- MPG ? What can I expect...
- My 327 finally comes to life!!!!
- looking for 4.9 mods
- Mod my '94, or buy the '04
- New Owner/Old Truck (86 150 4x4)
- Beastie spotted
- For all that love the '73-'79 Ford Trucks
- going elk hunting for a good week
- Project 85 F-150 - Stage Two Pics
- Project 85 F-150 - Stage One Pics
- Engine stalls w/AC on???
- Body Rot Solutions
- HELP! just got this truck and need some info
- 96 Bumper foglight mounting?
- Rust in over rear wheels?
- Bad Mileage on rear tank only??Help!
- 80 mm Mass Air on a 1994 F150
- 1969 pickup info
- 300 to 351W swap
- Headlight switch problem
- Headers?
- Going through some changes
- air intakes and where to get?
- coolest off-road video ever!
- My 1/4 mile vids
- never mind ..lol
- fuel smell
- is a 392 worth it?
- lift kits
- 351 Build-Up Continued ....
- Excessive Oil in Air Filter Box
- Latest Mod
- Airbag Code 21 Safing Sensor - Where is it?
- Its Fixed !!!
- Body Lift
- Update.
- New guy help with popping noise
- Repairs to my 96 F150
- Head Lights Flickering On And Off
- pulls to the right
- Finally found a clean '91 Bronco w/351, but fuel guage doesn't work.
- Windshield Wiper Mess
- Guys
- wanting brake upgrade.
- Too much power?
- pretty bad eh?
- How to eliminate TQ lockup
- ABS Light & Parking Brake Light On...
- Alternators
- Cooling ( or Not )
- Hypertech chip on ebay
- turn down on muffler?
- Went to the track once again
- 1.7 Roller Rockers with S/D...
- Remote Doors
- Will they fit?
- 89' 5.0L Temp Sensor?
- AC clutch engages every 5 seconds
- '86 F-150
- Speedo calibration when changing ring and pinion gears?
- Wheel hop, what to do
- Wondering what to do (re: headers)
- Exhaust for an 86' F150 5.0...
- Engine ticking
- What do you guys know about this cam?
- Moded Dodge Goes Down
- Ran the 1/4
- Grandparents modified my truck!
- 351 Vs 460
- No Power/Gas?????
- gas moving between dual gas tanks
- Check this out!
- Bogging down
- Roller motor with factory fuel injection and computer?
- Starting Problem and idle issue
- carb troubles
- My truck year to date:
- Lost against the 4.2L
- New to this site bought a truck.......
- tweecer
- Impossible EGR vavle removal
- '93 Lightning Performance Questions
- Heater Core '91 F150
- Centercaps...HELP!
- Buddy's 351 build-up now ...
- ecm question
- ATTN: Fuel Injection Gurus. Injector ??
- Thanks to ALL...
- Truck Itakes
- Hey PKRWUD /// Cat ????
- Headers and full exhaust? Please help!
- Tailgate Doesn't work?
- New Custom Gauges
- Hey guys.
- Truck has slight skip, Poor power, checked everything.
- engine parts (bearings, rings and stuff)
- Stock Rim Width?
- Billet Grille!!!
- Should I be concerned? (re: water temp. sensor)
- 302 Project Truck Questions!?!
- Hey everyone, I finished the Project!!!
- Center Console Door
- Horn Button Question???
- Temprature Problem...kinda
- oil in upper plenum
- bulid my own lift??
- Power Steering Gearbox
- 9mm wires
- 4.9L missing/bucking while cruising
- almost over heating:
- Is my fuel pump on it's way out???
- Engine swap on a 1989 F150
- drain plug problems, HELP!!
- anybody gone from power windows to manual?
- Billet Steps For 92-95 Flaresides
- cross camber question
- 4.10s and LS are in!
- Bad gas mileage with my 94?
- Street Scene Rollpan?
- More 1/4 times!!!
- Need help with Wiring
- E Fans
- What would get me closest to stock?
