View Full Version : Wheels, Tires & Brakes
- is the bolt pattern the same on a lightning as a f150
- Pics of my truck and new rims/tires (never posted)
- Remove clearcoat
- tire size
- Bridgeston tires...whatcha think...
- 04 brakepads-are they hard to replace??
- Please Help!
- Brake Lights Come On Intermittently
- Slotted or slotted/drilled
- New Tires and Maybe Rims
- wheels?
- hub caps not fitting
- 2005 Tire Size
- Chromed my Lariat rims and dropped rear...
- backspacing & offset for 16x8's
- 285 / 17
- Tread Life - Nitto vs. BFG
- Lug Nut Torque.
- Offset and Backspacing explained!
- Tires after lift?
- Discount messed up me rims!!!!
- Walmart Goodyears
- Zinik Z1 Shoguns
- Leaking Fluid ??
- Zinik Wheels For 05 F150
- EBC 7000 series
- new tires for 03 FX4
- Abs Light
- New Here! Tire Help?
- warranty replacement (attempt)
- Pressure?
- Tires?
- Big Brakes for cheap
- Hey, I can't stop!
- should i do this?
- Pictures of my new 22" rims with 305/40/22 tires
- Shopping for wheels, what should I know?
- What do you think about these?
- wheels for sale
- gearing/towing with lager tires
- 40/99/04trucks (question 4 u)
- Recomendations
- Impossible tire wear?
- how far off
- 285's speedo error 10% mileage 12.5 mpg
- 1995 4x4 Brakes.. Can't get them dissembled.
- Biggest tires?
- Rotor/Hub Assembly by Duralast
- Brakes Squeaky As Hell! How to fix?
- Parking Brake cable part needed
- Best Traction!
- 4 inch BS'ing enough?
- Speedometer Recalibration Question
- Pick a tire, any tire...
- nitto TG 325/60/18 on a 4x2 w/ 2.5" lift?
- Selling my FX4 stock 18" wheels / tires
- sorry to ask again
- Dog Pee On Tires
- matching wheels, explorer/f-150
- Added New Wheels To my 04
- F250 tire question
- 315/75/16 on 8" rims?
- 315/75/16 on a 8" rim??
- Check this out on Ebay 20" roush wheels
- Deciding on wheels
- 33's on stock 15 inch rims???
- abs light on
- wheels tires for a 97 f150
- New brakes for 02 Supercrew?
- Will a 325w tire fit on a 12" wide rim?
- 4 wheel parts
- Another "Will it fit" Question
- 03 FX4 wheels on 05 4x4????
- Good Asking Price For Tires?
- chrome cleaner & protection
- awful brakes
- What is the biggest tire that will fit under '04 F-250 FX4?
- cant find lugnuts
- is the vss gear directional ??
- chrome needs cleansing
- chrome cleaner
- 2000 F150 Ligthing Rims Fix On 98 Exped?
- bfgoodrich for sale? anyone?
- E-break
- Walker Evans
- New Tires
- can i fit a 36x13.5 with a 3 inch body lift
- Alternatives
- tire size and towing
- Nitto Mud Grappler
- 31x10.50
- tire size question, please help.
- 33" tires for '96....HELP please!
- Up grading tire size for specific use
- Nitto TG tires
- semi-metalic or ceramic brake pads???
- Purchasing tires off the internet
- Factory Rims
- 2004 F-150 FX4, grooves in rear rotors
- Good place for center caps
- speed with new tires??
- shaking and tire marks
- tire help
- Cheapest Place to buy Rims and Tires
- Will these fit?
- Just got mine in..
- looking for tires. . . likey 285s
- New Rotors
- Pedal goes to floor
- 2004 F150 HD 8200 17" 7 Lug rims
- Aftermarket wheel setups, no lift, no drop
- tire size cross reference
- Anybody heard of this happening???
- New shoes!
- Largest Factory Tire Package Offered for 98 F150?
- Front Rotor Replacement- New Bearings?
- Pulling to one side when braking
- 04 Supercrew 4x4
- pics of 35" on stock 18"
- 97' F150 15" wheels? Backspacing? fit?
- P/C X-Terrains- just ordered
- Which Tires? Toyo AT's or BFG AT/KO's?
