View Full Version : Pre-1997 Models
Pages : 1 2 [3] 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25
  1. Ignition upgrade
  2. Lower Cost Mods- EGR, Smog Pump, Cats, Mufflers
  3. Tire Cupping
  4. Failed Inspection and I's gots a tickets
  5. Starter solinoid wiring
  6. 1988 F150 not starting
  7. Changing M50D (Mazda) Tranny for something else?
  8. Converting OBDI to OBDII ?
  9. 91 f150 exhaust help
  10. SeaFoam
  11. New to me '89 150
  12. Window regulator (power windows)
  13. ALT died
  14. 1979 Ford F150 electrical problem
  15. Real High Idle and Transmission won't Shift
  16. Will Not Start (click)
  17. 91 I6 exhaust
  18. 1992 Ford f150 "IDEAS"
  19. Fuel or spark?
  20. Need ignition help
  21. 87-91 clear corner or euros
  22. header question
  23. headers
  24. Brake failure
  25. Cold Weather Starts
  26. need a fan shroud
  27. From 300-6 to 302
  28. No power to fuel pump
  29. 1987 5.8L Carb. Fuel guages don't work
  30. I6 wont idle
  31. Tire question
  32. Brake or Hub Problem?
  33. 87 F150 takes forever to refuel...
  34. What causes the slave cylender to fail?
  35. Looking at a '93 F150
  36. Quick question about some rot
  37. Leaking Oil Bad...(4.9 L)
  38. Inherited truck, some q's
  39. pcv valve?
  40. What do you average in MPG/KPL
  41. Rear Window Removal How to?
  42. EGR valve...AGAIN!
  43. Reclining Seat
  44. Starter problem?
  45. Timing question...
  46. Help Plz
  47. Trans case noise
  48. I6 to 351 conervion??? need help
  49. Plugs keep backing out
  50. new plow truck problems
  51. Cleaned motor now wont crank
  52. underdrive pulleys
  53. underdrive pulleys
  54. Help me with steering wheel swap.
  55. round plug distributor WTF?
  56. Air Injection Tube
  57. Help with Haunted 94 flareside
  58. Installing temp gauge
  59. Hydraulic Valve Train Questions
  60. 1990 ford f150 5.0 to 5.8 swap?
  61. horn problems
  62. 4WD Issue
  63. Broken gas gauge
  64. Need Key
  65. Transmission Dead
  66. horn location
  67. horn location
  68. horn location
  69. 1992 E40D Trans Adjustment
  70. Hazard/Brake light 15A fuse blows
  71. 86 F150 parts
  72. Turning then clunk
  73. Turned those rotors!!
  74. Lift kits??
  75. Draining old fuel
  76. Radiator Hose Rubbing
  77. 302 engine
  78. Not sure if I have asked this before but...
  79. Ignition switch issue?
  80. 92 Body Bushings
  81. How to change Fuel Filter
  82. Chips?
  83. HelP! Not shifting!
  84. Fuel Question
  85. Coolant Leak after New Heater Core? Pics
  86. (Question about front & rear gears) Happy Thanksgiving!!!
  87. woohoo my truck scared my wife
  88. 94 f150 no start, no spark
  89. DJM Flip Kits?
  90. Key/Headlight Buzzer not working
  91. 1987 F150 rear brakes - photo
  92. 92 f150 noises??
  93. Need Help with stereo wiring
  94. Loping/Stalling 93 f150 302 2X4
  95. '95 F250 loose steering
  96. Throttle Cable Removal
  97. Transmission problem question
  98. Electrical issue
  99. flywheel replacement
  100. How do you remove this?
  101. How much power can be forced out of a 302
  102. All I need is 2"!
  103. More power!
  104. 1997 f-150 Turning off..NEED HELP! plz
  105. Wondering if I can remove the cats and computer
  106. How feasable would this be?
  107. Cat removal
  108. is this screwed up?
  109. Removing the ball joints
  110. Rally rims?
  111. 1992 Throttle Body Options
  112. Rear End Gear Oil
  113. What Code Scanner do I need?
  114. Radiator Support
  115. Scanner code
  116. Question about gas and octane
  117. Exhaust manifold
  118. Door handle snapping off.
  119. strange RPM / IDLE issue
  120. EGR Engine light
  121. need help, dont know whats wrong, truck wont fire.
  122. Wreck!! Is it worth it to try and fix it?
  123. If I have a donor truck, can I convert a 150 to a 250?
  124. Have I for sure, 100%, found a roller 351w?
  125. 4.9 inline 6
  126. What is a MAP sensor?
  127. RABS Light!
  128. 1993 f-150 going to carb.help
  129. Gas Milage Reprogramming
  130. 95 body lift...need help
  131. Rubbing
  132. Fast turn signals
  133. remember my ticking noise?
