View Full Version : Lightning
  1. Comp behive spring pressure?
  2. Broken underdrive pulley
  3. Lowering Pulley Question
  4. Interior paint
  5. Red L @ Mufflex?
  6. Spark Plug Holes, UPDATE and port and polish
  7. Painted SC black, now i want to change the color
  8. spacer question
  9. Supercharger cleaning questions
  10. STOLEN Lightning from Seattle area
  11. Belltech Drop spindles pics
  12. predator data log
  13. More Whipple pics and opinions (as requested)
  14. A more than likely very stupid question about the QA1s
  15. I need a how to...
  16. Clunk Washers and Alingment Done.
  17. So I got these new shocks today...
  18. upper pulley?
  19. Truck is done..help me
  20. Noise from under the dashboard
  21. Anyone have a "custom-fit truck cover"?
  22. MB build kit?
  23. Yokohama Advan ST 295/40 R20 tires?
  24. Brake question
  25. E4OD Shifter Linkage Problems
  26. New Black Silicone Couplers for C&L Intake Tubes
  27. still trying to narrow down problems with truck..questions
  28. lightning insurance
  29. Trans capacity
  30. sct xcalibrator???
  31. Lightning Overhead module in Expy Insert
  32. Why don't lightnings 60' worth a darn?
  33. n2o questions ?
  34. Congrat's to JLP
  35. Need Canadian X-Plan!!!
  36. GUILTY --- Hanging around ROB too long ...
  37. weld wheels for 99 L...
  38. tubes needed w/slicks? Best deal too?
  39. Predator 8r9 firmware new features?
  40. Moroso Transmission Pan Studs
  41. Nitrous vs pulley
  42. LED bulbs
  43. boost actuator?
  44. Ported Eaton install. Not sure about something
  45. Anyone running H/C and a ported eaton?
  46. Fun Ford Weekend racers read this
  47. Suspension shop in Chicago NW burbs?
  48. Help me build my Lightning garage
  49. Any Results from FFW?
  50. was bored today at work and ..........
  51. Steering Box Leaking
  52. Anyone running a 8 probe egt setup?
  53. Custom Car Graphics - Dallas "APE" Wrap ?
  54. torque converter questions
  55. Mod Albums...Hoods/Tonneaus/Lights/etc...
  56. fibernetics bed cover pics
  57. Dynatech Headers & Bassani Cat back How To
  58. Colder Plugs
  59. complete lightning deivetrain swap into expedition. questions.
  60. Sorry for newbie question . what size I should to choose ?
  61. Norwalk FFW Pix from Saturday!!
  62. Tuners in San Antonio???
  63. hacking rear bump stops, how much??
  64. Stereo finally finished
  65. Will I need clunk washers with DJM lower arms?
  66. Mas ??
  67. lightning...tires and suspension
  68. Solid back glass
  69. will installing the clunk washers affect alignment settings???
  70. Yet another question for you suspension guys...
  71. Do all tuners turn off the rear O2 sensors?
  72. Fuel part? and where to get?
  73. Finished Painting my Calipers (before and after pics)
  74. autolite sparkplugs?
  75. Went to the track(1/8 mile)
  76. 4lb lower won't fit my 99 PICS inside
  77. Limited slip additive.
  78. I need some new exhaust...who has the best deal?
  79. Question for Chikenears....
  80. Headliner Mod!
  81. question on lowering and not installing cam bolts..yet
  82. intake hp Q
  83. pcv kit
  84. Bassani cat back ?
  85. Vacuum diagram
  86. Q-Logic Kick panels
  87. Predator & shift points
  88. useful ODB-II gauge
  89. 4:10 gears
  90. 2004 stock lightning vs 1999 corvette hardtop, 6 speed
  91. Help !!!!! with Lowering please
  92. My second gen2 is gone....
  93. Anyone Running A Innovate Motorsports Lc-1????
  94. Anyone running 03 wheels with Brembos?
  95. Boost help..please
  96. 4x4 Pan
  97. boost cooler ??
  98. Any Online Salvage Yards?
  99. Wet Okole Question
  100. keyless entry keypad stuff
  101. Since they don't make Lightnings any more . . .
  102. What in the heck is making this noise...I tried...
  103. bedrug on eaby
  104. How can I do a leak-down test
  105. If your having problems finding my house
  106. cold air intake for my truck ?
  107. Brake Question
  108. Should I stay away from dealerships??
  109. Just went to the MP site for a look, and...
  110. Port the eaton or #4 lower?
  111. Fiberglass on the L?
  112. Autox vid from Saturday
  113. **While The Cats Away**
  114. Bad Joke
  115. Spherical Valves
  116. Bird Kraaap!
  117. Lightning dress-up valve covers
  118. Are these the right shocks??
  119. Where Can I..............
  120. Check out my I/C off my 99
  121. Coolant Flow Path for L Cooling System?
  122. Help with Rotors/Bearings/Races!!!
  123. Another Outrageous Performance engine bites the dust
  124. lightning VS. cobra??help
  125. 4# Lower
  126. anyone go to Bristol Street Fights?
  127. boost actuator adjustment.??
