View Full Version : Lightning
  1. need help
  2. Feed back on your Wideband A/F
  3. Testing the posi unit? Should the tires turn when jacked up?
  4. Tailight Condensation
  5. bye bye gas mileage
  6. Will a bad Throttle PositionSensor cause the line pressure in the tranny to increase?
  7. how often do you change the transmission fluid?
  8. What happened to this poor L?
  9. Crank walk?
  10. Lightning replacement
  11. boogers radio delete
  12. Is anybody running this A/F wideband gauge?
  13. The L gets cleaned.
  14. how much boost and power can our stock blocks handle?
  15. After installing 58" torque bars....
  16. Seat ?
  17. Wheels and Tires For 2002 Lightning
  18. FRPP lowering kit
  19. oil leak
  20. Will the Ground Force kit will fit my 04 L???
  21. KB = no boost
  22. baby on the way, selling truck
  23. I hope ford learned their lesson and
  24. lowering my L
  25. Question for anyone using the SCT Excalibrator.
  26. Plastic Smoothing Experts: Questions...
  27. 20" 03-04 replica wheels do they make them?
  28. Finally did a little custom work on my truck!!!
  29. Alignment Question?
  30. Looking for an Efan....
  31. boogers backyard fuel set up
  32. 99's might be affected!!
  33. Southern SVT Lightning Gathering 2005 Photo Gallery
  34. Fluidyne Exchanger Pictures
  35. Tranny shifts way to high and hard??
  36. I Touched the new Adrenalin
  37. New Dodge Truck, Lightning Comp? Ram Daytona.
  38. JLP Predator tune and TIMING...
  39. Leaking Cooling System???
  40. First night at the track with new mods.
  41. AHHHH! The sunlight!! Subtitled: Having fun again..
  42. First time at the track with my '01
  43. Part # please for QA-1s with 3" drop.
  44. Belt slip? Or something worse?
  45. What's my problem, fuel or MAF?
  46. Detonation 101
  47. Dyno'd today (the fuel pumps won't cut it)
  48. Sound proofing and question on Shackles
  49. bad00's set-up
  50. Getting my head straight
  51. A.R.E. LS II Tonneau Cover ? Need your help !
  52. Vacuum canister questions...
  53. Kenny Brown XFactor
  54. OK I think I am officially ready...
  55. Tranny #2 Failed!
  56. Pod for Steering Wheel Column
  57. stock fuel pump went--7,000 miles
  58. Front Bumper
  59. Eaton is back on & Intresting observation though...
  60. TPS ground
  61. JLP R series headers and 3" exhaust
  62. Throttle Body Bolt!?!?!?
  63. Spotted some Lightnings down South on my Journeys last Sunday.
  64. oh no...!!!
  65. AirForce One + Airaid Compatability
  66. Who Else Owns a Turbo Lightning?
  67. boogers backyard tubed lightning
  68. AirForce One + Airaid
  69. Nitrous install help
  70. Motor making noise. Won't start.
  71. Wrong Parts? - chain tensioner
  72. Accuracy of factory boost gauge?
  73. will i need more?
  74. LFP=Great Service
  75. 60# Fuel Injectors $399.00
  76. 99 2000 owners need info
  77. Lightnings........San Antonio.......
  78. Had the truck on the dyno!
  79. WC Arms powdercoated
  80. Stock Lighting rear axle
  81. JDM 3.3 vs. PSP turbo vs. JLP frame mods.
  82. KB with 3.5" Upper & 4 LB Lower
  83. Any guys in Vegas with upgragded transmission
  84. Extended Warranty
  85. best intake?
  86. Freakin' eBay....
  87. Valve Cover Opinions
  88. GRRR!! 200 miles on my KB and its done....
  89. My Spoiled L will now be a ...EEEK!!.. Trailer Queen
  90. Whipple Fact or Fiction??????????????
  91. Kenny Brown X Factor
  92. Srt Quad Cab Vs Lightning
  93. Anyone ever been sued after an accident?
  94. Lighting Gauge Cluster In Regular F-150?
  95. Where to go from here? Want more power..options?
  96. Wheels
  97. rock and a hard place
  98. MP Green coupler poll- Who got one
  99. unbelievable Photo from germany !!!!! today---- The 3rd
  100. Boost BYPASS valve, And 60' times = lower 1/4 mile times?
  101. Anyone w/ black chrome wheels?
  102. Help with seats
  103. Ordered a Fluidyne Heat Exchanger
  104. im tired of looking and finding no links- Which Vendor Black Billet Grill Upper/Lower
  105. Stage II heads plus Ported Eaton
  106. Cai
  107. Loose motor vs tight motor
  108. slvrlight04
  109. Question for those Crower stage 3 users.
  110. The definitive Magnum Powers / Eaton comparison
  111. contacting FT
  112. New Wheels
  113. Do I need open end lug nuts?
  114. Places to Buy Expy Console?
  115. What u guys think ???
  116. 11's
  117. Oxgenated fuels
  118. Data logging on the go.....
  119. All those with L&S Automotive Oil Seperators!
  120. Help! IAC and oil or something?!?
  121. You are going to love this.
  122. Special Thanks to Autoway Ford - St. Pete, Florida
  123. Wallpaper 12: SVT Epinephrine
  124. I got a ride IN the PSP TURBO POWERED BIG BAD RED BEAST, !!WOO HOO!!
  125. information on pulling spark plugs
  126. Which Is The Best Plug For Our Built Motors
  127. motor reassembly question
  128. Best Hooking 20in Tires?
  129. new exhaust
  130. Symptoms of bad u-joints or driveshaft
  131. Anyone know the weight of an Eaton M112 blower?
  132. Canton ALuminum Coolant Tanks?
  133. Tuning a stock-block Magnum Powers
  134. porting blowers?
