- Lean Fuel Problems
- I think I need a new water pump...
- How much have you towed?
- Fuel Filter Line
- Lift/gear ratio help
- rear suspension
- AOD - how often are you guys using it?
- parting out truck
- Batch fire vs. Sequential injection
- Finally got grille guard installed
- i need a stock 302 lower intake manifold...
- 1995 Billet Grille?????
- Clutch problem - Urgent!
- Hitch won't fit with step bumper!
- Improving performance on a 4.9 Liter
- I know this isn't related.....
- this bolt is driving me up the wall!!!
- replacement door panels
- Replacement of Replacement parts
- problems
- Got my Edelbrock Intake Manifold in today...
- Remote starter recomendations 93 XLT
- paint scheme suggestions?
- Fuel pressure w/dual tanks 96 4.9l
- poweraid throttle body spacer
- Curb weight
- EAOD shuttering at highway speed
- Gen 1 Lightning Intake
- update on overloads
- E-Brake Cable Install Update
- synth oil...
- Anyone seen an F150 painted like this?
- Got my car back
- H.p.
- H.P. Differance
- semi-floating axle or full floating?
- How to tell what OEM options my truck came with?
- TPS question
- injector wiring EFI vs. SEFI
- I'm Goin' To Start My First Project Truck!
- Gauge cluster going bad
- Pics of my custom intake
- Towing 5000#, '90 F150 4x4 - use bumper?
- MSD problem?
- Wanted: '90 F150 4x4 rear hub caps
- Another ? for dvldog458...
- Adjusting headlights on a 95
- tranny fluid question...
- look at all the new posts
- Hauling Check
- Intake is on..
- Well, here they are....(Pictures of My truck)
- I need help with the gallary
- stumble when accelerating
- timing question
- i just ordered
- Pictures of my 95 F150
- Owners manual and service manual
- First 4x4
- White Faced Gauges
- New member
- Sneak Preview of my truck....
- 1990 F150 vibration under load at 65-70 mph
- Tranny swap
- shaved door handles
- '92 5.8l mods
- I'm so stupid!!
- e-brake cable update
- this is what I'm thinkin..
- Fuel tank size...
- Mpg
- Lifts
- Macgyver...Will this engine do it??
- Hey PKRWUD
- Looking for compression values
- 92 steel cowl hood?
- Dual fuel tanks
- engine idle rough or high?
- Update on the Superchip...
- fuel injectors
- Exhaust Advice
- Got my superchip today....
- suspension question
- 4x4 question
- 4.9 1994 F150 that stalls...
- Early Morning, No Start
- ATTN: Chris and/or Ray
- Chip ? again
- more lift!!!!!
- Wanted... Grill Guard
- Supercharger 96 5.8 F150 which one?
- 94 351 started sucking gas
- Axle Codes Simplified (?)
- Do I need new hubs??
- Question for dvldog458....
- Donate54 elec fan?
- Carfax help?
- trailer towing
- F-150 w/ tow package?
- engine temp
- Calling inski21!
- exhaust question for pre-97
- Got My Underdrive Pulleys In Today!!!
- Wobbling Gas pedal
- I just ordered........
- 94 F150 5.8l power???
- Tach installing
- Warn hubs..
- 1/4 mile, 0-60 times.....
- Tire Advice?
- drm7 - can you check a VIN for me?
- Which oil viscosity
- non HO 302 to HO 302 swap (mustang engine)
- Check your power return steering hoses!
- Hood Scoops
- Going to Power Doors/locks
- '86 cab pull off, what does it weigh?
- Not Happy.
- My poor little baby!!!
- signal lenses
- Parts list numbers & stepside tailgate
- Electric fans
- New tires for a 95
- Need Help... Quick!
- Correct me if i am wrong
- Bilstein Shocks
- what can I tell from this info: VIN & Door codes inside.
