View Full Version : Lightning
  1. Exhaust Upgrade???
  2. Is mixing oil brand's okay?
  3. The Chiken Man Comes Through !!!
  4. drawbacks of cutting front springs
  5. which 2" shackles to give real 1.25" drop
  6. check out this number
  7. Magnaflow High-Flow Cat Failure??
  8. shock info needed
  9. Inputs needed
  10. Got a Question
  11. Catless midpipes for longtubes.....??
  12. pics of my baby
  13. Ported box can be done in the L!
  14. Use clear coat to protect polish?
  15. time to get new tires
  16. Ordering A Ported Everything?
  17. Pulley's??
  18. Loud Intake??
  19. Running Lights
  20. Underhood Bling..
  21. Winter Rim Tire Question
  22. Guess this Noise...
  23. I know i know another quetion
  24. How do I tell if my 02's are bad??
  25. JLP Ram Air Kit *install help*
  26. Daytime Lights (DRL) 03 'L'
  27. Transmission Dragging?
  28. Couple vids from Thursday night.
  29. New Owner here
  30. Personal best at track today. (ventilated block with 200 shot)
  31. First attempt at a video
  32. vomiting spark plugs
  33. Help with PI converter install
  34. Carfax please
  35. Name These Wheels...
  36. Another stupid blower porting question.
  37. Tranny Shifting Harder.....Why?
  38. Predator and Custom Tunes
  39. anyone using a wms long block?
  40. Had something weird happen yesterday. Fuel related.
  41. Opinions on Jet-Hot Header Coating
  42. Gas/Fuel line issue
  43. Fastlane Motorsports in NC
  44. Post your Great Whites...
  45. Eibach Pro Kit info needed
  46. Spark plugs, heat ranges, thermal transfer and you
  47. Do you need a different size belt for underdrive pulley's?
  48. Ouch... Deer strike this mornin'....
  49. ne where near reynolds ga to clearwater fl that has open trailers for an L?
  50. 3/31 Raceway park
  51. enough about greasing things up front...
  52. Need help with stalling issue
  53. Am I crazy or did this really help?
  54. Installed fuel pumps and now have a DTC
  55. ATTN: gbgary
  56. Engine bay pics..Cleaned it up!
  57. HELP! Underhood birds chirping!
  58. Chrome Wheels
  59. Has anyone tried the new Metco Idler design?
  60. Need Direction
  61. Dyno numbers
  62. Keyless remote ?
  63. Gotta Love Spring
  64. Tips for taking "L" out of Winter Storage
  65. Slicks: Can I use 14mm on 12mm studs?
  66. How much boost on 95#'s of valve seat pressure?
  67. need snow perf help asap
  68. Autobahn - New Vid from tonight !
  69. Three questions for the pulley guru's...
  70. Has anyone tried to make a gasket for their JLP Plenum?
  71. torque converter makes noise...
  72. Stock Block Kenne Bell Users
  73. Tire Info needed ASAP
  74. Harley Door Handles $$$$$
  75. Datalogging with Predator
  76. Weight of rear axle assembly?
  77. PSP, can you hear me?
  78. New Nitto's, Powerslots ,wheel bearings Hawk Pads
  79. 6 Lb lower
  80. Still Fine after all these years
  81. EGR Flow Insufficient Detected - code question
  82. New Best at VMP last Sunday.
  83. Anyone ever Backfire?
  84. Well truck is gone..tonight
  85. Coolant blowout?!?!
  86. How much HP will my factory Tranny hold?
  87. guys running 10's, what kind of power, torque, & 60's are you putting out?
  88. How much can I get?
  89. chicken ears air box
  90. horsepower???
  91. Whipple is now installed...
  92. 4 pound lower/ 2.8 upper
  93. suspension question for 2000 L
  94. Center console mod
  95. Emissions with headers and Hi-flows
  96. quick hankook question
  97. Apten or LFP Port?
  98. Manual Swap
  99. GPS in Lightning?
  100. Truck PC
  101. Head/Camshaft question
  102. New personal best @ Moroso 03/25/06
  103. Selling my 01!! Question about putting the truck back to stock and the predator??
  104. After Market Valve Springs (tuners?)
  105. Trk cover
  106. 2004 Base Dyno
  107. Went to the dyno, Ummmmm...
  108. New Personal Best
  109. Had Denotation today???
  110. New Personal Best - (Christine goes STRAIGHT)
  111. 15" rotors/ 4 0r 6 pistons/ Stock wheels
  112. Anyone running Brembo Slotted/Dimpled rotors?
  113. Tubes or no tubes
  114. How much does a Lightning Long Block weigh?
  115. :-)))..... She was waking up today !!
