s?
- Snow time
- How tell a Dana 60 from 50 from 44??
- Radiator time
- What a joke!
- Windshield wiper pump not working
- MAF to Filter adapter
- Hey Chris
- ***Update***
- Air Pump
- Water pump is done!
- Motor Mounts for a 302?
- MAF size
- return line kinked very high pressure problem...please help
- Dashboard Lights
- I'm in trouble
- I need a stock intake. 93 F-150 (302)
- billet grill
- Gears
- truck stalls in reverse?
- crummy mileage with an FIPK--351 V8
- ford steel braded fuel lines
- Approximate Value Estimate -- 1965 F100 Dual I-BEAM
- Speedometer
- 90 5.0 Acting Weird
- 1983 Ford Ambulance For Sale
- Tune up time
- Missing, putting, sputtering and making me mad!!
- Water pump R&R questions..... (easy ones)
- 351w combustion chamber size?
- Maf?
- Bassani Cat-back
- too many hydrocarbons - failed emissions
- 4.9L I6 Performance Mods
- Fuel cross flow on 93 f150
- Gripes... Just plain Gripes
- 88' F-150 5.0 AOD 2wd
- Guy's what do you think of this?
- Running High RPM's
- Where to buy a NEW aftermarket oil pan?
- don't feel so bad about my slow 300.......
- Is my truck an odd ball?
- Catalytic Converter/Exhaust
- Complete specs.. where can I get 'em?
- Adjust timing or chip it?
- Dual Intake...with picture
- Fueling up rear tank problems!
- MacGyver where have you been!!??
- Big Brown Truck...Look what I got
- what rims will fit
- Bad popping
- Raced a 401 Wide block...
- whats with this??
- how big are my gas tanks?
- Diamond Plate Prices
- Wheel caps '95 f-150
- Extending O2 wires for full length headers
- some air mods??what do you guys think
- squeeking noise
- New Electric Fan Kit
- I need a stock stereo
- F150 Video :)
- No brake lights/ Flashing lights/ No start :(
- Front suspension squeaks
- Ordered My Echaust System
- Is there an easier way to tell?
- High Flow Fuel Pumps
- greasin
- Help... Need Advice On Rotors
- How can I tell if my cat is clogged?
- Jeez my truck is slow
- Half Ton....One Ton....
- Rear ABS..Whats the deal?
- Payload Capacities....
- Omg Lsu Kicks A$$
- Need Help Fast!!!!!!!!!!!!!!
- Who has a 5.0 with a Super Chip?
- This is what we do in the North East
- where does the h2o come from
- Replacing Front Disk Rotors on 4x4
- diffrential question
- PA body lift on 94 f150?
- I need a CARFAX REPORT...
- a lift/lowering prob
- will 1.7 roller rockers fit under the stock valve covers?
- Which collector gasket?
- Found a lowering kit:
- tire size question
- Transmission
- 302's HP rating
- Wiring Diagram
- Should I buy this 1988 F150 4x4 I6 STD?
- Air Flow?
- power needed
- Some lights don't work.
- Stock Throttle Body
- air box or twin filters
- 3.55 ratio axle and 6250 GVWR as options?
- Whaaaaaaaaat?
- I got bored again
- Saw a nice pre 97
- Hurst Truck Shifter
- F-150 flatbed
- Changing transmission fluid
- The Beer Fairy! Yeaaaaaaaaa!
- Next Mod???
- Wow
- Airbag light flashes?
- Updated photo gallery
- Posi, Locker and LS
- blown fuse
- Winsheild Fluid System?
- anyone who knows anything about rolle rockers please read...
- 1995 f150 with 5.8
- Gauge Cluster help
- Whos replaced the O/D switch
- Which manual is best?
- still planning roller cam swap, need help picking cam!
- any idea how much $ to paint an aftermarket hood?
- Wheel/Tire upgrade