- radiators
- Another new EGR
- 92-96 f150 sub's
- RAY, need more info on air box mod
- New Warn hubs
- spark plugs
- hyperspeed module???
- Any body converted to the "4-bolt" cover steering box?
- Redline????
- are all ford 9" rearends the same?
- MAF conversion with junkyard parts!
- Hello: New to the Board
- What kinda Oil ya guys use?
- Re Code Scanner
- Gone And Done It-- Chip, Pulleys...
- Wierd Idle
- best way to raise front - 92' f150 4x2
- Code Scanner
- ATTN: dvldog458
- 5.0 --> 5.8, whats involved?
- General Maintenance
- 5-spd shifter
- 351 to 514
- Interesting items in classifieds
- tb spacers
- 87-91 to 92-96 front end conversion
- Attn. anyone with a lift....
- Where can I get a "slotted" front bumper?
- ANYONE converted to a Mustang style EFI intake?
- Body lift anyone...??
- This page has really taken off.
- Dual Exausts=Better Gas Mileage???
- Looking for Pre-1997 F-150
- Need help deciphering F250 manufacturer codes
- Can ya'll show your pre-1997 lifts?
- Paint question
- ignition systems
- 5.0 performance y-pipes?
- Problems with ignition or something other
- F150 gas tanks
- Looking for a 95 F150 website
- C6
- 302-351 regulators & pulleys
- Tornado Engine Performance Maximizer?
- CraneCams HI-6S Ignition
- Codes Gone MPG has improved
- its baaaaack...
- 95 exhaust ??
- My F150 idles up and down, plus getting 7 mpg
- Attn: Pkrwud
- injectors
- Front end rattle
- 351 throttle body...
- My trucks getting there...one more prob.
- TFI Module Settlement?
- Addition to air box mod. Attn. Donate
- 1986 F-150 4.9L Fuel Mileage Question
- Power steering chattering sound on '92
- hey macgyver, i did the airbox mod...
- Harsh Shift
- 1996 F150 XL truck ?????
- Will a C6 from a 460 work with a 5.0?
- My hood is stuck...
- will 97+ rims fit my "older" truck?
- Sucky Pooh
- air filter
- Call me crazy!
- pulleys
- old trucks are good, new trucks are better.
- Mass Air or speed density?
- New Respect for '91
- Intake
- 0-60 time
- pics of my truck
- 1995 F-150 4x4
- selling my truck
- Updating a 91 F/E 350???
- Everyone Read!!!!
- Transmissions in the '96's???
- I Need Anti-sway Bars!.......88 F150
- I need you guys help..
- attn: inski21
- Anyone replaced a bench seat in an older F-250/350?
- Induction Hoods
- porting and polishing tb
- 302 engine idle up, down,up,down
- 5.0L & 5.0L HO Parts?
- Clutch master or slave, who has lost one?
- Knock sensor on 95 5.0???
- Need help for slightly embarassing problem...
- Who sells an off road Y pipe for a 95 5.0?
- EGR Problems 95 f-150
- porting and polishing intake
- Calling all Ford mechanics, I need Help
- 1996 F150 XL 4wd
- Looking at buying a 1992 F150-questions...
- phenolic spacers for manifolds
- 1994 none working turn signals; air bag light flashes
- Bouncing speedometer on 95 f150
- Broke something on my truck again
- Flex fan or Electric?
- Interval Wiper Test & Diagrams
- Attn: Donate54
- Running Boards
- Pre 97 design vs Todays
- Gone 'n Done It--Jacobs
- help me!!
- stupid me
- hey curt73@aol.com...
- Vacuum Lines
- Air Filter help
- fordmotorsports
- roller vs flat-tappet
- Winshield wiper problems
- For all of those looking for a little x-tra
- Shift Knob
- 4.9 VS 5.0 question
- C6 trans problems
- PKRWUD, Your toolbox ;)
- Battery Size
- Looking for a "swap"
- Mustang/Aftermarket Intakes
- CHIP...Is is worth the money?
