View Full Version : Lightning
  1. what's needed to make SVO single blade t-body work?
  2. Farm Truck II - The Sequel
  3. No LIghtning fest updates?
  4. Built motor guys. What timing?
  5. Yo Run 351
  6. Remember AMP
  7. WBC Install anyone.
  8. Moroso Motorsports Park
  9. Hoosier Slick Tire Compounds
  10. NLOC...get a life!!!
  11. New Rivals- Hostile03SVT vs. SlowSVT95
  12. Pics of chrome 03 wheels
  13. does xcal2 save settings if you change them?
  14. New Best Today!!!!
  15. New stock long block record!!!
  16. Header applications
  17. New JLP Intercooler Tank Question
  18. did a plug change today
  19. Where to get DSG paint quick?
  20. ported blower?
  21. Trans temp sender location
  22. Thanks JDM!
  23. Bassani Midpipes and Flowmaster
  24. billet grill
  25. PATS problem maybe?
  26. Carfax please
  27. My buddy just hit the jackpot.
  28. computer flashed!
  29. I found the solution to my problems
  30. Nashville Superspeedway this weekend
  31. Factory Tech Columbus Ohio Racing Event
  32. can i use same power lead for interchiller and e fan?
  33. which under dash fuse is hot all the time?
  34. Where to find a rear-end??
  35. Torque on Hitch Bolts
  36. Guys with Radar Detectors...
  37. Swaybar endlinks
  38. Anybody have an extra X-plan Pin?
  39. Best mileage ever!
  40. IN CAR camera mount pics???
  41. RUSLOW Panhard Bar question... measurements
  42. Big SVT logo?
  43. kooks header install
  44. Please help! I am desperate...
  45. Comp XE278AH Anybody actually using them?
  46. Ford crank locking special tool?
  47. I guess this is goodbye...
  48. Got extra money to blow on truck..How should I spend it guys?
  49. Tires tilting in
  50. Flip Chip, NOS, Cat-Back= 8lb boost & 633hp
  51. What the cheapest Code Reader to Buy ???
  52. Ford Dealer said No!
  53. wrecked L
  54. PSP Efan install help - where do these wires go?
  55. Back home after a 3 week tour!
  56. JDM Day 2005
  57. What the search button does for me
  58. L vs. porsche(pics)
  59. Built motor guys ----> inside
  60. free heads
  61. Parish went 10.0x....
  62. My first 11 sec pass
  63. Complete Predator tune comparision (dyno, 1/4 etc)
  64. operating temperature question
  65. who sells mini fuse taps?
  66. trans pans
  67. Help finding accesories
  68. That Bastard Vinnie...Congrats Man!
  69. FFW Ennis pictures
  70. kenne bell video
  71. Ennis 2005, talk about HOT & humid
  72. Need some help..
  73. Adjusting Predator Tunes
  74. Axle/tire size changes via predator...
  75. Florida people please check in.....
  76. Hep with Predator and SES Lite
  77. Need some help finding parts
  78. is leaded race gas better than unleaded or is a mix ok?
  79. Washed my L and the windshield broke!
  80. Need help with inside tire wear...
  81. How much nitrous is safe with a 6lb?
  82. Engine Problems help please
  83. New and improved stereo
  84. New Best at the track
  85. aftermarket fog lamps
  86. when adding coolant, what to check? burp system? air bubbles?
  87. Jeff, Phil, Others, Pic's of that Rear PCV Hose
  88. Oh boy, new mods...
  89. Stupid question
  90. Tranny help PLEASE
  91. Help engine missfiring foung DTC P0352
  92. Alignment, can't get it right
  93. good nitrous kits
  94. FRANK getting ready for LightningFest
  95. good place to buy rubber for Ls?
  96. Help me identify the sound
  97. Magnum power dyno results within-->
  98. Going to get dyno tuned
  99. DynoJet WideBand Commander on!!!!!
  100. Checking my Coils and.....
  101. Master Parts Catalog?
  102. Chrome 5 spokes
  103. ? about Metco Idler install...
  104. 6# and new tune results!
  105. Reset PCM cures rough running!
  106. Nitto questions
  107. Silver bullet install not possible?
  108. New Guy with A Lightning
  109. Anyone have a KB?
  110. power valve question
  111. starting trouble
  112. which truck has the best selection of aftermarket products?
  113. Follow up and solution to my fuel pressure issues
  114. High boost guys inside-->>>
  115. How much retuning needed 3.55's - 3.73's???
  116. John Armstrong from texas and PSI motorsports brings you Turbo power
  117. Lower intake pcv hose
  118. couple of weird questions
  119. Rolling Stones Tickets at Giants Stadium 9/15/05 FREE OF CHARGE FOR MY LIGHTNING BROS
  120. New Wheel & Tire Pics
  121. PLEASE help a young guy out
  122. She´s on the road again ! Thank you Mark @ LFP
  123. Okay Fellows,Some help needed.
  124. fuel injector?
