- Problem Resolved ...
- whipple #s later today
- JDM Day RESCHEDULED!!!! NOV 16th Due to Weather : (
- Does anybody know what the part number and description is of
- 99' lightning insurance costs
- Times For Stock 2002 Lightning?
- Spare tire key
- Fords at Etown pt.2 Vids
- Two dead cylinders... I need help....
- Roll cage pics
- 9 sec. all boost pass in a Gen 2 lightning **VIDEO**
- NX users jet size question
- where can i buy??
- authentication
- "L" throwning codes
- ***Lightning Cost?***
- head problems?
- 2002 LIGHTNING QUESTIOnS!!!!!
- Fords @ Etown results!!
- finished the plugs and have questions on what i found
- PSP now open in FLORIDA
- how do i make a photo gallery
- Couple vids of my truck
- 1.5X and lower 60' guys.. More race suspension questions...
- FINALLY! I'm in the 10 second club!
- got some bosch platinum plus
- Think we might have a problem
- 2 New Lightning Shirts plus 5 others
- Anyone have How-To for the IC pump?
- Changing Oil
- What Temp Thermostat With Built Long Block
- what are the gains??
- Wierd spitting sound
- pinging and gas prices
- Going built in NJ. Need advice
- best bang for buck spark plugs?????
- New Best Whipple stock block results from ATCO
- Atco Results
- update on the shaking..still need some imput
- Headed for the dyno
- CtTopGun 10 Sec Club member
- Do you REALLY love your Lightning
- Fords @ Englishtown this weekend!!
- 22k for a gen1
- New pic with polished wheels and hood
- Best Insurance In Southern Cali
- Wot???
- violent shaking at 45
- A couple questions about lowering, t-bars, and racing....
- Changed you pads lately?
- theft light flashing
- Woo Hoo!!!
- Front drag springs
- carfax help
- not sure if i should buy...need help
- Need 12v feed from headliner and--
- Shop Manual
- SCT tuner ?
- Been gone for a couple years, hehe...questions on exhaust, chips
- MD fixed my truck
- Head Unit Fittment?
- Mark @ LFP is a pimp
- Looking for Mobil 1 oil cap
- Some pics of the slicks and skinnies mounted
- mod question
- DMP/Famoso private track day 11/17/07
- Should I screw them?
- Whats The Average Life On A Lightning
- Holding Value... SVT vs SRT Trucks...
- hey is this vid any of you guys?
- Steering Box
- engine fogging
- White Face Gauge Overlay Pics? or Suggestions?
- New World Record ET !!!!
- Grinding Front/Rear Brake Calipers to Fit 15" Bogarts **PICS**
- separate Fuel cell for Nitros
- How much timing before your power falls off?
- opinions/answers wanted!!!!
- The Texas Mile (Videos Included)
- engine stumble.
- 255/45/18
- can i fit a smaller tire?
- Anyone else here have Weld XP wheels besides me??
- To remove the door panel?
- instrument panel help
- Carfax
- Gauges
- Anyone With External Transmission Filter
- Check Out Ny New Ride
- hankook rh06
- changed rear diff fluid
- turbo
- Big thanks to Mike Chester!
- What are the symptoms...
- throwing two diagnostic codes LONG!!!
- where to buy CHEAP hid bulbs
- First Annual Florida Lightning Strikes Event, Reminder...
- Open Header
- Best place to get a 2000 shop manual?
- Just Sold My 04. Thanks For All The Help
- More steigemier porting results
- Spare tire & jack removal on drag radials???
- Explanation of our Fuel Pressure Regulator?
- hey texas people
- Pressure testing AN hoses
- To install 04 outside door handles?
- i am at a loss/help!!
- Jim And Jdm Engineering Are You All Coming Out To Play?
- STOLEN!! Truck and trailer
- Twin turbo 32V Fires Up!
- No reason but want a wood S/Wheel :-)
- more problems with the L
- Exhaust Leak
- stiegemeier port and polish
- Inside door handles
- Lowering Shakle Question
- Shelby Heads On The L
- Big Problem w/ my lightning
- 500 Hp Lambo Ford Lighting, Looking for opinions
- Battery relocation question for Tim Skelton and those using an alternator relay
- Let's hear some testimonials from those with the WMS suspension stuff
- REM - Must read.
- Need Alot Of Advice!!!! 2000 Red L
- Calling Defaudio!
- Couldn't stand it no more
- SD Cams
- PSP Nitrous Plate
- Schraeder valve, fuel filter...