- I Dont Know Sizes.
- 4 Tires 2 with diff. Load range.
- 305/70R16's with no lift
- How to check ABS connector
- 305/65-17's ???
- New Shoes...
- ABS problem again
- Dunlop Radial Mud Rovers
- 235/75R-15 vs. 265/75R-15 ??
- Kumho M/T's
- Show me your black letter tires !
- Rear Rotors
- rotors, rearend and virbration
- Stock Chromed Wheels Pitting?
- 285's or 305's on 16x7 Rims
- Low Price Tires for DFW
- Which 305/45-22 is better?
- replace calipers?
- I saw these will they fit?
- BFG LT315/70r17/d's on 1997 4X4
- 35" Xterrain Tires
- Tire Size
- Bigger tires and gearing
- Tire Size
- after pad install?'s
- Max Wheels and Tires for 2001 4x2 Supercab?
- brakes pulsating
- BFGoodrich MT T/A KM vs. Goodyear Wrangler MT/R
- TRXUS A/T vs. Radial Claw
- Correct Tire Pressure
- New guy with questions
- 2005 FX4 18" wheel/tire blues
- Tire question again....
- Cupped tire wear cause?
- brake lights not functioning
- Black Wheelsin 4 days
- New 3" lift and 33"
- More Rubber!!!
- Rear rotors?
- Hydroplaning
- Spare + New Tire on front or back?
- Front Brakes bad?
- 1993 f150 what is the biggest size without problems
- Backspaceing
- idle steering???
- Drum brakes
- Someone Has Got To Have An Answer?!?!?!
- super swamper
- Brake Master Cyl
- Goodyear Wrangler MT/R
- Black wheels...
- What can they handle??
- Possible Abs Brake Problem??
- 20" Nitto Terra Grapplers
- Is it Tire Noise?
- Tires on a real Tight budget
- polish or paint boyd smoothie 2
- wheel and tire suggestions
- What size tires?
- Another Tire and Wheel ?
- 16 inch or 17 inch rims
- Another ABS Question
- Nitto's on Expedition
- help wit h size of tires an rims
- 24" Help
- Bridgestone Dueler A/T Revo
- New Brakes Needed?
- Tire question for wandell or anyone else?
- Warped rotors on 02 F150
- In search of the Perfect Wheels
- New Rims
- shoes
- Cavalier Sport King A/t
- Help Need Info.
- Brake noise
- Best Tires out there for good price?
- how big of tires will fit?
- Biggest tires without rubbing or other problems.
- mud flaps
- Firestone Destination M/T
- I need quick tire help???
- oversive tires on a 2-wheel drive?!?!?!
- new guy and a tire question
- I just got my 22's
- what will fit?
- Painting wheels
- Tires needed
- new tires with lift ??? 1997 150 xlt offroad
- Tire diameter question
- Biggest size on 04 supercrew
- Tires and rims---HELP!
- Tire Size For 90 F150
- 3" Lift
- Rim Choices
- 285 x's 33
- help! i want new wheels!
- nitto 295/70 R17?
- 35-12.50x17 Bfg M/t
- Need Opinions on these...
- Motorcraft ceramics almost get me killed... anyone else had issues with their SCab?
- 89 f150 rear brakes
- Which wheel do you recommend for 04 FX4
- Need New Tires on My 04 FX4
- Brake fluid shelf life??
- Right Rear Disc Brake Dragging
- Rear drum to disc conversion
- 98 150 rear Drum brakes to new disc brakes?
- Locking lug nuts
- 2WD Front Rotor torque values
- Almost Got Killed
- ABS wire corrosion
- Wheel Shake/Chatter
- Picture of my truck on 22's
- Got new wheels, anyone want FX4's?
- Tires
- SQWEEK help
- Best tire sze for my 20's
- need new pads which ones are best?
- Out of all the Mud Tires out there, which will give you the most tread life?
- Offset & Backspacing info
- Questions on ordering 2005
- Weld Velocity w/315/70/17 BFG ATKO pics here
- Best store for parts
- What tires for my 2002?
- 305/45/22 on my 04' 4x2 SCrew?
- Pics of supercrews with stock ride height with 285/70/17 BFG A/T
- Stock Chrome Wheels?
- Stock Tire pressure