  128. EMPLOYEE PRICING for FORD!!!!
  129. jdm exhaust
  130. Spark Plug Holes/cylinder Heads
  131. Slick question
  132. Intake gasket porting question?
  133. Does someone have a Carfax they can let me use?
  134. Whats a good 22" tire? Need to order
  135. Self porting results needed pls
  136. torque reduction and predator
  137. Fuel Pressure ?
  138. What would 500 RWHP and 600 RWTQ net in the 1/4 mile?
  139. Just Detailed....Bling!!
  140. Predator with laptop??
  141. Rotorpros rotors and Ford pads. Work as good as they look!
  142. Found a new shoe for truck!!
  143. Problem with Air Conditioning
  144. Super Power Lightning Poster
  145. Newbie steps,billet and tip
  146. fuel pump power wire?
  147. Just wanted to say thanks
  148. screwed up big time.....
  149. *RACE TESTED* No2 Test Results!
  150. new homemade bling
  151. Installed my "surfboard" gauge pod
  152. Wash, Clay Bar, and NXT Gen Wax, WOO HOO....
  153. Another Newbe Question
  154. Truck Back from JDM ** X-2 Question**
  155. Dezibel - Difference in stock and Mack Cat Back
  156. Finally Getting Truck Fixed (pics)
  157. cool pic from the track today
  158. truck feels flat...any opinions
  159. Long Island OBI Show This Sunday
  160. Whippled Lightning
  161. New plugs, spray... and now problems?
  162. First Blown Plug
  163. new exhaust video
  164. Ralph Voorhees New (1320Video)
  165. At long last
  166. Cobalt boost gauge ?
  167. How to change front springs?
  168. Any comments on billet pieces I'm doing ?
  169. Leaky '99 I/C, Can I Drop-In a 10 row?
  170. Temp sender in resevoir ok?
  171. anyone in mass goin to summer nationals
  172. Out with the Old, in with the New....
  173. Zaino Bro's New GRAND FINALE Spray...PICS
  174. CAT back system
  175. Denso IT-22, or IT 24's?
  176. 95 mm Mass Air MAC/Motoblue Problems with a 99ŽLightning plz help
  177. This is really strange...and driving me nuts...!!!
  178. the Hooters Gallery is growing!
  179. Lightning Mirrors, popping the colored piece off ?'s
  180. neutral revs at track
  181. whipple super charger 175 hp gain?
  182. Anyone ever heard and/or used Pure Power Perm oil filter?
  183. Predator Timing adjustments question
  184. To 2.7 Upper, or not....
  185. My CHip Foose Lightning
  186. For those who cut their passenger seat...
  187. Eaton Vs Magnum Dyno 6 29 05
  188. Local Jersey L owners spotted...
  189. 2002 L manual
  190. The Ported Eatons putting out 17-19 lbs of Boost
  191. Belt
  192. Smoothest idle plugs?
  193. pimp my L
  194. Gregg Evans, are you out there???
  195. Where to get Black Eaton Rotor packs
  196. good deal on bilsteins
  197. tune-up
  198. Plastic dash gauge cover
  199. Tire Wear???
  200. Suspension gurus....
  201. Snapped a Couple pics over the weekend
  202. LOVE the coil pack screw mod, hate the...
  203. L Video
  204. Stock 04 Dyno Results
  205. with or with out?
  206. cleaning my intercooler...need help
  207. Quick Question About....
  208. Is this considered normal boost???
  209. Installed A Hughes 2800 Stall Converter, WOW
  210. Need help with nitrous part
  211. Tranny life?? Factory tech please respond
  212. Anyone opened and painted the inside of the tails?
  213. wonder if this would work guys
  214. LIne lock instuctions
  215. Smooth Steps and Rollpan... uh.... possibilities?
  216. Clunk Washers. I searched, who sells them?
  217. PSP's Red Beast has a new home.
  218. Lightning striks a C5 and Mustang GT....
  219. Put a 2.7 Upper on the Eaton, (easy as 1 2 3)
  220. Blown5Pnt4 wheels post your 20s and up
  221. Superchip reburn, Who would you recommend?
  222. Best way to prevent under carriage rust etc.
  223. what is everybody using for header gaskets?
  224. Are coil packs under pressure?
  225. any lightning meetings in new york?
  226. Couple FFW Richmond rainout pics and vids.
  227. Raising wheels and bending Steel (Stainless Steel that is)Pic
  228. Won my first trophy, met Chip Foose!!
  229. Need Cover for L
  230. 5.4SC *vs* 5.4
  231. Grille mod question
  232. Cog Belt Setup-video
  233. Dyno Day in WV
  234. S/C Belt Change Question?
  235. JLO-JHO Meet Pics
  236. New Lightning engine from Ford
  237. New Pulley problem...
  238. Help me! My L is sick....any input would be much appreciated.
  239. psp motor pics
  240. Whipple Installed
  241. temps increasing...!!
  242. Piedmont Dragway?
  243. Can you help me verify that I have everything correct???
  244. Did plug,pully & chip, now sputters
  245. carfax? anyone run one for me pleeeeeeeese?
  246. New HyperPac Tuner??
  247. Efan purchase help
  248. Built Engine + Ported Eaton - Which Pulley?
  249. Ebay Fuel pumps? Any good?
  250. what kind of stuff i can change ?
