View Full Version : Lightning
  1. Painted body factory ground effect pieces ?
  2. Emissions Test with JDM Longblock etc
  3. FFW in Gainesville this year?
  4. F'n Snow!!!
  5. Bad experience with Brisk plugs!!!
  6. front runners
  7. Any Group Purchases/Buys in the works?
  8. Lightning Dash Kit Revision 2 (pics)
  9. Predator Question?
  10. Anybody having trouble with Walbro pumps?
  11. Blower fan quit working at lower speeds
  12. Engine Install time and pricing?
  13. Anybody notice the replacement UCA are...
  14. Fuel Pumps Install
  15. Serious issue with aftermarket hood. HELP
  16. Help please w/belt size for Ruslow inderdrive pulleys.
  17. will emblem off honeycomb fit newer grills ?
  18. drivshaft pictures
  19. Electric Fan controllers/Wiring
  20. Some pic's of my new PSP Motor, WOO HOO.........
  21. OEM Fog lamps for 2001 Lightning
  22. Porting S/C
  23. My 58" Tq Arm bars from LFP (Yellow)
  24. Sal (PSP) 2 questions
  25. Got some Ruslow underdrive pulleys for a good price.
  26. Did you cover your fan clutch after e-fan installed?
  27. The Best Head Gaskets ?
  28. pullys that add 6lbs of boost
  29. Owners of 1999-2004 Cruise control switch recall [merged] Pictures inside
  30. lightning purchase
  31. HVAC fan makes strange noises when cold = normal?
  32. Cleaning MAF?
  33. Probs at the track
  34. I think I found a performance rear diff cover that will accomodate large swaybars.
  35. What size tires for 22's?
  36. Who has installed Ruslow's SS front brake line kit?
  37. The 700 hp twin turbo Frightning!
  38. Airbags?
  39. Call all you upgraders
  40. How many east coast Lightning owners?
  41. Bad time of year to sell L?
  42. How much difference have you noticed.....
  43. Classic within it's own era
  44. diablo chip questions
  45. Classic within it's own era
  46. Whats up with wet okole?
  47. someone please explain to me
  48. Diff between standard 160 stat and Hypertech?
  49. Hi, New to this Forum...
  50. R.E.M Oil Seperator Maintence
  51. "what Is Horsepower Difference In Magnum Powers And Eaton 112
  52. Stock L vs Duramax
  53. Man, my gas mileage sucks!
  54. Mirror turn signals
  55. calling ruslow
  56. Shoud I Trade Mine For This One
  57. Can someone help buy new car
  58. Oil Blow-by from filler (people with plugged PCV)
  59. Tubes for E/T Streets?
  60. Who can estimate my L's horsepower
  61. Coil Pack Bolts, where can I get them?
  62. Newbie
  63. 3157 Silverstars link?
  64. PI torque converter??
  65. Southern SVT Lightning Gathering
  66. Oil filler neck breather ? Is this the one i need ????
  67. Question about tuning (Pros in here please)
  68. Does anyone have some stock springs they want to get rid of?
  69. Goodbye L!
  70. WTB: air filter housing to maf...
  71. Stock boost
  72. CnL upper intake plenum
  73. Clear Tail Lights??
  74. What a stock Predator tune does:
  75. anyone with 4.10s and 450hp
  76. Possible KB scam
  77. Cold weather q's
  78. End result for my KB timing and shut off threads
  79. exhausted lightning
  80. is this fixable?
  81. Trucks Keeps Stalling @ Idle....HELP??
  82. Which cams are better?
  83. ? on 90mm mass air flow sensor for 99-00 L
  84. Anyone using Sunoco Unleaded Race gas?
  85. Check this L out some other pics...
  86. Ram air hoods
  87. 5.4 DOHC intake for the Lightning
  88. Cold temperature questions
  89. anyone in orlando area help with plug change?
  90. Eaton bering lube is... what?
  91. Got Nice Weather? Lets see how your L looks...
  92. Do you have a upper pulley and pulley puller from RPM Outlet?
  93. Sal please call me
  94. Oil ????
  95. is this normal (gauge cluster)
  96. just wanted to give kuddos to JDM
  97. hypertech programmer
  98. Gear selector on dash problem
  99. Tranny Help! Fluid problem
  100. HIDs installed
  101. Never worry about plugs again on a stock truck?
  102. Bearing issues and oil to use ??
  103. Air/fuel Gauge
  104. here chevy .....chevy....chevy
  105. boost gauge
  106. What size tires are you guys using with 20's?
  107. Anyone that has had Engine Blow while under warranty!
  108. i dont think i will ever drive my L again!
  109. Need To Mount Extra Phamton Gauges
  110. Do You Start Your Truck While It Is In Storage? Pro/con
  111. More whine?
  112. putting expedition sunvisors in my lightning
  113. 2001 - UP Lightning factory upper grille insert
  114. Clear tail lights on a white 99L
  115. Chip Reburn for altitude...
  116. Pictures of my refinished Dash
  117. Kenne Bell Boost Question!
  118. 60# injectors are shorter than the rest?
  119. Adjustable fuel pressure regulator (97~98 rails)
  120. truck died at WOT
  121. Dyno Tune in NC
  122. Bassani BX series : Review
  123. Has anyone made a upper intake for a KB cheaper than JLP?
  124. how's your truck doing?