  125. Track results
  126. Finished the Radio Bezel Gauge Pod
  127. plug change
  128. Black chrome tail lights on red L?
  129. 2Bscrewed's custom beer cooler
  130. Dead pedal
  131. Cam swap special tools?
  132. Cam Degreeing?
  133. I lost power, can I get it back?
  134. Charlie Getting Ready For LF!
  135. I need to borrow a 10 lb lowr pulley
  136. New PRODUCT? MAF Translator Pro.
  137. Whooohoo got my alky kit today!
  138. Getting Dialed In For LF
  139. Accufab SBTB Problems
  140. Superchip & FTVB
  141. I ordered cam bolts and have a question?
  142. Who's going to Ford Fever at MIR ?
  143. Were Does My Thread Go
  144. Anyone ever have a Bad / Def Coil or Spark Plug ???
  145. Turbo friendly cams?
  146. So what has Justin@JDM (former) been up to.....
  147. AVT Performance Power Numbers
  148. Any 1 else got this problem
  149. FT/lbs Torque with a turbo?
  150. Need replacement bushings for traction bars
  151. New guy here
  152. Lightning Accessories
  153. Plugged Drivers side v/c vent good or bad?
  154. Chickenears shifter
  155. wierd sound from drivers side of engine
  156. Anyone know what triggers the fuel pumps to high pressure?
  157. Need help buying a 99 ported SC!!!
  158. 2004 L with a rust spot already....
  159. Need Help: Heater Blows Cold Air
  160. Lightning anyone?!
  161. KMC Super Sports
  162. Finally hooked up with the Twins ;o)
  163. One of the most Awesome Burnout Vids..Scott Dunn in his newly purchased PSP MACHINE
  164. Resetting Predator?? HELP!
  165. went to murillos
  166. No more Lightning?
  167. NED Bracket finals
  168. wanted to borrow, or rent: Top pulley tool in new england
  169. Factory Tonneau Cover
  170. Great weekend.....
  171. Weld racing prostar xp??
  172. Which blower has the loudest whine?
  173. Black Lights ?
  174. Lf Jlp True Street Update!
  175. Possible Lost Tune
  176. 2 degrees of camber will cause tire wear
  177. CC recall and mods
  178. which SCT MAF to use??
  179. Radiator Drain Plug
  180. Well Yesterday I decided to...
  181. Built motor guys?
  182. Jim@JDM wins Bristol FFW
  183. Practicality of the lighting?
  184. Cam timing? Could it be off?
  185. suprized to say the least.
  186. Questions about tranny
  187. Some street racing vids for your enjoyment.
  188. Lightning Fest '05
  189. octane rating
  190. '04 Parking lamps
  191. Lowering ? kind of
  192. wtf is with some businesses
  193. Alarm
  194. tps + wot question
  195. **Pic Of Our New Air Filter Box **
  196. Scott Dunn... Been to the track with "Big Red" yet?
  197. Its Over
  198. Survived the track with minimal difficulties
  199. so what's the story ?
  200. Subwoofer box
  201. anyone know?
  202. New Style Billet Caps Included Free
  203. How much HP can stock block handle?
  204. "How To" remove the EGR and Boost bypass solenoid
  205. electrical problem
  206. Help-Heart-stopping possible engine problem
  207. Frame Replacement
  208. screwing up EGR delete, help asap please?[merged]
  209. Newb L owner with a few questions
  210. im getting a ported blower, now what?
  211. So far the Mag and 60's are awesome......
  212. could this be the answer to my prob???
  213. dynojet/ mass air volts
  214. Wide band question.
  215. I think i'm ready for the track tomorrow
  216. Vacuum line schematic
  217. Increased Performance
  218. wiring interchiller and intercooler pump mod together q's?
  219. Cant adj global Timing(PRED)
  220. New thread for my build
  221. Oil leaking from Thunder Pipe?
  222. Why do the SRT guys...
  223. JDM Clunk washers
  224. Cam bolt kit
  225. whipple super charger
  226. New Best!
  227. Have to take Tranny out of overdrive to go WOT
  228. Warrenty!!!
  229. New Hood Is Finally ON!!
  230. Pro Turbo Lightning kit
  231. Kenne Bell Supercharger Install
  232. Fluidyne Heat Exchanger On Sale!
  233. Another Fix for Cruise Control Recall
  234. Hey Guys LTNS...any Hawaii Ls?
  235. Motorcraft oil filters
  236. Finally found a Lightning 200 amp alternator
  237. How much is my L worth?
  238. Aftermarket Heads
  239. Fuel Tank "Y" Fitting revisited
  240. The process of elimination has begun
  241. Who is getting 4lbs of additional boost out of just a ported blower, no addit pulley?
  242. looking for sticker
  243. Window sticker
  244. are 99/00 grilles interchangeable with 01 up?
  245. For anyone ever wanting to Mount a power Drivers seat on the passenger side......
  246. bald hill?
  247. strange belt or pulley whine
  248. Tires...
  249. Lightning 1 / Ferrari 0
  250. Hey Sal - about my order......
