View Full Version : Pre-1997 Models
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 [18] 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35
  1. New engine - no timing mark
  2. 1990 with no inline pump?
  3. Battery or alternator or wiring problem
  4. How do I get something painted?
  5. Need Advice on 5.8 liter eddie bauer
  6. Ram air hood for '88?
  7. Retrax, Fold-A-Cover or Bak-Flip?
  8. Forgot to gap plugs? results?
  9. Long block engines. Anybody ever deal with hiperformer.com?
  10. front fuel tank interchangeable?
  11. Got a problem , possible IAC
  12. Nite edition f150 info
  13. aftermarket or replacement bed for '95..
  14. Will these mirrors fit?
  15. Weak Spark at Coil Terminal
  16. Pip circuit failure?
  17. 88 F150 5.0 4X4 Will not start?
  18. replaced engine with reman won't start help
  19. 351w head bolt question - water jacket?
  20. Gear ratio problem...
  21. 95 short bed tonneau Cover
  22. My Gas Pedal Vibrates severally!
  23. 1988 F150 Complete Exhaust System
  24. Will these wheels and tires fit my 92?
  25. Not going back to center
  26. Fuel delivery problem F150 1987 duel tank
  27. ignition issues, falls on face when I step on it
  28. 95 300 I6, performance chips? yes/no?
  29. Overdrive issues - '95 F-150
  30. 91 F150 Steering Gear Leak
  31. Fuel Delivery Problem
  32. i6 oem carb prob
  33. How much does a lift cost?
  34. 95 f150 with worn bushing!!
  35. 1990 I6 valve chatter after oil change
  36. 95 4.9L No Spark at the coil.
  37. !990 F-150 Idling Issues
  38. Engine is cutting out??
  39. 95' Std Cab Longbed Driveshaft
  40. Cant wait to get her back
  41. Flareside and Styleside
  42. is this kit complete?
  43. 94 F150 question
  44. New Member with Issues! (not mentally LOL)
  45. Need help with a 302 (tick/knock) LONG
  46. Dual fuel tanks
  47. turn signal lock
  48. 10/95 6cyl. F150 Odrive light
  49. 96 F150
  50. 1988 F150 Horn is out
  51. 94 F150 With Oil leak
  52. Upper and Lower Intake
  53. '95 F-150 302 v8 Acceleration Problems
  54. rusted brakes lines
  55. 351w question about heads
  56. Smog/emmisions parts
  57. I-6 specs
  58. Project 94 f250 gas
  59. Replacing Ignition Module in '91 F150
  60. Surge Under Load
  61. Performing crash testing on F150 - need pictures
  62. no brakes
  63. Anyoen make an inexpensive cold air intake for my 92 4.9?
  64. Pictures of front bumper mounting brackets
  65. 92 w/302, whats this wire go to???
  66. Engine Horsepower
  67. 1994 f150
  68. Negative battery cable question
  69. School me on engines
  70. just saying hello
  71. 96 F-150 OEM Frame Coating?
  72. Duel Fuel (87) Problem: Isolating Issue
  73. Gauges for an 83
  74. 1990 F150 fuse question
  75. Kenne Bell supercharger
  76. MPG from a 93 F150 4WD auto??Weak and sucks fuel!
  77. No tail lights
  78. Abs And Brake Light On
  79. Someone please help with a 94XLT
  80. Spark Plug Gap
  81. Leaking Transmission and Exhaust Question
  82. I need a new Frame
  83. fuel pressure regulator?
  84. Coolant overflow problem!
  85. Was 4x4, shortbed, and dual fuel tanks ever an option?
  86. fuel leaking all of a sudden
  87. Headers for GT-40P heads?
  88. 93 Spindle Help
  89. My Trucks Smoking!
  90. Purge Solenoid
  91. 1984 F-150 4x4 300ci Inline 6 swap ?
  92. 1995 F-150
  93. Plug Wires
  94. warm up idle
  95. front bumper
  96. 302 Timing
  97. Eddie Bauer Colors
  98. leaking power steering fluid
  99. daystar installed
  100. 1994 5.0L 5-speed
  101. New FPR and it still won't start!!!
  102. wheres the grill screws
  103. Questions about Truck??
  104. 1994 mass air flow sensor
  105. 1989 F-150 Custom 4.9
  106. need computer code asap
  107. Steering noise
  108. need a computer codeasap
  109. does not go past 3500 RPM
  110. 86 F150 Box
  111. Where is the fuel pump relay?
  112. E250 5.0 Won't Start...help!
  113. 89 4.9V6 with black smoke won't start
  114. 1990 F-150 Engines Dies At Highway Speed Computer Codes Included.
  115. 88 F150/302 timing
  116. 86 F-250 window motor removal
  117. Idle problems
  118. Recently purchased 1995 4X4 F150 Super Cab 5.8L
  119. Anyone with a 460 please?
  120. Truck has the blues, smoke that is
  121. F150/250, same body?
  122. Just bought 95 f150 with jerking issues
  123. Truck ran rough then died
  124. truck cutting out
  125. My baby!
  126. Stalling while driving
  127. need help with vacuum line (see pic) thnx!