  125. Roush Full Drop Kit...
  126. timing with 20 psi (KB) and 100 octane
  127. ford parts guys need help on 02 sensor fitment
  128. Anyone have any suggestions???
  129. do the new style 03/04 fogs still crack like the 01 style?
  130. I know the Way SUAVY gets his Boost !!
  131. Moroso pan
  132. German Stock CAI in the Lightning ;-)
  133. Brisk Plugs
  134. Art work under hood ?
  135. The Roush Lowering Kit Sale Is Over
  136. Question on 99-2000 L
  137. How do you know when your fuel pump is going out or bad?
  138. Plugs
  139. Nitrous Bottle custom painted
  140. Pic's of Bearing # 7 (WOW was I lucky........)
  141. Machine Shop found some EXTREMELY interesting info about our Blocks
  142. Need a pic of a red L with Roush kit.
  143. I got hit!!
  144. Finally made it into the 400/500 club!
  145. Drove My Lightning Today With New Jdm Motor
  146. Fog Lamp / Fuse Location Question
  147. Best kind of Slicks??
  148. new to lightings
  149. Metco 6lb Lower ? Re : allen head sizes
  150. A-Pillar gauge pod for 2004?
  151. Just picked up my first Lightning, Does anyone know whos truck this was?
  152. Does Factory Tech do AOD-E trannys?
  153. blower noise ? (again)
  154. What size are the Snout bolts?
  155. race gas mix question
  156. Any Lightnings from the Bay Area?
  157. Mobil 1
  158. Lower Pulley Hitting Trans Fluid Line??!!
  159. How do our trucks compare to Z28s and Ws6s
  160. Pinging w/ 6# pulley
  161. Dyno'd - What Should It Turn?
  162. how do you get rid of water spots???
  163. Kenne Bell ???
  164. P1152 Fuel Air Metering code
  165. Does anyone sell a polished upper pulley in stock size?
  166. New here, just got my truck
  167. Hood Scoop Ideas ?????
  168. Seat of pants feeling on 4 LBer?
  169. Creative ideas for gauge placement?
  170. Metco...What size bolt???
  171. Been thinking about a body change...
  172. Anything wrong with this way of keeping oil out of I/C?
  173. boost bypass??
  174. replacment cats?
  175. For you Burago people....Chrome version
  176. Collection of Scans, vehicle info sheets
  177. IF YOU HAVE 20's/DUBS PLEASE COME IN!!!
  178. Problems from using Bell Tech springs
  179. Lightning rims
  180. Power gains
  181. C&L Upper vs. Stock dynoed today
  182. Who has built their own motor?
  183. New Rims... Pic
  184. Problem with my '03L, please read...
  185. can someone host
  186. ABC Exclusive hoods
  187. SCT 9100 reprogram
  188. Help get me back into a Lightning
  189. Why would DJM post this on there site?
  190. Car Show Guys/Gals
  191. FTVB for a SuperDuty?
  192. Whos Truck Is This? 646 hp and 804 ft pounds of torque
  193. Bassani Mids with Magnaflow Catback?
  194. One more dumb question (where do bump stops go?)
  195. For Shaker Owners.
  196. Racetested?
  197. Supreme Performance Cat Converters
  198. Calling 00Bolt
  199. Lakewood traction bars?
  200. Added Ghost flames when I had paint damages repaired..
  201. Show me your aftermarket Hoods
  202. Want you to show my L and my US cars before part 1
  203. Gainesville Raceway T&T
  204. Supercharger noises and problem checking
  205. Coil Pack Boots
  206. JDM Interchangeable Pulley Bolt
  207. idler pulleys
  208. serpintine belt
  209. Need help with front coils and rear leafs (extra parts...)
  210. 6 lb pulley questions/ intercooler leakage
  211. emblem for 01+ grill same as 00 emblem?
  212. My L needs a new starter?! WTF?!
  213. Which taillights on my White 99??
  214. Part number for L Alternator Pulley needed
  215. whats verdict on C+L plenum
  216. Have stock VB laying around........
  217. Do Kenne Bells still lock up?
  218. Nitrous kits
  219. Cog Belt System???
  220. Methnol Injection???
  221. Throttle Body Question?
  222. billet window switchs
  223. A different clunk
  224. Leaf springs?
  225. Not happy! Not happy at all!
  226. Its time....
  227. Calling all Photoshop Guru's
  228. Headers
  229. Oil filler breather cap, Where can i get one ???
  230. Really strange noise?!?!
  231. Is this anyones??
  232. Rusted Bassani
  233. predator tune
  234. Dyno testing/tuning, KY
  235. Stupid Testing
  236. What happens when you dont clean your exhaust
  237. any of yall got shakers?
  238. blower pullys
  239. Pics from 05 Silver Springs Show
  240. SCT XCalibrator Tuner
  241. Looking for picture of Lightning
  242. What oil should i use ?
  243. Whats the best ... oil separator or Cap off the intake and use breathers ?
  244. Can I start using this oil??
  245. flat out against a bmw
  246. Sonic blue - with dark SS-Style grill = Pics?
  247. FTVB Question
  248. Inexpensive Boyd's?
  249. brake pads Where and whos the best?
  250. Dynatech cat less mid pipes?