  134. brake fluid
  135. Check Engine light
  136. 2006 muffler/pipe on a 1988 4.9 ?
  137. 97 down cabs&interiors??
  138. fuel filter changed after 120k miles
  139. Straight axle conversion
  140. Need to change oil pan gasket
  141. Need to change oil pan gasket
  142. Need to change oil pan gasket
  143. Need to change oil pan gasket
  144. '84 150 - engine trouble
  145. Egr Cat Computer?
  146. horn not workin
  147. what is that bracket called?
  148. Radial arm bracket washer??
  149. 95 4.9L Starting Question
  150. New Member: Trying to restore 84 F150 Straight 6
  151. Starting Problem
  152. need advice
  153. 89 signal light problems/need to troubleshoot signal light switch
  154. is this possible
  155. Dual fuel tank problem
  156. 4R70W Transmission problems
  157. Difference between C6 and AOD?
  158. Bad solenoid?
  159. EGR valve? 91 302
  160. Tailgate Handle relocater kit?
  161. '92 F-250 heater won't switch from vent to defrost/floor
  162. F250 restoration nearing completion...
  163. Pre formed rubber floor
  164. new wheels
  165. Fuel pressure drop at wot?
  166. 89 F-150 brake problem
  167. Body Lift
  168. tow hocks
  169. Eaton M90 Supercharger on 5.0L Bronco
  170. tie rods
  171. Degreased and Hosed off Motor - Truck Won't Start Now
  172. Spark Plug gap
  173. 1988 f250 auto to standard?
  174. Solid axle swap and sterling 10.25
  175. 351W coolant temp sender size?
  176. Recall recourse: do safety recalls 'expire'?
  177. anyone seafoam inline 6?
  178. CUPHOLDERS aftermarket or possibly a Ford 'option'
  179. Curious about raising my F150 a bit...
  180. Leveling Kits
  181. 96 300 using a LOT of oil
  182. 120,000 miles on fuel pump
  183. Fuel Pump Noise
  184. Military Members
  185. Distributor pin in my 1986 f150 300 I6 keeps sheering
  186. Steve83 My motor mount is broken.
  187. Dash light replacement with LED's... how to do it?
  188. Had to try it and it worked fine
  189. CEL and running hot
  190. door swap / lock cylinder ?? '88 f-150
  191. lug nuts
  192. f150 stalling, hard to start need help
  193. sorry old f150.....
  194. Help Speedometer is Fluctuating
  195. Fuel Economy
  196. I6 EFI to 351W EFI swap
  197. 4.9 Fan clutch nut won't budge.
  198. what size
  199. '96 Engine mounts
  200. I'm doing a 300 I6 to a 302 V8 engine swap...Can anyone give me info?
  201. Headlights going off and on
  202. Problems with front gas tank and pumping gas
  203. 4.9 dual tank fuel filter
  204. Need bigger rims
  205. Voltage regulator location?
  206. Tow Hooks
  207. need help with code 578
  208. Adding Extra Battery
  209. front end "clunking" noise.
  210. need help finding spout
  211. basic tune up help
  212. i6 more power
  213. Bought new tires today... Any tips to reduce front end tire wear?
  214. Throttle body
  215. My Rig!!!! and a couple family fords!!
  216. I'll call him "mello"
  217. AC problems...
  218. 95 F-150 Won't start without a jump
  219. Seat conversion's......
  220. Fuel Issues
  221. coolant leak
  222. RRRRRR"s are hanging
  223. New Alternator woes
  224. what size tires
  225. Can a heated O2 sensor kill the engine?
  226. '96 - Hard Starts
  227. High Idle low power
  228. Had a few questions about my 300
  229. front susp. question
  230. Head gasket
  231. Oil Pressure - Am I in trouble???
  232. how many quarts of earl
  233. oil and gas additives
  234. 1996 speedometer
  235. trouble with rough running when just giving the truck a little gas
  236. Gas Mileage (how good how bad)?
  237. Temperatrure sender on a 94 I6
  238. Exaust Question
  239. '95 F150 Exaust problem
  240. Jerky Ford ;)
  241. Bad Starter? 1995 F150
  242. Bad Starter? 1995 F150
  243. 86'f150 Has No Power
  244. Bad coolant leak
  245. K&N Performance Intake
  246. Lurch at highway speeds
  247. E4OD tranny slipping in D
  248. 96 5.0 Supercharged?
  249. looking for pair of factory running boards
  250. Picture Request (should be easy)