- High rpm heavy load. Miss that goes away?!?!?!
- How-To: Build and Install your own Line Lock **PICS**
- calling new mex and colorado lightning owners
- Did search but still have 2 questions
- Stock Airbox Holes
- Best aftermarket pulleys & intake
- Ford Fun Weekend California Speedway 10/19/07
- Why Does It Stumble?
- Winter Beater Carfax Please
- Hey SVT F150 - Found a Blown Motor Lightning
- Everybody is going Big Tire and all fancy.. Not me
- Trustworthy Repair shop N Houston?
- GK_crewchief's SD Tran Cooler install + How-To with pics
- Just got back from 14 month deployment
- Turtle ice wax
- Dmr
- 2001 front calipers
- removing welded in flows
- Thought I would never see this day!
- Lightning Injectors?
- Adding tow package
- Anyone ever measure the ohms across tran temp sensor?
- third set of pumps
- Built engine problems
- need help picking out an aftermarket torque converter
- Aeroforce Interceptor Gauges OBD Gauge GP
- engine light on...help!
- Oil Pressure at Idle
- Post your breather set-up's
- buddy needs help
- 11s Lightnings step in and help
- Experiences with stainless steel braided hoses
- New Lightning Diesel?
- :( Poor trucks...
- Lightning Friends This Ticks Me Off
- My battery just took a dump
- pump volts
- Paging Sal!! PSP, chime in ...
- Repair manual for 99 lightning
- Diff Cover (w/ drain plug) on lowered '01
- Oil Weight for Road Course
- The Official JDM Day 2007 Thread
- New Lightning owner. Looking for suggestions!
- QA-1's
- Intercooler cleaning and plug check
- 99 lightning standard spark plugs
- Which used Lightning?
- fuel alternatives?
- New track times!!!
- Tranny Leaking
- fuel pressure/trouble shooting?
- Thanks to JDM
- Brake conversion
- 18mpg
- Does 2003 Lightning Have Torque Converter Drain Plug
- Help Guys
- 1% Frame modifications for a ground up rebuild
- found some x-factors
- Stock gears to 4.10's
- Weekend Plans, You Bet......
- staring at a lightning
- Intercooler pump...
- Issue with Late Model LED Third Brake
- the good idea Piņata is struck again
- I Just Got Off Phone With Autometer
- All you lowered folks - Bump stops???
- Magnaflow Exaust and Cat Removal?
- Tranny shifting hard
- How should I price my L?
- Anyone Ever Use The Aero Force Gauge
- How much amps should a alternator read???
- Class Action Lawsuit
- Turbo Or Whipple
- fuel pressure issues
- Has Anyone Had Problems With Bassani Tips
- Gen 1 Lightning needed for commercial shooting in Los Angeles!
- Anyone know this truck?
- Re-tuned for ethynol, new #`s, thanks PSP!
- Any X Plan Pins Anymore?
- buying a lightning but living in the uk
- Saying goodbye
- Dyno results are in!!
- Second Thoughts Big Time
- Who all has done the coolant crossover mod?
- Oil Seperator on my whipple....
- gaylord lid lock busted, looking for a part.
- Anyone Seen This Lightning on EBAY??
- How to run 11s?
- Fun Ford Weekend Ennis Texas World Finals!!
- Parting Ways With The Lightning
- Really Really Upset!!!!!!!!!!!!!
- hitting the dyno in the morning :)
- 2003 lightning Intercooler fluid change
- Jdm Day 2007?????????????//
- What should I paint the underside of my tonneau cover with?
- need new brake pads
- Lighting Upgrade Help Please?
- Dyno Tune Question
- Anyone ever had a serious issue from a clogged injector?
- Boost limit of stock engine and blower?
- Carfax for a long time member please
- Transmission durablity?
- Truck will start then die.....
- Anyone know what hood this is?
- 9 sec. project Norway
- cost of rebuild?
- Purge valve is bad...
- amp/sub
- Tried the dealerjim method of draining the fuel tank
- Installed the LFP Radiator today
- Rob's method of changing Supercharger oil
- Lightning Friends I Need Help
- Lighting killer!!!!!
- Looking at Used Lightning - Oasis Report
- Where to get another spare wheel/tire??
- Heads Turn Still... :)
- Mega Ford Weekend
- Ftvb
- On Track at Gingerman Sept 15-16 2007
- Fuel Filter the cause??
- Odd Hum From Engine Compartment