  135. Calling SCT Pro Racer Users
  136. Is there a general consensus on the EGR Blockoff??
  137. Spark Plugs?
  138. EVAP removal?
  139. Rear Leaf How-To
  140. Blower Maintenance
  141. WTH is this unused sensor??!!
  142. ATT: Big Man
  143. Painted and Decaled my Calipers
  144. Holy can you say 20 lbs of Boost IS NOT a problem
  145. tr6 gap out of the box?
  146. Has Anyone Painted Their Wheels ?
  147. Egr Blockoff
  148. Turbo'd L's
  149. Magnaflow soundclips
  150. Quick Question Before I order Nitto DR's!
  151. Clear Differential covers
  152. Overspinning the Eaton
  153. Rear tires for HIGH HP trucks? Street tires
  154. Any chrome covers for stock exhaust tips ?
  155. Buying factory replacement parts (wheels)?
  156. Started to acetone my emblems yesterday
  157. 5.6" I/C fans vs 6.5" fans?
  158. Is your harness out of date?
  159. Can I use the same belt?...
  160. I want taillights like the Lexus RX-330
  161. Sonic Blue 03 Price??
  162. to stroke or not to stroke
  163. BIG thanks to PSP and Adrenaline Motorsports
  164. Rear axel assembly
  165. This is what happens when you go to a dealer.......
  166. Buying out of state experience?
  167. Video:Warming up the Lightning
  168. need help
  169. sport trac adrenalin
  170. need help.....
  171. Frame Coating?
  172. stock L hanger
  173. JDM Short block rebuild kit
  174. Well I did IT!!!
  175. Southern SVT Lightning Gathering 2005 "Last Reminder!"
  176. Flitz It!
  177. JDM Motor Pass's the Test
  178. What do you think ? opinions needed!!
  179. Console mod almost done..pics
  180. 63v 02 sensor reading?
  181. Oil/filter ???
  182. A couple of little Mods can made a big difference
  183. AAD Cobra Cowl
  184. 4.10's Pros/Cons, Slick Size Rpm Difference/ Mileage diff.
  185. When to change to summer tune
  186. Lightning Guts
  187. First pics since getting DA BOLT back.
  188. ordering chip for new lightining
  189. f150 online shopping
  190. Eaton S/c
  191. Oil filler tube
  192. bell rose
  193. 1/8 times
  194. The new SVT head guy is already showing his utter lameness
  195. *new Items In Stock!*
  196. What a great place to learn about our trucks
  197. Ported blower for sale???
  198. One quick question.
  199. Radio Bezel Installed
  200. unbelievable Photo from germany !!!!! today---- The 2nd
  201. Electrical problem with new 510 PIAA's.
  202. Upper Intake Plenum
  203. My L is running bad, again.
  204. 8.3 at 85 with a 1.9 60 ft. in my misfiring truck
  205. Would this be a realistic asking price for my L?
  206. 1/8 -> 1/4 ?
  207. Mickey Thompson slicks
  208. First time at the track
  209. whose running 22's??? A couple ?'s
  210. third times a charm
  211. Heat Exchanger Question
  212. sonic blue with 03/04 chrome
  213. Vid of RAMAIRSVT's 10 sec pass
  214. Do I need a bracket for this console?
  215. Please tell me if they gave me the wrong kit with this gauge ???
  216. Exhaust Exit Delete
  217. Borla Stinger?
  218. Help with Data readings!
  219. Fastest MP Stocker
  220. Stiegemeier port?
  221. calling clonetek
  222. Sal, I got the tires. FYI
  223. Psp
  224. Question for wideband users
  225. CDDJ...... Huh
  226. Finished my custom LED tails
  227. Hotchkis Rear Leaf Pic/Question
  228. Newest member of the RACETESTED club
  229. Installing custom seats, can keep power controls?
  230. Seat protection
  231. Motor Pulling Hints
  232. Water Pump Shaft Play
  233. noob
  234. Is the two weeks up yet? Has anyone gotten the 2.3 on yet?
  235. Stock Block Kennebell Users
  236. Etown Friday 3/18
  237. Help Oil Pressure Issue
  238. billet grille install????????????
  239. 2.8 installed!!
  240. Anyone using the motoblue intake?
  241. Might be getting another L after all
  242. Sal
  243. Has anyone moved the CD CHANGER? (ading 2 10")
  244. New block?
  245. Does a Lightning motor fit in a mustang?
  246. Boost gauge issue?
  247. Anyone try any digital boost gauges?
  248. Its a thunder, NOT a lightning! What is it?
  249. Power Folding Mirrors...
  250. first time at the track last night