  128. just installed 3.73 gears limited slip
  129. High idle after TPS change????
  130. fuel pump
  131. K&N filter ?
  132. Shock preference?
  133. Who knows AOD's well?
  134. ailgate help
  135. heater motor resistor
  136. magnaflow muffler
  137. sluggish in first here and there
  138. 86 F150 lost all electrical - a bit stumped.
  139. Fan running...
  140. Where to get sun visors for '86 f150?
  141. A/C On = No Power...Help?
  142. spark plug wires
  143. Spark PLugs
  144. f150 fuel tank, what fits?
  145. New Member here with a 95XLT F150
  146. A/C vacuum question
  147. maximum tire size
  148. 4 wheel drive problems
  149. stock 302 engine for 1985
  150. truck problems.
  151. 4X4 Conversion
  152. Hi Everybody. (Noobie with a few questions.)
  153. Can't quite figure out what it is...
  154. First off, Hi everyone I'm Nick!
  155. Tune-up time! Need plugs, wires, etc... recommendations?
  156. auto hubs
  157. PKRWUD this one's for you
  158. Check Engine Light, Code PO 155
  159. Intro/4x4man Hub Noise(did Search)
  160. Right front hub
  161. What the hell is it?
  162. 94 f150 2wd 6 in lift on 34s
  163. Rear Springs
  164. back on the road
  165. 86 f150 302
  166. TPS is out of range
  167. How much collant in a 5.8?
  168. best engine/tranny to tow horse trailer?
  169. Does Anyone Know Torque/Procedure Rear Pinion Bearing 1996 F150
  170. AC compressor
  171. bad anitfreeze problem
  172. sounds like an orca
  173. seat for 89 f150
  174. 1995 F-150 5.8L... HP rating???
  175. EEC Ground Wire
  176. Finally got pics on here...
  177. Steering Gear Leak / Vacum Things
  178. Battery Keeps Dying
  179. Tires and front springs
  180. i have a really old tachometer and want to hook it up
  181. Upgraded Seats... Heated? Plus, How much should I Sell My Truck For?
  182. solid mounted fan to thermal clutched fan
  183. which fuel pumps are most common to fail in a dual tank truck?
  184. does my EGR vacuum regulator work??????
  185. Ammeter/alternator wiring...
  186. i cut my airbox
  187. intake mainfold and throttle body
  188. Can anyone run a Carfax?
  189. Cup holder inserts?
  190. spedo stoped working, shifts hard too
  191. '76 F150 stock grille w/ square lights
  192. same codes as before plus one new one
  193. New member with a project: 1995 2WD F150 with 4.6 SOHC and single turbo
  194. Where Can I Buy A 1979 F250-350?
  195. Transmission Question?
  196. Clifford=Christine
  197. Racing the engine
  198. Tips on removing O2 sensors
  199. Dana this, dana that....
  200. Wire bundle/plug in glovebox, 1985
  201. Will this cold air intake work on my 92?
  202. Just wanted to share...
  203. What years 300 I-6 are mass air?
  204. Tach and Transmission Temp Guages
  205. Inacurate gas guage, front tank only
  206. which f 150 is best for daily driver ?
  207. Fuel Press. Reg causing leak elsewhere?
  208. bigger throttle body
  209. what is this solenoid? what does it do?
  210. Coolant leak near TB?
  211. No Fire---help!!!
  212. Electrical Woes.. Air Bag Code 52
  213. Are any of your trucks this way?
  214. How do i know what transmission is in my truck?
  215. driveshaft?(1987 302 4 speed)
  216. over sized TB
  217. How do you put the rear seat down?
  218. Rough Idle
  219. 96 F150 Squeaking Rear
  220. What is the best oil and oil filter to use???
  221. oil filler cap?
  222. 94 Explorer Transmission Question?
  223. Headers on a 93
  224. what is it
  225. Power window wont go up 1990 f150 HELP!!
  226. 89 302 stalling problem,
  227. pcv and fuel filter issues
  228. 96 F150 Wiring
  229. Need a step by step of how to replace headlight lens?
  230. popping through carb
  231. new to Ford Trucks
  232. No cruise control
  233. Manual hub swap
  234. oil problems
  235. Questions with engine swap
  236. Mass Air Conversion - 94' w/EOD4
  237. MPG's
  238. Heated O2 Sensor
  239. 1990 4.9L Help
  240. Mass air injector harness
  241. check engine light
  242. it knocks when it sat all night
  243. 1995 Lightning
  244. Have question about F150 4.2 V6
  245. Did Ford make a diamond plate rear bumper factory?
  246. Super Swamper Tires
  247. Looking to buy an '89
  248. Which engine is more durable and reliable? 4.9, 5.0, 5.8?
  249. Fuel gauge acting up
  250. P0443 code. Help Please!
Search Engine Friendly URLs by vBSEO 3.5.2