  116. What do you all think happend
  117. Used KB price????
  118. "chirping" noise when I turn on my heat... HELP
  119. The time has come for Taps
  120. Dream came true!!!
  121. Went to the NVMC Dyno Day. Got some new numbers.
  122. Help replacing wheel studs!!!
  123. JBA Shorty Header Opinions
  124. air bags suspension question
  125. Lightning VS Jeep SRT-10
  126. Big Problem with Bassani Cats install HELP!!!
  127. Custom Vented Fender Opinion
  128. I need to beat my buddies SUPRA TT
  129. Anyone have status on the Billet Flow SBTB's
  130. Who's looking to set new records @ SSOTN? II
  131. Anyone using header wraps on their long tubes?
  132. New Dyno #'s! 545rwhp & 667ft/lbs - Graph and Vid inside!
  133. Rims?supercharger
  134. New Supercharger
  135. Help With Freeze Plug / Probe
  136. thanks to Johnny/Sue for the lil green gear for KB
  137. My tinted lights
  138. More roll bar pics.
  139. And the Answer Is? Woo Hoo !!!
  140. WTF!! Clunk while stopping even with clunk washers installed...
  141. Want to get different rims for my slicks. Need advice.
  142. is any one using 97'fuel rail/reg on their L
  143. Something doesn't feel right in the steering
  144. More questionsss
  145. Throwing Codes
  146. I need a few suggestions on an engine build-up
  147. car fax please!!!!
  148. Road Racers (again) - Tire Pressure
  149. Looking to where i can get my manley valve springs
  150. NJ guys or Close to NJ PLEASE HELP
  151. Anyone heard of FFP?
  152. Roll cage
  153. Results from installing the GMS COP's
  154. Lightning Steerin Gear Box
  155. Predator Tune Question
  156. Strange smelling coolant
  157. Control arms vs. spindles
  158. Cool-Aid and Hotchkis!!
  159. Whipple arrived @ the shop today! :)
  160. Another Boost 101 question
  161. What you dont want to see when you walk into Ford
  162. Question about my old spark plugs
  163. Ssotn Dead Line Tommorow!
  164. has any one raced a JOE GIBBS rc 5.3?
  165. ? for low 11/10sec lightnings
  166. what should i run w/these mods?
  167. Help with LFP Supertank Reservoir please
  168. anyone know where i can get these interior clips?
  169. Hex cap for blocking egr, does ford or anyone have a part #?
  170. what size belt with 10lb lower and stock upper
  171. Best Prices on replacing 2000 fog lamp
  172. How common is belt walking for our trucks?
  173. !!!!help!!!!
  174. Exhaust tips in chrom?
  175. Lightning block same as 3 valve 5.4?
  176. Niche performance hood HELP!!!!!!!!!!
  177. anyone using Auto Tap on their Lightning?
  178. Blowing dash light fuses left and right.
  179. Lets talk 60' times
  180. Custom Pedals
  181. will 01-04 headlights fit my 2000 L?
  182. Interchiller is a real nice piece!
  183. Please help
  184. converter gains for my power level
  185. Who can polish the blower etc besides Stiegemeier
  186. New best ET on Nitto DRs - Dyno #'s for TUNING ONLY!
  187. Are there any L Brother's that live near Davie, Fl
  188. 10 series
  189. I think I might be dreamin!
  190. New 10.5" TD Converter working great!
  191. Harley motor Vs L motor
  192. Torque converter issue or tranny problem???
  193. Aftermarket rim question
  194. Help!!! Help!!! Looking For The Best Heads And Cams For A 5.4 3valve Engine !!!
  195. Need A Good Tuner in NC
  196. My new best & a Video of Whip beating me
  197. awesome deal on rims?
  198. ? About Exhaust
  199. teaser pic of the new motor
  200. Who has the best aftermarket tranny?
  201. Finally, my 10 sec pass!!
  202. New "Cool-Aid" installed
  203. How Low?? (Stock Ride Height Question)
  204. Rod bolt torque spec question
  205. Looking for 20s...
  206. 20" rims w/ 275-45-20 for the lightning question
  207. Gauge mounting
  208. Headlight/Foglight Bulbs
  209. How much do you think my 01 is worth ?
  210. 9005 fog lights in 2000 L?
  211. Trucks Done! Tonneau around Bar, Center Console, etc....
  212. How much difference will M/T Drag Radials make....
  213. Heater Hose Leak??
  214. Great vid from our track rental
  215. Roll bar and Expy console mods complete. (pics)
  216. Ssotn April 8th!
  217. Road Racers - Heat Cycling Tires?
  218. silver 2000 L looking for 20s...
  219. What's the best way to replace a corroded battery terminal?
  220. Gauge Pod Question?
  221. what is safer...
  222. How Much Race Fuel To Use?
  223. most afforable way to lower 00 L 2"/4"
  224. Chickenears Custom Floormats Sale!
  225. New COP's...anyone have them yet?
  226. I need help!!
  227. Chilly Intercooler with dry ICE!
  228. Got my 8lb lower...
  229. Boat-like noise?
  230. Another JDM monster released!
  231. Short Block v Long Block?
  232. Cheap L insurance!!!
  233. Harley Rims on a Lightning (ANYONE HAVE PICS?)
  234. Redneck Sportscar
  235. Part number help, please.
  236. Getting to be time for tires....options?....
  237. New built motor break in - how long til you lean on it?
  238. 90 model 454 SS
  239. $ for 00 L?
  240. JLP Now Offers Sct Products!
  241. 4lb with nitrous
  242. Lower Pulley
  243. Front brake caliper brakets ?
  244. JDM Order & Shipping
  245. muffler help?
  246. Help with New Motor
  247. Who has a JLP block
  248. Throttle Position Sensor Reads 1.02
  249. Corbeaus are in - Pics!
  250. Anybody need something water jetted?