- vin decoder for 94 f350
- '89 Lariat Seat Rattle
- '91 4.9 Hesitation on Exceleration
- lowering shackles?
- No Fuel Pumps during Starter Crank
- Project update
- smog pump--- shorter belt and bypass??
- 1990 F150 Electric Window Problem
- New Rear Window for '92 F-150
- v6 4.2L VS 4.9L I-6
- I-Beam question
- Header gasket leaking
- PLEASE HELP! Will this work???
- Diesel question
- Need to find an alternator...
- chip and pullies on the way
- '96, '97 460's
- Changing the Fuel Injectors on a 94 with the 300 Inline 6...
- I gotta few questions....
- New Here
- Donate54 where are you?
- Hey I'm new here
- 96 300 6cyl belching fuel under hood
- New Exhaust... Check it Out!
- Oil Pan Gasket
- '91 4.9L 154K - Motor Oil
- Advice on Gear Swap...
- '91 F150 4.9L Stalling idle when first cranked
- '86 5.0L running rough
- Injector resistance, is there a difference?
- pwer steering gearbox
- clutch replacement
- new exhaust problems????
- Cams ????
- 89 302 Missing Under Acceleration
- lug pattern
- wet okole seat covers
- Code Reader, HELP!!!
- Difference between 302 & 351 exhaust...
- Fuel problem
- Some "in the process" picture
- Attn people in the salt states...Save your Fender!
- stupid ABS light!
- Silly question about rear diff. oil...
- Stupid radiator!
- surging and bogging during heavy rain
- headed to the lake tomorrow chris
- Question about Troyer Performance electric fans....
- thanks Sprocket X
- Question
- Got my headers....
- Starting problem when HOT.
- DAMMIT Macgyver!!!
- Replacing the preheater....
- Bbk Headers
- putting in a chip
- Yet another exhaust question
- Some quick questions...
- vapor lock
- New pics
- Header Options For 1996 F-150 w/ 5.8L
- gear install
- can I block off rear tank lines?
- In the 16s
- Bought some headers
- 1995 F-150 headlamp assembly replacement
- Bad Day For Me
- 1989 f250 fuel gauge/sender (weird)
- Temperature Gauge
- Check Engine light @ 4000...
- 1994 F150 cuts out @80 MPH
- That Bronco I was talking about
- 300 6 cyl performance modifications???
- Modified Air Intake question
- 94 Bronco problems, need help
- Brake pads...
- Thank You
- Rear Disc Brake Conversion...
- Well, the 89's finally lifted 6"
- went drag racing
- rear tank question on 95 f150
- How many quarts? (M5OD)
- How many quarts?
- Torque converter & gas mileage
- Gears are on the way!
- Upgrade 1984 F150 300 six
- 1994 f150 stalls when on gas
- broken bolts
- 94 4.9L Running Hot...where to start
- 2x4 To A 4x4 Ttb
- Headers
- Wheel Alignment
- I didn't go ricer, did I???
- Increasing fuel pressure,Richer/Leaner?
- 5.0L Engine oil pan capacity?
- Changing M5OD fluid
- Removing the A/C
- Help with the truck:
- Wanted: 87 lockout hub knob
- 1987 F150 4X4 problems: locking hub, duel tanks, sending units.
- '95 Dana 44 TTB bearing torque
- Cowl induction hood
- 6" Lift with Dana 44 TTB....
- Master Cylinder/brake valve....
- Alternator upgrade,Which brand????
- this is easier than my last thread!!!
- Airbag flashing code 4-5
- gearing questions
- Electric Fan help
- Which spark plugs?
- Airbag Code 2-3 or 3-2
- Happy Happy Happy
- Upper actuator & drive gear
- Been wantin a Bronco 4x4
- A few NEW pics.
- Sorry
- heads swapped but wont fire??
- what do you guys think?
- fuel pump or something elese.
- Fuel Mileage
- pre '97 headlights...
- Oil Leaking..Somewhere
- Re-Did my intakes
- starting problem
- Got some new stuff
- Free to a good home!
- Help
